Sponsored by The Tire Rack
Old 04-19-2009, 06:41 PM   #1
Spdu4ia
My Ride: changes too much
Rear spacer help!
I am wanting to space out my rear wheels more so they are more flush since I'm rolling my fenders.
Specs are 19x9.5 +44 wheel with 255/30 tire. I am lowered on Tein S-techs
I was thinking of a 5mm or 10mm... I think 5mm may be too small and 10mm would poke too far... I NEED HELP
I also found some on Wheeldude.com for $10 and others for $45 ... whats the difference?
-Travis
Spdu4ia is offline   Reply With Quote
Old 04-19-2009, 07:03 PM   #2
BMW-UDM
My Ride: Piggy bank
sup man! 10mm should be fine if ur roling the rears. I have a 256/30/19 on 19x10 with ET 37, i just added 15mm and now i sit at ET22!.. non-m by the way. I have poke but thats what i wanted and it looks hot! I rubb but it should be fine once i roll and pull a bit. Based off that I think u will be fine with 10mm in the rear GL bro!
BMW-UDM is offline   Reply With Quote
Old 04-19-2009, 07:10 PM   #3
dfjaws
My Ride: E90 M3 / E86 M Coupe
I think H&R makes a 8mm spacer?
dfjaws is offline   Reply With Quote
Old 04-19-2009, 07:13 PM   #4
BMW-UDM
My Ride: Piggy bank
^ yeah i think ur right, that would be perfect i think
Old 04-19-2009, 07:15 PM   #5
MrMotorwerk
Der Meisterstück
MrMotorwerk's Avatar
My Ride: '02 330Ci,'01 M3,M4
ask wheeldude if their spacers come with new hardware (longer bolts).
H&R spacers all come with new hardware (longer bolts), I'd pay a little more for a sense of safety. Also check out EAS's Macht Schnell spacers.
Never use spacers without longer bolts, or else you more likely to loose that wheel while driving, don't let anyone tell otherwise.
MrMotorwerk is offline   Reply With Quote
Old 04-19-2009, 07:15 PM   #6
BartenderPlease
My Ride: '03 540i/6 M-Sport
Run a 10 or 12mm. Once you roll the fenders, measure how far the tire is to the lip and base it on that.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 04-19-2009, 07:34 PM   #7
Chris-TK
My Ride: Mk VI GTI
I would NOT run anything more than a 5mm.
K.
Chris-TK is offline   Reply With Quote
Old 04-19-2009, 07:40 PM   #8
dfjaws
^^ BartenderPlease knows his stuff, I'd trust anything he says as far as wheel/tire fitment goes.
Old 04-19-2009, 07:41 PM   #9
Chris-TK
My Ride: Mk VI GTI
Yes he does know his stuff. I'm just speaking from my own observations. I'm running a 9.5" 45mm offset rear with rolled fenders on a coupe with 255's and from my measurements the max I can get away with safely is a 5mm.
K.
Old 04-19-2009, 07:45 PM   #10
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
Any pics of your setup?
Chris
dreamdrivedrift is offline   Reply With Quote
Old 04-19-2009, 07:49 PM   #11
BMW-UDM
My Ride: Piggy bank
i should have pics soon, i am waiting for my mirrors to arrive, its under a car cover right now...no mirrors on the car at the moment, lol...loooooong story
Old 04-19-2009, 09:07 PM   #12
Spdu4ia
I have longer wheel bolts already. So to get the best looking fitment go with a 10mm and rolled fenders. And this setup "should" not rub correct?
-Travis
Old 04-19-2009, 09:09 PM   #13
Chris-TK
My Ride: Mk VI GTI
I think it might rub.
K.
Old 04-19-2009, 09:16 PM   #14
Spdu4ia
I can't seem to find a H&R 8mm spacer. Any help here?
halfway between 5 and 10 so should be perfect right?
-Travis
Old 04-19-2009, 09:17 PM   #15
Chris-TK
My Ride: Mk VI GTI
H&R doesn't make an 8mm. I think that Rogue does though.
K.
Old 04-19-2009, 09:31 PM   #16
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
just get 10's. if it rubs, then it rubs.
thatll put you at a 34. with a 255 it will probably rub, since rolling e46 fenders isnt a true "roll"
BreakMyWallet is offline   Reply With Quote
Old 04-19-2009, 09:36 PM   #17
Spdu4ia
well Wheeldude.com has 8mm spacers... but why are they so much cheaper than all others?
-Travis
Old 04-19-2009, 09:40 PM   #18
Chris-TK
My Ride: Mk VI GTI
Because they're not H&R, Rogue or UUC. Who knows how good they are. Spacers should ALWAYS be hubcentric, which WheelDude's does not specify yes or no. Nor what type of material they're made from.
Who the hell is Wheel Tek is a better question.
K.
Old 04-19-2009, 09:43 PM   #19
MrMotorwerk
Der Meisterstück
The Wheel Tek spacer pictures don't inspire much confidence...
Old 04-19-2009, 09:44 PM   #20
Chris-TK
My Ride: Mk VI GTI
Agreed.
"very strong and lightweight"....great.
K.
