Old 04-23-2009, 10:19 AM   #1
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
Q about exhaust cam sensor
So I've been throwing codes indicating an exhaust cam sensor problem shortly after a severe overheating condition. This is then accompanied by a fuel mix ratio beyond tolerance in banks 1-3 and 4-6 so it stands to reason that the code is correct and I possibly damaged the exhaust cam sensor when the engine overheated. It's intermittent and doesn't appear to be wiring connector associated. I've resigned myself to the fact that I'm replacing this part. It's looks easy enough. The problem is which part number should I use?
RealOEM indicates that are two parts # used for this
No.DescriptionSupplementQty From Up To Part NumberPriceNotes
5Pulse generator, camshaft1Apr-0412141438082$107.14 See MH 9790718
5Pulse generator, camshaft112147518628$107.14 See MH 9790718
/// MODS
Last edited by TitaniumCranium; 04-23-2009 at 10:25 AM. Reason: part # was formatted as exponential number
Old 04-23-2009, 10:50 AM   #2
ferrarix99
ferrarix99's Avatar
My Ride: 87 325e - 05 M3 Vert
Use the top part number
click for pics of the old ride...
-Nick the Greek-
euro.techniks
Bimmerworld Epic Tune | OEM Euro Headers | CSL Brakes | B&B TriFlo | aFe SuperStock | PSS10 | Varrstoen TE37 | V1 | ZKW Lens Swap | Orion Golds
Want your car coded? PM me.
ferrarix99 is offline   Reply With Quote
Old 04-23-2009, 10:55 AM   #3
K:^P
My Ride: 00 323//65 Fastback
12141438082 saids "Up to Apr-04" and you have a 2002.
If you're dealing with the parts people, let them figure it out.
K:^P is offline   Reply With Quote
Old 04-24-2009, 01:37 AM   #4
TitaniumCranium
/// Limitless
I found out that the top part number "up to Apr-04" is supersceded by the bottom part number.
/// MODS
Old 04-24-2009, 10:49 AM   #5
hummer
My Ride: 2001 330CI
I think this means that production used the top number through 4/04 at which time production changed to the bottom number. The new sensor is the bottom number.
Old 04-24-2009, 12:51 PM   #6
paraklas
My Ride: ESS TS2 320ci
use the bmwfans.info website, it shows which parts supersceed older ones
Old 04-25-2009, 03:55 AM   #7
TitaniumCranium
/// Limitless
Thanks for the tip. Looks like RealOEM and bmwfans.info and you can find out pretty much anything you need.
/// MODS
Old 04-25-2009, 09:48 AM   #8
carbon323
My Ride: -
yeah to what they said, and how did you quote realoem??
carbon323 is offline   Reply With Quote
Old 04-25-2009, 12:29 PM   #9
TitaniumCranium
/// Limitless
I copied the RealOEM table into excel (HTML copy) so I had the column header information along with the part information in the table. Then I deleted the unnecessary rows from the table, copied that and wrapped it in quotes. But I can't figure out how to get rid of the annoying ******> things.
/// MODS
