Old 04-22-2009, 12:00 AM   #1
Novare330
My Ride: AA s/c AMBULAMPS
Attn: Those with oil temp gauge...
and have chosen to install it this particular way...
where did you guys get the sender that threads into the drain plug hole? what size is it and how much did it run you?
thanks!!!!
- Stan Peng -
EUROPROJEKTZ Southeast | Co-Director
Originally Posted by drbworld View Post
Need some opinion. Stock Titanium Silver coupe without spoiler, using the 2 Fast 2 furious skyline vinyl scheme. What do you think, do it or not? plus, i think it would look better then what most car members have here.
Novare330 is offline   Reply With Quote
Old 04-22-2009, 01:08 AM   #2
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
i got mine from leatherz.com and it came with the sender.
AMG-ETR is offline   Reply With Quote
Old 04-22-2009, 01:24 AM   #3
Novare330
the vdo gauge came with the sender?
- Stan Peng -
Old 04-22-2009, 01:30 AM   #4
AMG-ETR
yeah man came with everything:
http://leatherz.com/Merchant5/mercha...=E46_GaugeKits
Look at option one and two.
Old 04-22-2009, 09:34 PM   #5
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
The leatherZ kit taps into the back of the oil filter housing. There are pros and cons. Pro being it reads the same place where the factory oil pressure is located. Con being that the vdo kit sender is way too big and that space is way too tight. Go for an Autometer, Defi or Greddy and you will get a 1/8 npt sender. More compact sender.
The drain plug is where I mount mine. The plug is M12x1.5 and there are adapters sold by Autometer or egauges that allow a M12 to 1/8npt.
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
Old 04-22-2009, 09:56 PM   #6
Novare330
so the sender that comes with the DEFI oil temp gauge threads directly into the drain plug hole?
- Stan Peng -
Old 04-22-2009, 10:13 PM   #7
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
yeah that how its set up on mine also.
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
Old 04-22-2009, 10:16 PM   #8
Custom3
My Ride: HellRot 330CI
i want this bad....so god damn expensive though...well for me it is
Old 04-22-2009, 10:26 PM   #9
Custom3
its a little cheaper here
http://www.bavauto.com/fland.asp?par...DO%20KIT%20E46
Old 04-25-2009, 09:16 PM   #10
fmzip
My Ride: '08 328xi / '01 530i
Same here
fmzip is offline   Reply With Quote
Old 07-08-2010, 12:10 PM   #11
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
Originally Posted by Custom3 View Post
Are they the exact same kit that leatherz has? Bavauto VDO guages are cheaper. I wonder if the illumination is the same as leatherz. I lioke to keep everything amber - leatherz states only thier kit is amber.
VDO Vision Series Gauges (Oil Pressure, Oil Temperature, and Voltmeter)
OEM-matching amber illumination (only available from LeatherZ)
LeatherZ Oil Distribution Block, with senders pre-installed, that replaces the factory oil pressure switch and measures temperature and pressure at the oil filter housing
LeatherZ E46 Gauge Panel, which replaces the storage bin. The LeatherZ Gauge Panel is CNC cut from ABS plastic for a perfect fit and is covered in Black Spinneybeck Leather
Oil-resistant wiring and connectors
Detailed, step-by-step installation instructions specifically written for E46 cars with pictures and diagrams
phamine is offline   Reply With Quote
Old 07-08-2010, 06:22 PM   #12
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
Those are some ugly gauges! I wish EAS would make some gauges like they did for the E9x M3 series.
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 07-08-2010, 06:38 PM   #13
SweTurbo
Big Pimpin'
My Ride: 323i -98
F yeah . those gauges and the position they're in makes me think they're not even worth $100.
What about a AEM gauge along with an A-pillar mount , or a holder on the dash ?
It looks alot better than that ^^
Old 07-08-2010, 09:44 PM   #14
phamine
They are good looking for stock. No ricey Defi like gauges.
Old 07-10-2010, 07:39 PM   #15
Custom3
they look like they aren't worth $300 is because they aren't worth $300...everything is over priced for our cars
