Sponsored by BAVSOUND
Old 05-02-2009, 04:08 PM   #1
Raysride
My Ride: 01 330 Dinan Cab.
Has anyone pried off the HK grill on coupe/vert.
front door--trying to find out if mid or tweeter is toast. Thanks
Raysride is offline   Reply With Quote
Old 05-02-2009, 09:13 PM   #2
BmwAudio32
My Ride: 2004 Imola 330i ZHP
The grill can be pried off however I believe you have to take the door panel off to do so, which negates the point of doing so. Just follow any of the many available guides to removing the door panel and then you can check your mid and tweeter enclosure.
BmwAudio32 is offline   Reply With Quote
Old 05-02-2009, 09:19 PM   #3
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
Don't pry it off. Remove the door panel and access it from behind.
to remove the door, you need a t-20 torx bit.
3 screws under the arm rest
1 behind the small circular cap behind the interior door handle
1 behind the "air bag" badge you remove from the door panel.
Then it's just pop in push pins you have to pop out to pull the panel off.
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 05-02-2009, 09:37 PM   #4
Raysride
Thanks for info.
Makes sense.Thanks much- Doug in So. Cal.
