Sponsored by The Tire Rack
Old 04-18-2009, 10:39 AM   #1
325i-Vizon
O.D.
My Ride: 2010 335i
Send a message via AIM to 325i-Vizon Send a message via Yahoo to 325i-Vizon
Another offset question....
Will these fit my 2001 325i lowered on eibach prokit? I searched but couldn't find anything like this...
Fronts 19x8 +38 (235 tire)
Rears 19x9 +36 (265 tire)
325i-Vizon is offline   Reply With Quote
Old 04-18-2009, 03:08 PM   #2
BartenderPlease
My Ride: '03 540i/6 M-Sport
I wouldn't recommend that, you look pretty low. If you did a 225 front and 245 rear, then maybe so.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 04-18-2009, 07:01 PM   #3
325i-Vizon
O.D.
My Ride: 2010 335i
Is it the offset that is bad or the tire size bc I currently run a set of Iforged senekas 19x8.5, 9.0 w/ 235/265 tires...
Old 04-18-2009, 08:07 PM   #4
Chris-TK
My Ride: Mk VI GTI
It's the offset. You need to be running a 40-45mm on a sedan. Even then the 265 might give you problems. If you want those 265s get a 45+ mm rear.
K.
Chris-TK is offline   Reply With Quote
Old 04-19-2009, 11:47 AM   #5
325i-Vizon
O.D.
My Ride: 2010 335i
Hmm dang, that sucks, was really looking forward to a set a wheels offered to me with this offset
Edit - Forgot to add, I have had my rear fenders rolled, I don't know if that makes a difference or not. Would really like to try and get these wheels to fit.
Old 04-19-2009, 03:52 PM   #6
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
The fronts you will be okay with on 235/35/19's. As far as the rear, it gets a bit tricky since you have a sedan and being at that height. 19x9.0 +36 would only be 3mm more aggressive then a 19x9.5 +45 wheel but with a 265/30/19 tire, that will pose a challenge. I would suggest going with a 245 rear tire to be safe from any kind of rubbing issues. Some aggressive fender rolling/flaring will be needed to run a 265 rear tire.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 04-19-2009, 06:57 PM   #7
325i-Vizon
O.D.
My Ride: 2010 335i
Thanks for the help! So would I want a 245/30/19?
Edit...nvm don't think I understand what the "30" stands for lol
Guess I can only get a 35, or 40 for a 245/19....which do I want ?
Old 04-19-2009, 08:30 PM   #8
Chris-TK
My Ride: Mk VI GTI
The middle number is a profile, which is a percentage of the width. So a 245/30/19 is a tire that is 245mm wide with a height of 30% of 245 and 19 inches in diameter.
I would go with a 245/35/19. A 245/30/19 is very small.
K.
