Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 04-28-2009, 11:39 PM   #1
Bobk528
My Ride: 3 series
Secondary air pump system P0491 and P0492
Last November the Check Engine light appeared on a 2001 325Ci and the diagnostic code reader displayed P0491 and P0492. An independent mechanic replaced the secondary air pump, air valve, electric control valve, and rubber hose at a total cost of $1,050.
After the mechanic cleared the codes, the car ran for 1 day before the Engine light and same codes (P0491 and P0492) returned.
The Check Engine remained on until the mechanic recently searched a BMW bulletin board and determined that the problem was isolated to the non-return valve, which is part number 11611312737. According to Bav Auto, the part cost $16.95 but this small plastic piece looks like it only costs 5 cents. So far the Check Engine light has not returned. If you receive a P0491 and/or P0492 code, you may want to first look into replacing a $17 part.
Bobk528 is offline   Reply With Quote
Old 04-30-2009, 12:06 AM   #2
jeffreyslc
My Ride: 330xi Auto
Thanks for the tip! I just happened to pull those two codes, plus a couple others. Although my SAP is bad (sounds like a vacuum cleaner), but it is good to know what else to watch out for.
Jeff
Jeff
2002 330xi Auto
Steel Blue
Mods: Shark, Conforti CAI, Dinan Tranny s/w, LED interior lights, OEM Alarm install, OEM 6-disc changer install, Homelink Install, Window tint, golf tee mod.
jeffreyslc is offline   Reply With Quote
Old 05-25-2009, 02:34 PM   #3
ferrarix99
ferrarix99's Avatar
My Ride: 87 325e - 05 M3 Vert
Will look into this!
click for pics of the old ride...
-Nick the Greek-
euro.techniks
Bimmerworld Epic Tune | OEM Euro Headers | CSL Brakes | B&B TriFlo | aFe SuperStock | PSS10 | Varrstoen TE37 | V1 | ZKW Lens Swap | Orion Golds
Want your car coded? PM me.
ferrarix99 is offline   Reply With Quote
Old 05-25-2009, 05:13 PM   #4
apollotrance1
My Ride: '02 330i, '05 GSXR1k
ifl
apollotrance1 is offline   Reply With Quote
Old 06-08-2009, 12:15 AM   #5
xi_ter
My Ride: 2003 325xi
I've been getting the CELs too and replaced my valve today. The area is tight to hand access, so I removed the intake cover, the cabin air filter housing and a shield around the brake reservoir. I also decided to replace the hose going into the white/black non-return valve.
DiceyOne removed his cover and his pic shows the connections the the valve from the bottom. Thanks, good for orienting.
Old 06-17-2009, 11:06 PM   #6
Bobk528
My Ride: 3 series
The same codes returned. I checked the fuses located in the glove compartment and found the 50amp fuse for the secondary air pump had blown. I went to AutoZone to purchase a $3 fuse, erased the codes with my diagnostic code reader and the "Check Engine" light has not turned on for over one week.
Old 06-18-2009, 12:05 AM   #7
willsbma
My Ride: 99 323i
I have been having trouble with these codes too and now I'm gonna look into this. Thanks for the heads up. I'm sorry it cost you so much money.
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 03-01-2012, 06:34 PM   #8
jskin1510
My Ride: 08 335xi
welll i've been searching and searching and it sounds like from these two codes you can possibly have one or multiple reasons why these codes come up.. anything from a fuse, to any vaccum leak in the secondary air system, to failure of any individual part/component of this system as well. Why does this have to be so complicated... sorry venting a little because i was hoping i could narrow down possibilities by researching first, well I guess i'll just start with the cheapest fixes first and go from there...
jskin1510 is offline   Reply With Quote
Old 08-29-2012, 09:31 AM   #9
Jmhockey1920
My Ride: 2002 325i
My SES light just came on the other day and I got the famous P0492 problem. I guess the first thing I will do is also start with the cheapest (check/replace the fuse).
Jmhockey1920 is offline   Reply With Quote
Old 08-29-2012, 09:53 AM   #10
Jmhockey1920
My Ride: 2002 325i
I also found this thread if anyone is having this code come up...
http://www.bimmerfest.com/forums/sho...d.php?t=430048
Old 08-29-2012, 11:21 AM   #11
325kev
My Ride: 03 325i 5MT
My SES code popped on a few weeks ago with the P0491 and P0492 codes. There is a small vacuum line that runs around the rear of the intake manifold along the valve cover to the SAP that I had accidentally broken a couple months ago while replacing my valve cover gasket.
I replaced the broken portion of the line with some Autozone vacuum hose (cost maybe $1), cleared the code and it hasnít returned since. First things first, I'd say inspect that line for breaks (especially if you've moved it recently - it can be pretty brittle). I experienced no drivability issues while my SES light was on...
325kev is online now   Reply With Quote
Old 08-29-2012, 11:26 AM   #12
Jmhockey1920
My Ride: 2002 325i
Thanks for that information, Key. I have a question for you. Did you have to remove the SAP in order to find that broken line?
Old 03-10-2016, 06:59 PM   #13
WifE46
My Ride: 2002 BMW 325XI
could this code come from using vacuum line that is too small in diameter?
WifE46 is offline   Reply With Quote
Old 03-10-2016, 07:42 PM   #14
jfoj
My Ride: 330CiC, M5, X5
Not likely.
First things first, Pre-cat O2 sensors cannot be lazy, if they are 10+ years old, original, they should be replaced.
Vacuum hoses cannot be cracked or broken, pump must run.
One of the easiest systems to diagnose on these cars.
Suggest you read these links:
http://forum.e46fanatics.com/showthread.php?t=1041726
http://forum.e46fanatics.com/showthread.php?t=1023149
http://forum.e46fanatics.com/showthread.php?t=965526
http://forum.e46fanatics.com/showthread.php?t=1052605
http://forum.e46fanatics.com/showthread.php?t=1074847
http://forum.e46fanatics.com/showthread.php?t=1074573
http://forum.e46fanatics.com/showthread.php?t=106959
http://forum.e46fanatics.com/showthread.php?t=1078986
http://forum.e46fanatics.com/showthread.php?t=1096889
Old 03-10-2016, 08:03 PM   #15
WifE46
also found the big hose quite soft and ratty looking. what kind of hose should I use to replace this?
Old 03-10-2016, 08:15 PM   #16
jfoj
Quite common problem. After 8+ years ALL the plastic and rubber under the hood is deteriorating.
Suggest you get the hose from the dealer, easiest way to go, you can get these from online dealer or other suppliers like ECS Tuning, FCPEuro.
You might find a molded hose at your local parts store that may fit or have to be cut, but I find it is simpler to get the proper part.
https://www.ecstuning.com/BMW-E46-32...sions/ES26824/
https://www.ecstuning.com/BMW-E46-32...ons/ES2581135/
