Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 02-26-2013, 07:31 PM   #41
123Shift
My Ride: 2001 325i
I did replace the entire control arms and bushings with the Meyle HD's. I checked the tie rods when I was under there and they seemed tight. The boots were not cracked at all. Even the ball joints in the old control arms seemed not too bad with the exception of one of the inners. That was really loose. I got the car used. I am technically the second owner. It was owned by a rich family and sat in a garage most of the time. I have never owned a BMW and never envisioned myself owning one but when I saw it while trolling craigslist it seemed too good to pass up. I've owned a lot of cars over the years but I'm thinking this might be my favorite. Its way up there anyway. I guess I'll try the guibo since it see its like only 50 bucks or so. Is it a tough DIY? And thanks for everyone's help. This site is a godsend. I'd be lost without it!!
123Shift is offline   Reply With Quote
Old 02-26-2013, 08:29 PM   #42
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
It is not that difficult. It requires the proper E-torx bit for the 2 bolts. The guibo can only go on one way. If ithas not been removed in a while, the steering column may not collapse easily. You may have to use a mallet with a screw driver to break it loose. I put the new guibo on the steering rack stub first and get it on all the way before putting the column in.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 05-06-2013, 12:07 PM   #43
Jocke_from_Sweden
My Ride: 325 Touring -02
Originally Posted by DHK View Post
Bad RTABs, and FCABs can lead to wandering steering.
Also on rutty shitty roads, certain tires will tramline like crazy. My summer tires tramline a lot but my winters dont.
What's rtabs and fcabs?
Jocke_from_Sweden is offline   Reply With Quote
Old 05-06-2013, 12:08 PM   #44
WDE46
My Ride: '13 128i, '04 330Ci
RTAB = rear trailing arm bushing
FCAB = front control arm bushing
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 05-06-2013, 01:08 PM   #45
BMWCaptain
Also referred as:
RLCA - REAR LOWER CONTROL ARM
RLCAB - REAR LOWER CONTROL ARM BUSHING
LCA - LOWER CONTROL ARM
LCAB - LOWER CONTROL ARM BUSHING
BMWCaptainE46.com
Old 05-09-2013, 08:19 PM   #46
mattman928
My Ride: e46 M3
Really great dialog on this thread. I am also suffering from the same problem. I have a 2002 M3 convertible with 76k miles on it. Am I correct in assuming that since none of the folks who are tackling this problem have posted a solution that folks have not been able to solve the problem?? Or maybe there is no single silver bullet, and each person had a different issue?
mattman928 is offline   Reply With Quote
Old 05-14-2013, 03:12 PM   #47
123Shift
My Ride: 2001 325i
Mine was fixed with the replacement of the steering guibo and changing the front tires. To be honest I think it was more the tires than the guibo.
Save the manuals!!!
Old 05-14-2013, 03:26 PM   #48
BMWCaptain
I always replace the guibos on my cars because you cannot see the loose guibo, but it makes a big difference. It is a cheap and easy repair that pays dividends no matter what else you do.
BMWCaptainE46.com
Old 11-10-2014, 05:23 PM   #49
mattman928
My Ride: e46 M3
UPDATE: SOLVED!!
After taking a couple of stabs at this problem, I ultimately changed the control arm bushings, new (better quality) tires, and an alignment. Honestly I think the tires made the biggest difference in fixing the problem, that coupled with the alignment. These cars are very sensitive to alignments and the alignment goes out easily!
Old 11-11-2014, 08:33 PM   #50
Tbone8ty
My Ride: 2003 330i
changing RTABs to powerflex help immensely for me, new RTABs also help inner tire wear which can cause more steering wonder.
also something to note is the steering tie-rod ball joints are an area that people forget. a loose ball joint there will increase steering wonder in corners.
Black 2003 BMW 330i 5-spd Sport Package HSD
Tbone8ty is offline   Reply With Quote
