Sponsored by The Tire Rack
Old 04-20-2009, 07:18 PM   #1
kentrob11
My Ride: 2001 BMW 330ci
Which wheel spacer?!?!
Hey guys...I have an 01 330ci with stock wheels on it. They sit pretty far inside the fender and while I don't feel like spending the kind of money it would take to fill them out a bit more, I wouldn't mind the wheels coming out a bit further. I'm going to be upgrading to a 6 series in a couple of years so I don't want to spend much....Are there spacers wide enough to close the gap with these? Would they leave me with tons of vibration? Any help would be greatly appreciated!
2001 330ci
kentrob11 is offline   Reply With Quote
Old 04-20-2009, 07:45 PM   #2
Chris-TK
My Ride: Mk VI GTI
Get H&R Trak spacers.
10mm up front and 15mm rear.
K.
Chris-TK is offline   Reply With Quote
Old 04-20-2009, 08:37 PM   #3
Breakin Newz
My Ride: BMW
don't know the offset on those oem wheels, but I have 12mm (4door) all the way around on my stock 119 wheels and it sits perfect lowered on cupkit... No rubbing!
I'd get the Rogue Engineering spacers they are LIGHT! I'd say 12mm up front for you and 15mm in back since coupe's have more room in the rear...
rogueengineering.com
Breakin Newz is offline   Reply With Quote
Old 04-21-2009, 03:41 PM   #4
Auraraptor
My Ride: -
Make sure to get longer bolts of the right length (+12/+15mm)
Auraraptor is offline   Reply With Quote
Old 04-21-2009, 03:54 PM   #5
Riverbmr3
My Ride: MB E350 & BMW 325i
i have 10mm all around in my stock 17's lowered with sport cup kit, H&R with longer bolts is what you need.
Riverbmr3 is offline   Reply With Quote
Old 04-21-2009, 05:33 PM   #6
david @ eas
Past Site Sponsor
My Ride: E46 M3
I would go with 10mm up front and 12-15mm in the rear, but make sure to measure it up first... All cars can be different in terms of how the suspension has been treated over it's lifetime. Feel free to check out the links below after you measure that up:
Competition Wheel Spacer kit Features:
- Machined from 6061-T6 aerospace aluminum
- Chamfered edges allows installation & removal quick and easy
- Black anodized finish for additional strength and corrosion/wear resistance
- Improve handling by reducing body roll with a wider wheel base
- Included black extended-length corrosion-resistant wheel fasteners
Macht Schnell - Competition Wheel Spacer kit for BMW - 03mm
http://www.europeanautosource.com/pr...oducts_id=2197
Macht Schnell - Competition Wheel Spacer kit for BMW - 05mm
http://www.europeanautosource.com/pr...oducts_id=2198
Macht Schnell - Competition Wheel Spacer kit for BMW - 10mm
http://www.europeanautosource.com/pr...oducts_id=2199
Macht Schnell - Competition Wheel Spacer kit for BMW - 12mm
http://www.europeanautosource.com/pr...oducts_id=2200
Macht Schnell - Competition Wheel Spacer kit for BMW - 15mm
http://www.europeanautosource.com/pr...oducts_id=2201
Macht Schnell - Competition Wheel Spacer kit for BMW - 18mm
http://www.europeanautosource.com/pr...oducts_id=2202
david @ eas is offline   Reply With Quote
