whole house sound system - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 04-20-2009, 08:42 AM   #1
buzzm3
My Ride: 996tt
please help audio guys
my inlaws just bought a house, the previous owner had 15 or 20 speakers throughout the house (he also had 6 plasmas in the living rm and 4 in the bedroom !), he left the wires and the speakers, inlaws want to be able to hook up an amp and have music playing throughout the house either from cd or ipod, obviously most amps dont have jacks for 20 speakers and i assume its not a good idea to just twist all the wires together, all the wires are run to one central location so that helps
can anyone suggest a good amp and whatever else i need to hook up all of these wires please
not sure exactly what the budget is but a few grand would be ok (less than 5k total) this doesnt need to be nightclub quality
01 996tt
08 ML550
06 M3 [gone]
04 ML500 [gone]
01 Nissan Pathfinder
buzzm3 is offline   Reply With Quote
Old 04-20-2009, 09:22 AM   #2
BMWDon
My Ride: Needs a cage
small battery (D or C cell) could be used to help you ID where and what those wires go to, go to the central location and take each pair and tap + and - on the wire pairs and have people call out locations for you, mark the wires. 15-20 speakers? Seriously? Damn somebody liked to play music throughout the house eh? We've got a couple home audio specialists in here, I'm sure you'll get the answers you need.
BMWDon is offline   Reply With Quote
Old 04-20-2009, 09:29 AM   #3
Custom3
My Ride: HellRot 330CI
like john said wireing them together is okay...just try and split them evenly...if the amp has 6 outputs for speakers...divide that by how many speakers you got....20 you said????..so it will be about 3 speaker wires together into 1 output in the amp.....first thing you need to do is look at the specs on the speakers...should be printed on the back.
Old 04-20-2009, 09:35 AM   #4
DME46
My Ride: has free candy.
Home Theater/Home Audio
Home Theater and Home Audio topics, suggestions, set-ups, tricks, tips, gadgets, technology.
You be slackin' JonJon.
embrace this moment
remember
we are eternal
all this pain is an illusion
DME46 is offline   Reply With Quote
Old 04-20-2009, 09:37 AM   #5
slo323ci
My Ride: 00 323ci
Originally Posted by JonJon View Post
But if you wire speakers together (Series/Parallel) doesn't it drop/increase the OHM load on the amp?
Yup.
Does it look like the guy had a rack somewhere where all the wires went to? He must of had some kind of audio distribution system for all of those speakers.
slo323ci is offline   Reply With Quote
Old 04-20-2009, 09:45 AM   #6
Custom3
opps thats what i thought you meant by that....
Depending on how you wire those speakers, you need to do some research as far as the speaker specs/amp specs... Max Wattage/ Ohms/ etc.
So you don't blow anything out.
You cant just wire things together.
Yeah it does drop/increase the OHM load when you wire speakers together but as long as your taking into consideration the specs on the speakers you should be fine....for example if 1 speaker is 100 watts max and if you add another 100 watt max speaker and wire them together you have to think of it as one 200 watt speaker load into the amp in the same input....then you know what your working with when choosing a amp.
Great advice
I don't think I said that, lol
Its been MANY YEARS since my Home/Mobile Audio days....
Old 04-20-2009, 10:02 AM   #7
blownE30M3
My Ride: 2004 JB M3
Send a message via AIM to blownE30M3
This isn't really necessary. Most in ceiling, in wall speakers are going to be around the same wattage and very rarely operate on different impedance.
A battery would be the cheap way to do it. The correct way would be to get a toner from Home Depot, find which pairs go to which speakers, label them, then get an amp based on how many pairs of speakers you have.
As for equipment, you will need 1-2 amps depending on amount of speakers. I would reco. a Sherbourn amp. It has level sensing for channel power, always on, or switchable, along with a 12v sense.
Check them out here: http://www.sherbourn.com/products/index.php
With that you will also need some sort of audio switcher to switch between different sources. With this you can go fairly large with independent sources to each channel or you can get el cheapo from Best Buy and just feed the entire amp one source. I can give you more details on this if you want but it sounds like you are looking for the latter.
Home Automation and A/V Programming
http://www.xsdesignstudios.com
blownE30M3 is offline   Reply With Quote
Old 04-20-2009, 10:54 AM   #8
buzzm3
My Ride: 996tt
thanks guys
all the wires are labelled and in one location, we dont need the sound to switch between rooms or anything fancy, we just want the whole house wired as one so that music will come from all speakers at once
when it comes to amps should i just go for the biggest i can for the money ? i assume i should wait until i can find out exactly what wattage the speakers are
what would you suggest for hooking up the ipod to the amp ? is ther just a smple cable or are there docking statyions etc ?
sorry, its been a long time since i have done this type of thing and ipods werent even a glint in apples eye at the time
01 996tt
08 ML550
06 M3 [gone]
04 ML500 [gone]
Old 04-20-2009, 11:04 AM   #9
scott0482
My Ride: 2001 530i, 1997 M3/4
Send a message via AIM to scott0482
he had something and took it with him. I am guessing it was pretty expensive whatever it was. I have seen some fairly complex stuff. For example I went to hook up computers at a client's house, and he had this unit in the basement that had quite a few inputs for cd, ipod, aux, am/fm of course.. we hooked an ipod up to it and it could be controlled and it could be controlled by little touch screens next to the light switches in several rooms. I was trying to get him to have me hook up a computer down there to it, but it was pointless since it would be much harder to control and this system had built in ipod controls.
I have no idea what it was called.
Try talking to the old owners of the house? They have no know something, especially if they knew enough about it to know how to take it with them, rather than just leaving it with the house.
did a quick google search: http://www.russound.com/cseries_system.htm
this is actually fancier than what they guy had, but the same idea.. (probably just newer) I think you should look into going that route though.
scott0482 is offline   Reply With Quote
Old 04-20-2009, 11:21 AM   #10
buzzm3
My Ride: 996tt
that thing looks awesome, but too awesome for what we need, we dont need to switch zones or anything like that, these are my inlaws, they just want something simple that they can turn on and play music through the whole house at once during parties
so far it seems like i just need an amp, size TBD and then some way of hooking up an ipod to it, they dont really use cds any more but friends may bring some over so i'll have to get them one of those as well
anyone know of any nice docking stations for ipods that i can use ? the system will be in plain site so should look pretty nice if possible
house was a foreclosure so theres no way of contacting the previous owner
01 996tt
08 ML550
06 M3 [gone]
04 ML500 [gone]
Old 04-20-2009, 11:21 AM   #11
blownE30M3
My Ride: 2004 JB M3
Originally Posted by buzzm3 View Post
thanks guys
All you need is a mini to analog line level adapter. They sell them pretty much everywhere.
This example will not charge, but there are cables that will if you want that sort of thing. And you will more then likely need more than 1 amp. My suggestion like I said is to go with Sherbourn or maybe Speakercraft.
Or if you want a dock:
http://www.bestbuy.com/site/olspage....=1142295759733
Go to bestbuy.com and look at the ipod stuff.
Old 04-20-2009, 11:25 AM   #12
buzzm3
My Ride: 996tt
why do i need more than one amp ?
sorry for the noob questions, i just want to understand, thanks for being patient
01 996tt
08 ML550
06 M3 [gone]
04 ML500 [gone]
Old 04-20-2009, 11:29 AM   #13
blownE30M3
My Ride: 2004 JB M3
It sounds like you have more speakers (channels) than most amplifiers will hold. Like I said before you need to figure out how many PAIRS of speakers you have. Once you have that number you will need an amplifier that has that many channels.
If you have 14 speakers, you probably have 7 pairs, i.e. you would need a seven channel amp.
Old 04-20-2009, 11:31 AM   #14
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
WHAT in the HELL are you talking about?
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 04-20-2009, 11:36 AM   #15
buzzm3
My Ride: 996tt
so its not ok to twist 2 speakers wires together and put them into one channel ?
01 996tt
08 ML550
06 M3 [gone]
04 ML500 [gone]
Old 04-20-2009, 11:39 AM   #16
blownE30M3
My Ride: 2004 JB M3
It's typically not a god idea.
Old 04-20-2009, 11:40 AM   #17
GlockMan
GlockMan's Avatar
You need a better than average speaker selector box and/or impedance matching volume controls at a MINIMUM.
The easiest and fastest way to do this properly is to find 6 rooms that you want to listen to.
Take those six rooms and run them to a 6 pair controller, then connect the controller to the amp.
You WILL BLOW YOUR AMP if you wire several pairs together.
I have a New Niles SSVC6 for sale for $300 if you need it...
It protects your amp and gives you independent volume control for each of the 6 rooms...
http://www.crutchfield.com/p_190SSVC...6.html?tp=2997
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 04-20-2009, 11:43 AM   #18
GlockMan
GlockMan's Avatar
NO.
Google: speaker wiring parallel vs series
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 04-20-2009, 11:45 AM   #19
buzzm3
My Ride: 996tt
i dont need volume control for each room, i dont need to switsh between rooms or anything like that, they want it simple
01 996tt
08 ML550
06 M3 [gone]
04 ML500 [gone]
Old 04-20-2009, 11:47 AM   #20
GlockMan
GlockMan's Avatar
You have NO idea what you are talking about.
Please DO NOT give advice on subjects that you are not proficient in.
Opinions are opinions, but elecrical wiring is not really subject to opinion.
You can easily have someone destroy their electronics with advice like this.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
