Old 05-03-2009, 02:24 PM   #1
05 330CI ZHP
My Ride: 2005 330CI ZHP
Clutch Slave Cylinder question
It looks like I need to replace the metal line that goes into the clutch slave cylinder due the end of the nut that goes into the CDV/rubber clutch line being messed up from being over tightened at some point. Is this just a simple swap and bleed, or am I looking at a big ordeal to swap it out?
Bill
05 330CI ZHP is offline   Reply With Quote
Old 05-04-2009, 09:29 AM   #2
05 330CI ZHP
Anyone? Does anyone at least know if the clutch slave cylinder drains out, if I will have issues getting it working right again? Should I even be messing with this? Any info/help would be appreciated.
Thanks,
Bill
Old 05-04-2009, 10:57 AM   #3
hummer
My Ride: 2001 330CI
It may have been damaged during the CDV delete? If so, remove, replace and bleed like any other line replacement.
Old 05-04-2009, 11:03 AM   #4
05 330CI ZHP
Thanks Man, that is exactly what I was hoping to hear.
Bill
