Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 04-21-2009, 09:53 AM   #1
99FRC
My Ride: 06 Aw-Imola M3
ddm coilover tape on camber plate
i have a question ive read before you have to put tape on camber plate so it doesnt make noises when in contact with shock tower?
how do i put tape on and how much maybe some pictures or am i wrong?
99FRC is offline   Reply With Quote
Old 04-21-2009, 11:57 AM   #2
99FRC
i just spoke to a ddm rep he recommended to use tape to minimize noise so i guess ill put some duck tape on top of them
Old 04-21-2009, 12:04 PM   #3
JohnBlaze
My Ride: Black Sunshine
never heard of that? what noise is duct tape going to prevent?
s54door
JohnBlaze is offline   Reply With Quote
Old 04-21-2009, 06:32 PM   #4
rachel330cic
My Ride: BMW 330cic
I've never heard of it eaither but it makes sense. It prevents metal to metal noise
rachel330cic is offline   Reply With Quote
Old 04-22-2009, 09:27 AM   #5
Custom3
My Ride: HellRot 330CI
im wondering if the oem bump stop cut in half like recommend in this thread is better then putting some tape.
http://forum.e46fanatics.com/showthr...t=coilover+diy
Old 04-22-2009, 09:59 AM   #6
TxZHP04
My Ride: ESS TS2+ ZHP
There shouldn't be any metal to metal noise, the plates should be bolted securely to the strut tower.
Old 04-22-2009, 07:33 PM   #7
99FRC
maybe ur right but i will be installing them next week ill put take on just in case lol if it wont make a difference then its fine and if it will thats even better
custom 3 ur talking about a different thing i belive we dont need bumnp stops with ddm coilovers the tape im talking about goes where the camber plate on top meets the shock tower inside
Old 04-22-2009, 07:43 PM   #8
BreakMyWallet
My Ride: B6 A4
BreakMyWallet is offline   Reply With Quote
Old 01-03-2011, 05:26 PM   #9
ultraviolet_m
My Ride: E46 325 CI
Send a message via Skype™ to ultraviolet_m
I have the same problem, mine beats on metal like crazy and I was looking for advice on that too. Any suggestions. I believe it happens only when the car is really low to the ground and the nut of the strut meets the strut mount when going through bumps with low speed. Probably some rubber or some Teflon tape?
Pending Current Projects - Full White LED Interior(done)/ ZHP Suspension & Ground Control adjustable coilovers(done)/ Black CF window trim wrapping(almost..)/ ECIS CAI filter replacement(done)/ Sprint Booster(done)
ultraviolet_m is offline   Reply With Quote
Old 01-03-2011, 07:00 PM   #10
FTWeisse
My Ride: has no hip-hop rimz
I guess you can try it - wouldn't hurt.
My only concern is that maybe yours are loose somewhere - I've never had any noise coming from my street cars that have camber plates...
Old 01-03-2011, 08:01 PM   #11
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
I agree, I'm running the plates that came with my D2's and no noise. Make sure your perches are all tight and not loose. I know a loose perch will cause this, same with adjustable end links or loose bolts. Anyway if your rubbing that tape would only be a short term solution, as rubbing back and forth over time would wear away at it.
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is online now   Reply With Quote
