Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 05-10-2009, 05:58 AM   #1
oliverreed
My Ride: 318i
Angry loose ,bump steer,wandering,constant correction, steering
after 3 racks,inner,outer ties,2 front tyres,3 alignments,balancing,cabs,i finally called it a day withh my 00 .A question ,ARE THESE CARS GOOD OR BAD TO DRIVE OVERALL,ive kept my 03 step car,but still same issues,i mostly use my astra for driving anywhere ,just keep bm to look at and wash and wax it,
oliverreed is offline   Reply With Quote
Old 05-10-2009, 06:03 AM   #2
EDawg
My Ride: :/
maybe the balljoints on your control arms are bad. that seems like the only thing you haven't changed. other than that, depending on mileage, your struts and strut bearings can be bad. or maybe you're just not accustomed to the fact that the e46 provides a lot of front end feedback, and you are mistaking that with sloppy steering.
EDawg is offline   Reply With Quote
Old 05-10-2009, 07:15 AM   #3
grafiksguy
My Ride: 2010 328xi
Oliver, I can sympathize with your frustrations. I've had a twitch (for lack of a better word) that I've documented here and have been chasing for the better part of two years. Symptoms are a slight yank of the steering wheel when you hit a bump on one side or the other and the steering wheel will twitch/jerk to that side. It's not really a bump-steer because the car doesn't change direction, but I doubt this what BMW intended as "feedback". To recap I've changed: Struts, strut bearings, sway bar bushings, steering links, control arms and CA bushings, flexible steering coupling, 1 tierod, 1 tierod end, and probably something I've forgotten here, and had the car aligned (2X) and had two qualified indy's certify that everything seems in order. Car tracks straight, no noises, just this damn twitch,which by the way, it does with two completely different sets of tires/wheels so I know it's not that, oh, and seems to be a bit worse on the right side. In my case I've decided it's an idiosyncrasy of my particular car and I've come to an grudging acceptance of it. Whenever I read a thread like this however, the Mr. FixIt in me gets wondering again.
grafiksguy is offline   Reply With Quote
Old 05-10-2009, 02:57 PM   #4
oliverreed
My Ride: 318i
thanks for your input,but having the same probs with 2 cars (2000 and 2003) at the same time,makes you think about bmw
Old 05-30-2009, 01:55 PM   #5
jai_c
jai_c's Avatar
My Ride: 2001 325ci
Anyone have a answer for this yet? It's driving me insane. I'm about to put my H&R cupkit in but I hear lowering the car may make it worse. I think mine is pretty bad already, I'm constantly wandering into other lanes. It's crazy because my steering wheel is straight but my wheels are all over the place.
jai_c is offline   Reply With Quote
Old 05-30-2009, 02:28 PM   #6
TxZHP04
My Ride: ESS TS2+ ZHP
Have you guys replaced your RTABs?
Old 05-30-2009, 02:56 PM   #7
jai_c
jai_c's Avatar
My Ride: 2001 325ci
I haven't.
Old 06-28-2009, 02:45 PM   #8
jai_c
jai_c's Avatar
My Ride: 2001 325ci
Just changed my my rtabs and installed my cupkit. definite improvement!!!
Old 06-29-2009, 03:58 PM   #9
Richy_Boy
My Ride: Alpina B3S
I have this on mine and am about to put M3 RTABs on there to see if it helps. My other thought is shock absorbers once the usual culprits are ruled out. So far I have done the front wishbones & bushes and had it aligned - might go for tie rods next (both inner and outer sections).
I also contacted BMW about my flexi steering coupling, yet it seems as my car is RHD I have a very different part, twice as big, twice as strong and twice the price! The BMW parts guy said he's only ever sold two of them - both from accident damage.
..the hunt goes on!
Rich
Alpina B3S - 3.4L, 305bhp, 267ftlb
K&N panel filter, SPAX Coilovers, M3 Sway Bar, RedStuff pads, Brembo Grooved/dimpled discs.
Richy_Boy is offline   Reply With Quote
Old 01-03-2010, 10:37 PM   #10
Ecoloqua
My Ride: 2004 M3
Not to revive a thread that may be long dead but I have the same type of "wandering" on bumpy roads since I bougt my M3. It is an 04' and I bought it with only 24K miles on the clock. I took it in to the dealer for an alignment and they said that my rear bj's were worn and they wanted over 1k to replace them. My head exploded in rage because I could not understand how a car with only 24k miles would already need sus. componenets replaced. Long story/short....I took it to one of the most respected susp. shops in town to have it looked at and they said it was fine. I suspect that it is just the way BMW M3s are made. Espcially after reading the great lengths that some of you go chasing down this perceived problem. I have owned just about every sports car imaginable...including 3 Ferraris, a couple of Vipers, Acura NSX, Porsche 930, several 911's.. etc. All were stock suspension and some had more mileage than my M3. None of them exhibited this sort of "bump steer" effect. I think it is just the design.
Ecoloqua is offline   Reply With Quote
Old 01-04-2010, 02:46 AM   #11
323i matt
My Ride: 323i se 4 door
ive got a 323i se and it does the same thing
ive narrowed it down to the top mounts on the shocks being worn and the bearings so movement in the suspension making the car not as it should
maybe worth checking on yours ?
323i matt is offline   Reply With Quote
Old 01-04-2010, 11:25 AM   #12
CBell330
My Ride: '01 330ci ZSP
my 01 330ci has bump steer...its alot better if your going faster....idk why. ill see if my rear control arm bearings are the culprit. Mine is in the shop for basicaly new right rear ca's wishbone etc. ill tell ya on the 9th(HOPEFULLY)
CBell330 is offline   Reply With Quote
Old 01-27-2013, 09:11 AM   #13
yannis4ny
My Ride: 2004 325ci vert
i am having the same problem. car wandering around after it hits a bump. i know this is quite old thread, but i was wondering if anyone has figure this out? I was quoted 1100 for changing all shocks and struts but i don't feel that this is the problem. Also my right strut tower is deformed just a bit(mushroom). I have a feeling that it might be the strut mounts and this "mushrooming". thanks
yannis4ny is offline   Reply With Quote
Old 01-27-2013, 09:32 AM   #14
DHK
My Ride: 2002 BMW 325Ci
Bad RTABs, and FCABs can lead to wandering steering.
Also on rutty shitty roads, certain tires will tramline like crazy. My summer tires tramline a lot but my winters dont.
DHK is offline   Reply With Quote
Old 01-27-2013, 09:56 AM   #15
yannis4ny
Thanks for the reply, FCABs replaced, RTABs told are good! Asked to change the struts and shocks $1100. maybe they would do the RTABs for free!
Old 01-27-2013, 11:10 AM   #16
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Should replace your steering guibo. Common problem and cannot tell with just looking at the steering joint. Cost about $50-60, but well worth replacing.
BMWCaptain is offline   Reply With Quote
Old 01-27-2013, 01:07 PM   #17
yannis4ny
guibo that was done 15k ago with oem. There is no clicking in my steering wheel.
The car has a sport package and doesn't bounce around when i press down on the front or rear. This is how i eliminate the shock strut problem. there is a little mushrooming on the right shock tower though?
what i have done:
FCABs
stabilizing links/sway bar endlinks
control arms are OEM good
I want to run a poll:
A)who thinks it's the RTABs?
B)the mushrooming effect?
C)the struts?
D) all of the above?
thanks
Old 01-28-2013, 10:57 AM   #18
BMWCaptain
check your ball joints
what i have done:
FCABs
C)the struts?
thanks
Get under your car and check your ball joints. Also check your your strut mounts from above by removing the dust cap.
Old 01-28-2013, 03:22 PM   #19
Mobil
My Ride: 2001 330 Ci
I have a 330ci that is doing the same thing. It has become progressively worse over the last year so I started replacing things and have NOT found the major contributor yet.
So far I have replaced:
Front control arms and bushings
Front wheel bearings
Steering flex coupler (guibo)
Rear trailing arm bushings
All of the above items were showing signs of major wear or damage, improvements inhandling were noticable but none of them were the culprit of the wandering...
I am now more convinced that the shocks/struts and mounts etc are the likely offender. I will investigate their condition this weekend maybe.
So I vote Struts, strut mounts...
Sent from my myTouch_4G_Slide using Bimmer App
Mobil is offline   Reply With Quote
Old 01-28-2013, 03:28 PM   #20
WDE46
My Ride: '13 128i, '04 330Ci
My car still tramlines quite a bit. I believe that is what you guys are experiencing. It wanders a little too. I think my struts may be bad. I'm only at 75k miles but I believe the PO's location had crap roads. My steering is vastly improved after RTABs, FCABs, control arms, and a steering guibo. It's not perfect yet. I'm going for some coilovers or H&R for new suspension components. If that doesn't work, I'm getting a new steering rack.
