Old 04-18-2009, 07:55 PM   #1
Zero2_2005
My Ride: 328i
Control Arm Bushing or Joint of Brake Caliper and Arm
Need to fix please watch video!! This is the right front wheel. Wheels are turned to the left.
Zero2_2005 is offline   Reply With Quote
Old 04-18-2009, 08:05 PM   #2
Renboy
My Ride: 04 330Ci '08 Daytona
You need a new control arm.
Renboy is offline   Reply With Quote
Old 04-20-2009, 11:06 AM   #3
Zero2_2005
My Ride: 328i
would i need to do both or will I be okay? The other one doesn't do this.
Old 04-20-2009, 11:09 AM   #4
n2Bimmer
My Ride: Loves Corners
Never Never change out suspension parts only on one side. Change out both sides, and get new bushings also.
Old 04-20-2009, 11:15 AM   #5
Renboy
You can do one side to save now, but be assured that if one has failed, the other is on it's way. It's just better to change both at the same time unless you damaged it by hitting a curb or something else.
Old 04-20-2009, 11:21 AM   #6
GRIDLOCK
My Ride: E36 / E46
Replace your control arms (and your bushings as well).
Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya.
GRIDLOCK is offline   Reply With Quote
328i, bmw, bushing, control arm, sedan
