Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > New England
New England
MA ME NH RI VT
Old 05-04-2009, 01:19 PM   #1
sna77
sna77's Avatar
My Ride: BMW
Retrofit Nav this weekend...
I retrofit OEM Nav in my wife's 2004 325xi this past weekend. Actually, I should say I helped with the retrofit. The real brains behind the operation was Andy, at Bavarian Performance Group in Winchester. We spent the better part of the day working on this.
Bought a complete MKIV DVD-base navigation drive, BM53 radio module and widescreen CD player from a member on here for a good price (came out of a 2005 M3). I wanted to go OEM since I already had OEM Bluetooth, AUX and Sirius in the car, and wanted things to be as easy to use as possible for her...
Anyhow, did the install following these instructions:
OEM instructions:
http://www.bigpatsfans.com/nav/NavInstall.pdf
Someone who did the most detailed retrofit instructions ever (these were incredibly useful--especially Part 2):
Part I (ripping apart your car):
http://www.bigpatsfans.com/nav/Ultim...rofitPart1.pdf
Part II (installing everything):
http://www.bigpatsfans.com/nav/Ultim...rofitPart2.pdf
Here are some pics of the dirty work...
Ripping apart the car...
Wiring harness (its a retrofit harness--you're existing speaker wires stay put)
Everything mounted in the trunk:
Final connections to glove box:
All done!
sna77 is offline   Reply With Quote
Old 05-04-2009, 01:28 PM   #2
dmon_101
My Ride: has sexy fogs/shoes
Send a message via AIM to dmon_101
how hard was moving the HVAC controls down? did the wiring reach easily enough? and does it fit fairly flush?
Dealer Programmable Options | Projector Fogs FTW
There are a lot of Fs and too many Ks in the F/M/K scenario <- posted before I met my wife
To answer your question, it's something you can find by searching the forum or using Google
dmon_101 is offline   Reply With Quote
Old 05-04-2009, 01:34 PM   #3
55fanatic
My Ride: B5 Avant, 07 Denali
BMW sells a bracket to move the HVAC controls, that should be pretty easy actually
55fanatic is offline   Reply With Quote
Old 05-04-2009, 01:44 PM   #4
sna77
sna77's Avatar
My Ride: BMW
HVAC relocation is easy. There is an OEM bracket that's about $65 to do it. Looks prefect, fits perfectly flush. That was probably the easiest part of the install.
Old 05-04-2009, 01:47 PM   #5
sna77
sna77's Avatar
My Ride: BMW
Now that i have the Nav screen in... Next project... reverse camera!
http://www.bimmerboard.com/forums/posts/516841
Old 05-04-2009, 01:49 PM   #6
dmon_101
oh, cool. I was also wondering how the button panel would work with something like that, since I've never taken it apart, and I know different cars have different numbers of buttons. I only have DSC and the HK ones. but this is good info to know in case I ever need to take this apart.
Old 05-04-2009, 02:00 PM   #7
sunydude
My Ride: Boost
What was the total cost for parts and/or labor, if you don't mind me asking?
E46 325i - sold
E46 M/// - sold
2011 WRX - sold !!!
Back to BMW :-)
sunydude is offline   Reply With Quote
Old 05-04-2009, 02:01 PM   #8
sna77
sna77's Avatar
My Ride: BMW
I found all of the parts for around a bit more than $1k... Labor was about 6 hours at the shop...
Actually, I then dropped $150 after all that to buy the 2009 maps (my used one came with 2007 maps)
Old 05-04-2009, 02:18 PM   #9
Ibn_Becharre
My Ride: 00 e46 86 e30
job well done, i've always considered doing this
torrents ftw
BMW_North_America_2009.1_HIGH_DVD
Ibn_Becharre is offline   Reply With Quote
Old 05-04-2009, 02:54 PM   #10
sna77
sna77's Avatar
My Ride: BMW
torrents ftw
thanks...
as for the torrent... nah... The MKIV drive has problems with overheating used burnt DVD's, even using high quality DVD-R's... Either rather not chance ruining a $800 DVD drive over $150... (yes, burnt DVD's have been known to get stuck in the drives and require surgery to remove)... The cost difference to buy a legit disc is so minute that its not worth the risk or headache....
Old 05-04-2009, 03:01 PM   #11
Ibn_Becharre
yeah a friend of mine decided to go legit too, probably for the same reason i suppose
he got his from http://navigationdisk.eu/?p=140
Old 05-04-2009, 03:15 PM   #12
sna77
sna77's Avatar
My Ride: BMW
Interesting... any idea what he paid?
http://www.navteq.com/ ...is where I was about to order mine (same price as at the dealer--exact same thing; packaging etc is all BMW's)... when I did a quick ebay search before I pulled the trigger and someone bought the "High" version for their system that needed a "Professional" which meant I got a good deal on a brand new, legit 2009 DVD
Old 05-04-2009, 03:19 PM   #13
Sam 330ci
My Ride: 03 530i 07 Sierra
Send a message via AIM to Sam 330ci
It must be nice to have money.
Sam 330ci is offline   Reply With Quote
Old 05-04-2009, 04:28 PM   #14
Ibn_Becharre
not sure how much exactly, but if you follow the paypal link on that page, says its listed for $30
Old 05-04-2009, 04:45 PM   #15
sna77
sna77's Avatar
My Ride: BMW
ha... yeah that can't be legit... Although if you had a professional DVD pressing station like software / hardware manufacturers do, I suppose you could make them cheap if mass producing them...
Commercial CDs and DVDs are pressed on large machines with acid etching in a process similar to that used to manufacture phonograph records. Prices can range from the high 10s of thousands to 100s of thousands of dollars for high-volume systems. All consumer grade CDs and DVDs use a sensitive dye or gel that a laser 'burns' through a clear substrate: http://en.wikipedia.org/wiki/CD-R . They are particularly sensitive to UV and heat and the gel layer can quickly lose its stability...
Old 05-04-2009, 04:46 PM   #16
Sam 330ci
sna is there any chance the CD player you took out had a mode button?
Old 05-04-2009, 05:02 PM   #17
sna77
sna77's Avatar
My Ride: BMW
sure did... Its up on ebay now...
http://cgi.ebay.com/ebaymotors/ws/eB...m=280341932132
If you have a pre-2002, you need a $10 antenna adapter, and voila-- Sirius and AUX support (no MP3 as this came from a 2004)...
If you want it Sam, i can give you a good deal on it...
Old 05-04-2009, 05:43 PM   #18
dmon_101
if his is out of your range, I have a pre-facelift sedan deck, same as that, I can get rid of since I don't need it
Old 05-04-2009, 06:39 PM   #19
sna77
sna77's Avatar
My Ride: BMW
prefacelift sedan (99-01) did not have MODE button. MODE button came in 2002.
Here is a 99-01 Business CD ("M" does not equal "MODE")
Old 05-04-2009, 06:42 PM   #20
Sam 330ci
Damn feedback rating of 474 sna
I was thinking about taking it cause I wanted the MODE button but Im using a DICE in mine so I really don't need the mode button I guess. Good luck with the auction
