Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 05-02-2009, 03:37 PM   #1
jgrecbets
jgrecbets's Avatar
My Ride: e65 750i / e90 328xi
Send a message via AIM to jgrecbets
how to do a outdoor setup?
I want to do a setup in my parents backyard and every year I did it half assed, and always burnt something out.
I want to put about 8 speakers all around the back, but i want to be able to control/turn off certain sets at a time
Do I need special cable for outdoors?
I have an 800w 2 channel amp.. can i use this?
jgrecbets is offline   Reply With Quote
Old 05-02-2009, 08:07 PM   #2
blownE30M3
My Ride: 2004 JB M3
Send a message via AIM to blownE30M3
Niles Audio Outdoor speakers:
http://www.nilesaudio.com/product_de...kers&catcdID=1
Yes you will need direct burial speaker wire.
And no you can't use that amp.
Home Automation and A/V Programming
http://www.xsdesignstudios.com
blownE30M3 is offline   Reply With Quote
Old 05-02-2009, 08:51 PM   #3
B's ZHP
My Ride: 05 330i ZHP
He is right you def have to use direct burial, and most of the time you can throw 2 pair of speakers on one amp if you use an impedence matched volume control wich you will need. The amount of volume controls depends on how many zones you want to break the yard into. You will need at the minimum 2 amps or 1 multichannel amp you can find both at the website he posted.
B's ZHP is offline   Reply With Quote
Old 05-02-2009, 10:09 PM   #4
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
No you dont.
All you need is either a speaker selector box with impedence matching in it or a impedence matching volume control for every pair of speakers. Period. That is what they are for. Why would you 1 impedence matching volume control on two pairs of speakers???
You can run 24 speakers on 12 volume controls off a $300 receiver if you want.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 05-02-2009, 10:10 PM   #5
GlockMan
GlockMan's Avatar
Easiest way...
If you are serious and you want to do it right, PM me.
Send me a list of exactly what you have and your budget.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 05-04-2009, 04:39 PM   #6
B's ZHP
you can do that if you want to run in and out of the house to adjust levels depending on how loud the yard gets during times of entertainment or you can zone your back yard out by placing weatherproof VC's at different locations. And the only reason I suggested multiple pairs of speakers on one VC is because they can be grouped together like a pool zone. If you have 2 pair around the pool you can raise or lower them all together. Whats the purpose of an impedence matched speaker selector with volume control and an impedence matched volume control???? All I am suggesting is multiple VC's in the yard, if he's breaking the 4 pair up in to 2 pair in each zone wouldnt it be easier to run your VC inline with the wire you have to run outside anyway and keep your VC as close to your speakers making volume adjustment on the fly a whole lot more convenient? And if they are 8 ohm speakers why couldnt you put 2 pair on one VC. Any good VC will go down to 4 ohms. Im speaking as if he is only going to have 2 zones in the yard not 8.
Old 05-04-2009, 04:45 PM   #7
GlockMan
GlockMan's Avatar
8 speakers are not 8 zones.
Easiest and cleanest especially if located in different areas or using different models of speakers is 4 impedence matching volume controls. 1 for each pair. It also allows you to easily add another set with another vol control later.
Simple, effective, flexible, and protected.
As far as the switchbox with built in volume controls, I wasnt saying it should be inside. Clearly with 8 speakers, he has protected areas outside. I dont like switchboxes myself, its just a simple solution.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 05-04-2009, 05:24 PM   #8
B's ZHP
I understand what your saying and def am not a fan of speaker selectors myself. Again I was under the impression that he was only going with 2 zones wich is why I originally said 2 VC's. As far as options for addition in the future I wasnt looking into that as he only said what he wanted now. And I know 8 speakers is not 8 zones. 8 speakers also doesnt reqire a 6 pair selector as pictured in your post. I was only trying to get him the most cost effective way of running 8 speakers with volume control at conveniant locations.
Old 05-04-2009, 05:42 PM   #9
GlockMan
GlockMan's Avatar
yes, you could do 2 volume controls with eight 8ohm speakers.
really, you could do 1 volume control with eight 8ohm speakers if wired right.
I just like controlling each pair indiividually myself.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 05-04-2009, 05:50 PM   #10
B's ZHP
Def understand where your coming from Im kinda the same way LOL do you do this down in florida? You have great knowledge in the subject.
Old 05-04-2009, 05:52 PM   #11
GlockMan
GlockMan's Avatar
Thanks.
I own a tiny custom home theater company.
We specialize in mid range systems ($10K-$50K).
I dont do any installs myself, but I am CEDIA certified.
PS - I just got the NuVo WCP for my Grand Concerto system. It is soooooo badazz.
It is an inwall keypad made into a 2 way wireless rechargable remote. All ipod, XM and Radio meta data, control every room together or seperate, it is awesome!
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 05-04-2009, 06:02 PM   #12
B's ZHP
Nice, had a feeling you were in the biz lol way to much info coming from you lol. I just started my own co. up here in New Jersey, Ive been tainted as the co. I worked for before had all big money clients everything was crestron and amx, Kalidescape and blah blah. I actually just saw that unit today at one of my distributors. It is def a great peice.
Sorry JG we Kind of Jacked your thread.
