Engine & Performance
Old 05-08-2009, 10:23 PM   #1
SoundOfSpeed
My Ride: Clownshoe
FS: Upgraded Dual Vanos & Solenoids
Complete UPGRADED dual vanos unit. Has 60k miles on it. Has upgraded lifetime seals. Perfect condition.
$200 for the Vanos unit. $130 for the solenoids. Both for $300.
Dual vanos solenoids. These have about 90k miles on them. Work perfectly.
$110.
+Shipping
Ghery
SoundOfSpeed is offline   Reply With Quote
Old 05-10-2009, 07:43 PM   #2
CaliAgents1688
My Ride: 2002 S54 Z3M Coupe
B.U.M.P. for a good seller. AIYEEEEEEE!!!!!!!!!!!
CaliAgents1688 is offline   Reply With Quote
Old 05-12-2009, 06:22 PM   #3
SoundOfSpeed
My Ride: Clownshoe
bump
Ghery
Old 05-14-2009, 08:35 AM   #4
SoundOfSpeed
My Ride: Clownshoe
o_O
Ghery
Old 05-14-2009, 01:10 PM   #5
Maypo
My Ride: 2001 M3
Can you describe what the advantages of the "upgrade" is? I am relatively new here and, according to my mechanic, may need to replace my VANOS pretty soon.
Maypo is offline   Reply With Quote
Old 05-15-2009, 03:17 AM   #6
SoundOfSpeed
My Ride: Clownshoe
There are seals inside the VANOS that go bad, causing the pistons to not move as they should, and your VANOS to fail. I've seen the seals go bad as early as 50k miles even.
This unit has expensive aftermarket seals that will pretty much never go bad.
So this will perform and look like a new unit.
Ghery
Old 05-15-2009, 11:12 AM   #7
Maypo
My Ride: 2001 M3
So, the seal wear is the root cause of the 'rattling' my VANOS is emitting?
Old 05-15-2009, 09:33 PM   #8
Guy With A BMW
My Ride: 2003.5 AW M3 SMG
No...you need to get the Dr. VANOS version or replace one or both the timming chain tensioners!
Guy With A BMW is offline   Reply With Quote
Old 05-15-2009, 10:37 PM   #9
SoundOfSpeed
My Ride: Clownshoe
The Dr. Vanos unit is pretty much the same unit I am selling. The rattling is from the tensioners.
Ghery
Old 05-18-2009, 11:16 AM   #10
Maypo
My Ride: 2001 M3
Thanks for the clarification.
Old 05-18-2009, 04:26 PM   #11
SoundOfSpeed
My Ride: Clownshoe
prices lowered
Ghery
Old 05-18-2009, 10:46 PM   #12
slysloth
My Ride: 2000 328i
hey I am about to do the besian system oring upgrade anyone have experience with those and should i do my solenoids??? my car is 2000 328i with 92k on the clock so i think the solenoids should still be good.
slysloth is offline   Reply With Quote
Old 05-19-2009, 11:01 AM   #13
GrZ3
My Ride: BMW
Engine M52TU double Vanos course 142500 tys
Only on warm engine obtain only such sound ?
-on cold OK
-on hot OK
on warm ( the coefficient the temp. of above blue field and 1/4 )!!!
I change
- the pump of water
- the bearing of alternator
- rings on Vanosie http://www.beisansystems.com
- the tensor of main chain http://www.realoem.com/bmw/showparts...39&hg=11&fg=25 25 9,10,11,12
- the chain of distribution on 2 rolls the tensor and the side - slip http://www.realoem.com/bmw/showparts...71&hg=11&fg=25 25 1,2,3
No trouble code
Please help
GrZ3 is offline   Reply With Quote
Old 05-22-2009, 03:55 AM   #14
SoundOfSpeed
My Ride: Clownshoe
Ghery
Old 05-22-2009, 02:03 PM   #15
GrZ3
My Ride: BMW
Today 03:55 AM SoundOfSpeed ^
How and where Can I buy?
Old 05-28-2009, 12:54 AM   #16
SoundOfSpeed
My Ride: Clownshoe
From me, with a payment through paypal or money order.
Ghery
Old 06-19-2009, 03:36 PM   #17
SoundOfSpeed
My Ride: Clownshoe
Ghery
Old 08-23-2009, 02:12 PM   #18
piotr.kasprzak
My Ride: e46 320 Ci m52tu
I have the same problem with my bmw e46m52tu, what I have to do?
I don't understand this sign "^"
Please help me.
piotr.kasprzak is offline   Reply With Quote
Old 08-23-2009, 03:35 PM   #19
southpaw
My Ride: E36 M3 and E36 318ti
bump for a legit dude.
-Brandon
239whp/227wtq @2700lbs
southpaw is offline   Reply With Quote
Old 08-24-2009, 04:48 PM   #20
piotr.kasprzak
Hi once again
Could you now what this rattle can be?
