Old 05-04-2009, 11:10 AM   #1
Apollo10
My Ride: 00 e46
2005 325i hesitation at low rpm
Hi guys,
Having read about the vanos issues and having experienced it on my 2000 328ci, I'm wondering if anyone with a 2005 325i has had hesitation at low rpms, high gear??
My car has all stock ecu,exhaust and a ECIS CAI.
Have been running like this for 5 months without any issues.
This morning it was about 46F and after about 20 mins of driving I was in 4th gear just slowing into traffic, around 2,500 - 3,000 rpm and jumped on the throttle. The car hiccups 2 times and then takes off without problems. Didn't do it again but I'm wondering if it might a bad fuel issue (I used chevron 89 Octane last tank.), or the CAI is leaking, other stuff?
The car has just under 29,000 miles. Original fuel filter, plugs, Inspection I, still under warranty.
Thanks for input.
Apollo10 is offline   Reply With Quote
Old 05-04-2009, 02:18 PM   #2
xlash
My Ride: '05 325i MT
Why not put your stock intake back for awhile and see if the problem persists. I can't recall seeing a VANOS issue on an 05.
xlash is offline   Reply With Quote
Old 05-04-2009, 02:43 PM   #3
iansanderson
My Ride: 2001 330CiC
have you checked your intake boot elbow that goes into the throttle body?
iansanderson is offline   Reply With Quote
Old 05-04-2009, 04:04 PM   #4
Apollo10
My Ride: 00 e46
Yup, everything is tight.
I'll give it until tomorrow, then I'll throw back the stock airbox.
I like the CAI sound/response, oh well.
Old 05-04-2009, 04:06 PM   #5
bigcraig77
My Ride: 2000 323i
i have the same issue. the car is perfect after 3k. i have no cel
bigcraig77 is offline   Reply With Quote
Old 05-04-2009, 04:48 PM   #6
Enik
My Ride: 89 525i, 02 325i
Traction control anyone? Might explain the hiccups in response to the "jump on the throttle" part.
Enik is offline   Reply With Quote
Old 05-04-2009, 05:47 PM   #7
Apollo10
My Ride: 00 e46
No, definately not traction control engaging. I had dry streets and 1/2 throttle when it did it this morning. Granted I quickly engaged the throttle but it's a 325i, not super heavvy on the engine torque, if you know what i mean.
I may do an ECU reset (battery cables off) tonight after checking the intake for leaks...
