Sponsored by BAVSOUND
Old 05-10-2009, 09:31 PM   #1
nadeemp8
My Ride: 05 325i
Driver's side speakers cutting out...
Hey folks, so was driving along today and my driver's side speakers decided to stop working for a few moments, then came back on, and repeated a few times. Sound played out of all the other speakers without any issues and even my aftermarket sub was fine. Anyone have any similar situation and if so what was the result?
FYI I have the HK system w/ navi and an aftermarket amp wired into the HK sub amp location with a LOC converter...
Thanks in advance!!
Nadeem
nadeemp8 is offline   Reply With Quote
Old 05-11-2009, 10:19 AM   #2
ca1242
My Ride: 2003 330i
Could be a number of things (wiring, amplifier, head unit, speakers). Need to do some troubleshooting to figure it out.
What exactly cut out, the whole left side (ALL left speakers, front + rear)?
Old 05-11-2009, 10:40 AM   #3
nadeemp8
My Ride: 05 325i
Yeah, the whole left side cut out, and it seems that with every bump I go over it switches between off and on. Also I noticed this morning that the rear speaker on the left side crackles when it is not on, and this happens even if the stereo is turned off. I'm thinking a plug may be loose, I did have to remove the locking feature of the plug that goes into the factory amp when splicing into some speaker leads for the amp turn on, I will check that out today to make sure it hasn't come loose!
Old 05-11-2009, 11:36 AM   #4
ca1242
My Ride: 2003 330i
Check connections. If al whole channel is out (all speakers on left), I suspect it might be a head unit issue, wiring from head unit to amp, or to a lesser extent, the amp itself. Try the "banging" test while the stereo is playing:
1. Bang with an open palm around the head unit area, maybe remove the head unit and hit it a couple times, wiggle wires.
2. Try the same on the amp.
Old 05-11-2009, 06:43 PM   #5
//TRD power
My Ride: 3.0 | 200hp | 214trq
check wires to HK amp
//TRD power is offline   Reply With Quote
