Sponsored by BAVSOUND
Old 04-20-2009, 08:05 PM   #1
turbokid
My Ride: 2005 325i
err I ment JL 10w7, I want one of these...now help?
Okay so I want to install a JL 10w7 and keep the OEM HU
Heres what I believe I need so far...
JL 10w7 woofer
JL 500/1 amp
Wicked CAS Enclosure
Sven2 LOC, right???
Questions:
What gauge wire kit (brand)do you guys recommend for this set up.
Where can I mount the amplifier so its as discrete as possible with out overheating? Or where do you guys most commonly mount yours?
Any other info would help thanks!
turbokid is offline   Reply With Quote
Old 04-21-2009, 12:53 PM   #2
//TRD power
My Ride: 3.0 | 200hp | 214trq
You can definetely keep your HK setup the way it is, as it runs on its own amp. You can mount the amp on the sub box to keep everything clean or on the back of the seat, whatever your preference. Personally, I have my amp mounted to the right of the box facing it. JL amps are very sturdy and you should not worry too much about it overheating with a single woofer setup.
//TRD power is offline   Reply With Quote
Old 04-21-2009, 01:39 PM   #3
turbokid
My Ride: 2005 325i
HK set up... I dont have an HK ooo HU... I ment head unit by that... and Im going to go with the wicked cas box , I think ill mount the amp on the ceiling of the trunk, I read that some have done that...
My main concerns are what LOC will I need for a JL 500/1 amp and what gauge and brand wiring to you guys suggest?
Old 04-21-2009, 02:40 PM   #4
SCOOTTER
My Ride: 330sexi/gsx-r-1K
Go with a 4gauge wire. You don't have far to go, so it wont cost a ton.
I will not trade freedom for beneficence nor my dignity for a handout.
I will never cower before any master nor bend to any threat.
SCOOTTER is offline   Reply With Quote
Old 04-21-2009, 03:20 PM   #5
turbokid
My Ride: 2005 325i
okay thanks! should I just get it cut to length from a shop?
any Idea on what LOC i will need?
Old 04-22-2009, 01:56 PM   #6
//TRD power
you ground and power are going to be short and simple since your battery is right in the trunk, your signal wires and remote are going to be the ones you'll need adequate measuring of, get a little bit longer just in case.
Old 04-22-2009, 03:02 PM   #7
turbokid
My Ride: 2005 325i
okay, but what about a LOC!!! lol i searched and am not finding anything specific to a 500/1 amp????
Old 04-22-2009, 05:15 PM   #8
325CI2004
My Ride: 09 335I
a sven 2 will work with that setup.
09 E90 335i Alpine White/Chestnut Brown
325CI2004 is offline   Reply With Quote
Old 04-23-2009, 06:23 AM   #9
turbokid
My Ride: 2005 325i
will the LOC affect the quality of my sound? What I mean is.... is there a better LOC I should get?
Old 04-23-2009, 01:21 PM   #10
325CI2004
My Ride: 09 335I
all you really need is the SVEN. They do have more expensive options.
When i originally installed my system, i just added subs, components, and amps with a LOC. I wasnt happy with the lack of flexibility with the stock radio so i installed a headunit. That would be the best option, but alot feel that the headunits look out of place in our dashes. With the stock radio, you dont get any control of the sound other than volume, fader, balance. You do get bass and treble, but it affects the whole stereo. With an aftermarket headunit, you can control different aspects of your system.
Instead of buying a high price LOC like the Rockford 3.sixty, or the Audiocontrol LC6i, i would look to get a headunit. Many have used the Sven2/4 LOCs and have been happy with them.
Old 04-23-2009, 02:04 PM   #11
turbokid
My Ride: 2005 325i
yah i def. dont want a new HU I like the oem look , are there any benefits to the more expensive LOCs?
Old 04-23-2009, 03:58 PM   #12
325CI2004
My Ride: 09 335I
for your setup, no. If you were to run new components with an amp, and run all your audio signals thru them, then it offers you more flexibility with crossovers, time-alignment, sound processing.
Since your just running a sub, i would just do a sven 2.
Old 04-24-2009, 08:34 AM   #13
turbokid
My Ride: 2005 325i
thanks for the help my man!
Old 04-24-2009, 01:10 PM   #14
ca1242
My Ride: 2003 330i
Don't need a loc for the 500/1. Just tap into the oem amplifier inputs and solder some RCA wires, then plug into the new amp.
Old 04-24-2009, 01:57 PM   #15
turbokid
My Ride: 2005 325i
uh-oh, now im getting mixed signals?
(no pun intended)
Old 04-24-2009, 02:07 PM   #16
ca1242
My Ride: 2003 330i
OEM head unit puts out a balanced-differential signal. 500/1 can take this signal directly, no adaptors necessary.
Old 04-24-2009, 02:10 PM   #17
turbokid
My Ride: 2005 325i
thanks ca1242! save me some cash...
Old 04-24-2009, 03:41 PM   #18
325CI2004
My Ride: 09 335I
good catch. Im not too familiar with JL Amps.
Old 05-14-2009, 09:09 AM   #19
turbokid
My Ride: 2005 325i
would it hurt if I installed a LOC any how?
Old 05-14-2009, 10:39 AM   #20
ca1242
My Ride: 2003 330i
It is not going to hurt but it is one additional knob to adjust and one additional component that can fail. I personally like to keep things simple and minimize equipment.
