Sponsored by The Tire Rack
Old 04-19-2009, 09:48 PM   #21
Riverbmr3
My Ride: MB E350 & BMW 325i
agreed with H&R, fit 100% order spacers with longer bolts
Riverbmr3 is offline   Reply With Quote
Old 04-20-2009, 12:05 PM   #22
Spdu4ia
My Ride: changes too much
ok so H&R it is... does anyone know were to get an H&R 8mm spacer? All I can seem to find is 5mm and 10mm
-Travis
Spdu4ia is offline   Reply With Quote
Old 04-20-2009, 12:09 PM   #23
BartenderPlease
My Ride: '03 540i/6 M-Sport
Travis, like I said earlier just measure the distance the tire is from the fender lip after you have it rolled. This is the most accurate way to determine what size you need.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 04-20-2009, 12:12 PM   #24
BartenderPlease
Also, there is a company that custom makes hubcentric spacers to whatever size you want. I referenced them in a thread and I know it would be hard to search for. I'll look it up in a bit and get back to you with the company name. I'd suggest doing what I said in the above post and then ordering custom ones.
Old 04-20-2009, 12:40 PM   #25
Spdu4ia
I'm hoping to get under there and crank up the negative camber and push them as far out as I can.
-Travis
Old 04-20-2009, 03:23 PM   #26
BartenderPlease
Keep in mind you'll need to change the toe as well, after you change the camber. Then do your measuring.
