Old 11-22-2009, 09:09 PM   #121
tylerc
My Ride: 330ci
How and why did you choose 3" for the piping size? Had a 'good old guy' question why I was thinking of going so big for my engine.
tylerc is offline   Reply With Quote
Old 11-22-2009, 10:55 PM   #122
mkodama
mkodama's Avatar
Having only a limited understanding of exhausts and fluid dynamics, I ran off some simple things that I did know;
1) Cross sectional area
2) Weight per foot of tubing
3) Cost per foot of tubing
The setups I got the data for were:
  1. a dual 2.00" setup (stock M54)
  2. a dual 2.50" setup (stock S54)
  3. a single 2.5" setup (stock M52)
  4. a dual 2.25" setup
  5. a single 3.00" setup
  6. a single 3.5" setup
  7. a dual 3.00" setup (like a friend's 330ci race car, lol)
  8. as well as a couple combinations of dual to single or single to dual.
Single pipes have a distinct advantage over dual pipes.
  • Less material compared to dual pipes of equivalent cross sectional area
  • Lighter
  • Cheaper
  • More muffler options
  • Less bending and welding for fabrication
  • Better flow compared to dual pipe of equivalent cross section area according to an SAE article
More specific reasons I went with a single 3" pipe the entire way back, was that single 2.5" has slightly lower cross sectional area than my 330 has stock, and over 3.00" would have difficulties fitting things. The very beginning of my exhaust starts dual, because I had to bring the dual to single, but other than that, I just saw no distinct advantages of a hybrid dual-single system when the single 3" served my purposes almost exactly. Also the 3" system has just a slightly larger cross sectional area than stock, as I didn't want to use something excessively large and worry about sound resonating and making the exhaust note louder and raspier for no reason, as well as avoid totally destroy any engineering the BMW put in to the engine, head, ecu, and stock exhaust. Lastly, a member I respect with his knowledge suggested single 3" and uses this setup in practice.
Old 06-29-2010, 12:44 AM   #123
lkstaack
My Ride: 04 330iZHP, 05 325iT
Mkodama: did you ever finish this exhaust?
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
Old 06-29-2010, 01:10 AM   #124
mkodama
mkodama's Avatar
Nope, I sold the car before I finished. I could have finished, but usually an aftermarket exhaust doesn't help much for the sale of a car, so I put the stock exhaust back on. Now the piping and mufflers are just sitting around.
$100 takes the $400-$500 worth of stuff I've got if anybody wants it.
Old 06-29-2010, 08:00 AM   #125
drivrswntd
My Ride: 330ci
Just PM'd you. I will gladly finish this project.
Jay
Boston BMWCCA chapter
drivrswntd is offline   Reply With Quote
Old 06-29-2010, 01:10 PM   #126
mkodama
mkodama's Avatar
I'm sorting through the small flood of PMs I just got this morning.
I'll respond to everybody shortly.
Old 06-29-2010, 01:41 PM   #127
mkodama
mkodama's Avatar
Exhaust sold in less than 12 hours!
Old 06-29-2010, 01:42 PM   #128
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Old 06-29-2010, 04:14 PM   #129
lkstaack
Did you get another Bimmer? Since I revived your old thread, can you direct me a site that describes the benefits of a single 3" pipe vs a dual 2.5" one? I'm assuming that is the reason you went with the 3" pipe. Thanks.
Lars
Old 06-30-2010, 02:08 AM   #130
mkodama
mkodama's Avatar
I actually went to a Mercedes, but a very special Mercedes at that, a grey market 1985 190E 2.3-16V.
And the answer to why I chose single 3" is a few posts above, at post #122.
Old 06-30-2010, 02:19 AM   #131
farmdog
My Ride: Food Truck
[QUOTE=mkodama;11938978]I actually went to a Mercedes, but a very special Mercedes at that, a grey market 1985 190E 2.3-16V.
Can we see it?
farmdog is online now   Reply With Quote
Old 06-30-2010, 03:18 AM   #132
mkodama
mkodama's Avatar
Originally Posted by farmdog View Post
Can we see it?
Not quite yet. It doesn't look nice at all at the moment, and i'm in a rush to get the engine in perfect shape for a smog check so i can finish up registration on it.
Old 01-20-2012, 11:55 PM   #133
TrippinBimmer
My Ride: Just Fast!
And here is a parts list should anyone decide to do this. This is not exactly what I bought, but if I were to do it again, this is what I'd order:
I haven't quite gotten to the midsection support part yet so that may add something to the list, as well as I still have to install this setup and test it out so this list is not final...
Have a updated list of this?
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 01-21-2012, 12:27 AM   #134
mkodama
mkodama's Avatar
Well, long story short, I sold my E46 before I completed this, so I ended up selling the entire setup to AggieE46 who completed it and tested it.
-Vibrant flanges are too large to fit
-Magnaflow mandrel bent tubing was nicer than the Dynomax
-I ended up using an addtional 3' for 3" straight tubing
-could substitute one of the 90 bends if buying 3' of straight tubing
If you search through AggieE46 you can find more details about the finished exhaust: http://forum.e46fanatics.com/showthread.php?t=736943
Old 01-21-2012, 12:50 AM   #135
TrippinBimmer
My Ride: Just Fast!
Sold it to my best friend Brady! I'm wanting to build the same. Just want to see what u suggest before I order.
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 01-22-2012, 07:41 PM   #136
darksideracer69
My Ride: 01 325ci
does brady have any videos with this setup?
IMAG02051
Old 01-22-2012, 09:22 PM   #137
mkodama
mkodama's Avatar
Old 01-22-2012, 09:29 PM   #138
darksideracer69
My Ride: 01 325ci
That thing is loud
Sent from my SGH-T959V using Bimmer App
IMAG02051
Old 01-23-2012, 01:07 AM   #139
mkodama
mkodama's Avatar
That thing is loud
Yeah, I intended to use it without headers, so the muffler and resonator are both straight through type designs.
Old 01-23-2012, 08:54 PM   #140
aggieE46
Keep it clean
aggieE46's Avatar
Yes, it is quite loud. Currently working on getting a new y-pipe going and I'll probably swap out the muffler for a slightly longer Magnaflow.
