Sponsored by BAVSOUND
Old 03-02-2003, 09:55 PM   #1
dan4081
My Ride: 2000 323i
Amp wiring problem? help needed.
I installed a kicker 800.4 amp today and two kicker L7 10" subs. It's wired so two channels of the amp are bridged and are seeing a 4 ohm load. I'm running 4 guage power and ground. The ground wire is at the same spot as the battery ground to the chasis. I have a pheonix gold circuit breaker on the power wire.
Here's my problem. When I turn the volume up and the bass hits hard the amp cuts out until I turn it down. This happens with the car running or not.
Any suggestions???? Thanks, Dan
dan4081 is offline   Reply With Quote
Old 03-03-2003, 01:58 AM   #2
CynicalWry
Doesn't like PMs...Email me
CynicalWry's Avatar
My Ride: 00 323i-05 cbr600rr
Send a message via AIM to CynicalWry
do your lights dim? are all your connections solid? Do you have the correct size fuse in your amp kit? How did you bridge it?
is your friend
Authorized Umnitza.com installer
301-825-5871
http://www.robinsNestChildCare.com - - - - - http://www.tntTint.net
CynicalWry is offline   Reply With Quote
Old 03-03-2003, 07:42 AM   #3
dan4081
My Ride: 2000 323i
I haven't checked if the lights dim yet. I have a 140 amp cicuit breaker, all connections are very solid, and the amp is bridged per kickers instructions in the amp owners manual. I haven't put a multimeter on it yet to see what the volts read as I turn it up, guess that will be my next step.
Old 03-03-2003, 07:05 PM   #4
dan4081
My Ride: 2000 323i
Havent been able to put a meter on it yet but the lights dont dim. Any ideas?
Old 03-07-2003, 07:00 AM   #5
BMOBSESSION
My Ride: 330 CI Sport Conv
Are you sure the amp is seeing a 4 OHM load. If all ground and power conections are good, it sounds like the output stage protection is kicking in to stop you from frying the output transistors. Did you wire your power feed directly to the battery terminal ? ( If the supply voltage to the amp drops due to heavy bass output, this can also trigger the amp protection circuit to trip) - As an experiment, try running supply and ground directly to the battery using very heavy guage wiring. If this solves the problem, you knowits power rather than impedance related...
Good luck
BMOBSESSION is offline   Reply With Quote
Old 03-07-2003, 12:17 PM   #6
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Outback
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
Cap it?
VALMONT is online now   Reply With Quote
Old 03-07-2003, 08:14 PM   #7
dan4081
My Ride: 2000 323i
figured out that problem, now for this d#$% alternator noise........
Old 03-08-2003, 05:06 PM   #8
Delirium
yo mama
My Ride: -
what was the problem?
Delirium is offline   Reply With Quote
Old 03-08-2003, 09:35 PM   #9
dan4081
My Ride: 2000 323i
The problem is I am retarded!! The subs were dual 2 ohm and I had ordered dual 4 ohm. I never read the little writing on the box until after they were already in and wired 2 ohm stereo, which my amp wont do! Now everything is fine, except for the fact my air conditioner stopped working today! Some reason the compressor only turns on sometimes.
Old 03-11-2003, 01:49 AM   #10
johnhab
My Ride: '02 330xi
Send a message via AIM to johnhab Send a message via Yahoo to johnhab
You may still have a problem. If that Kicker can't accept high input voltage (above 2V), then you're frying it with the high output voltage of the BMW headunit (over 2V, probably 8V).
If that's the case, you need to install a line output converter between the headunit outputs and the amp inputs.
Better picture coming!
johnhab is offline   Reply With Quote
Old 03-11-2003, 08:41 AM   #11
dan4081
My Ride: 2000 323i
I already installed an alpine headunit. Everything from the stock sound system is gone!
