Old 05-04-2009, 06:23 AM   #1
dh0licious
My Ride: '00 325i
Question Doing cooling system overhaul very soon - what else should i do?
From my reading around here, I should replace belts, tensioners, pulleys while doing the cooling system right?
I am about to order the overhaul kit from Tischer but want to know what else I should attack while down there. I've already bought the 2 belts (conti's) but am having alot of trouble finding correct part numbers for the rest - pulleys, tensioners etc. So part numbers would be great, and any other things you can think of for me to consider.
I drive a late '00 325i step.
TIA
dh0licious is offline   Reply With Quote
Old 05-04-2009, 08:24 AM   #2
bmwbun
Banned
My Ride: Pre-facelift Coupe
realoem.com
bmwbun is offline   Reply With Quote
Old 05-04-2009, 08:36 AM   #3
Custom3
My Ride: HellRot 330CI
hoses...waterpump...temp sensor...belts...tensioner...pulleys...coolant tank...and coolant.
Old 05-04-2009, 08:40 AM   #4
sbocaj55
My Ride: 330
Send a message via AIM to sbocaj55
Can't you get the part numbers off of Tischer's site? PM Evan @ Tischer...he could probably help you out.
sbocaj55 is offline   Reply With Quote
Old 05-04-2009, 08:40 AM   #5
bmwbun
Banned
Read a few DIY write-ups first.
You're going to need some special tools for the fan removal.
You're also going to need an angled ratchet to drain the engine block, torx sockets.... etc.
Old 05-04-2009, 09:31 AM   #6
PK330iZHP
My Ride: '04 330i ZHP TiAg
autohausaz.com has all the parts for the cooling system under that sub directory
PK330iZHP is offline   Reply With Quote
Old 05-04-2009, 08:21 PM   #7
dh0licious
My Ride: '00 325i
I am already getting these parts:
* Thermostat w/ housing/gasket (11537509227)
* Waterpump (11517527910)
* Upper radiator hose (17127510952)
* Lower radiator hose (11531436408)
* Expansion Tank (17117573781)
* Radiator Cap (17111742231)
* Engine drain plug crush ring (07119963200)
* Lower hose temp sensor (13621433077)
* 1 gallon BMW antifreeze (82141467704)
And i already have the belts aswell.
I just need to know part numbers for pulleys and tensioners (i am not mechanically inclined, realoem.com is absolutely useless to me). I will try talking to Evan
