Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Old 05-15-2009, 12:16 PM   #1
e46vert
My Ride: 330ci
Will i need another Battery for this set up?
right now i have 10' kicker L7 with Mtx 600/1 mono amp coming out the ski pass. It sounds good but not good enough without a box. I plan to get two 10' Alpine Type R with a Punch 500/2 amp and a capacitor. If i add that set up in my trun, Do I need another battery to power them? or will i be fine with a proper install? I dont really want to get another battery and i dont have the space in my trunk for one.
e46vert is offline   Reply With Quote
Old 05-15-2009, 12:35 PM   #2
325CI2004
My Ride: 09 335I
I hope your not adding it with the setup in there already. Regardless, you shouldnt need another battery as long as yours is in good health. Also, dont waste your money on a capacitor. They are a waste of money and put more strain on your electrical system.
09 E90 335i Alpine White/Chestnut Brown
325CI2004 is offline   Reply With Quote
Old 05-15-2009, 12:42 PM   #3
Skiracer41
My Ride: wastes my money
2 subs and an amp wont put nearly the strain these SUV's with there 400lights, a winch that could pull a tractor trailer up a cliff and ten 15's all individually amped with cute little lights that go to the music! (ok maybe i exagerated alittle)
But 2 12's will be just fine man sorry to pick on ya!
Skiracer41 is offline   Reply With Quote
Old 05-15-2009, 12:43 PM   #4
Skiracer41
oh im sorry 2 10's
Honest mistake
Old 05-15-2009, 12:43 PM   #5
e46vert
My Ride: 330ci
yes the plan is to add the type r with the kicker L7. Dont the capacitor help?
Old 05-15-2009, 02:10 PM   #6
PBFreak817
My Ride: 2005 325i
For 1 thing. I don't recommend having two different brands of subs running off different amplifiers. Sound quality will not be as good.
You most likely will not need a new battery until you test it all out. It should be able to handle the subs but don't exactly know. If your battery does die after installing the subs, then go with another battery. But keep in mind, you should also get a high powered alternator to handle the extra battery
The capacitor is not needed so I wouldn't waste your money. Only get one if you notice your lights dimming when the sub hits.
PBFreak817 is offline   Reply With Quote
Old 05-15-2009, 07:13 PM   #7
325CI2004
My Ride: 09 335I
i never recommend capacitors to anyone. They are the biggest joke in audio. If you get dimming in your car, upgrade the battery. All a cap does is add more strain to the electrical system.
Old 05-15-2009, 07:14 PM   #8
325CI2004
My Ride: 09 335I
with your setup, you should be able to run the 2 subs with no problems. I run 1300wrms to my sub and 125wrms to each door and i get ZERO dimming.
You should have no problems.
Old 05-15-2009, 09:12 PM   #9
//TRD power
My Ride: 3.0 | 200hp | 214trq
you really need 3 subs? I'd say throw out the kicker and put in 2 alpines.
//TRD power is offline   Reply With Quote
Old 05-15-2009, 09:17 PM   #10
325CI2004
My Ride: 09 335I
x2, forgot to comment on this earlier. do one or the other.
Old 05-16-2009, 05:04 AM   #11
ca1242
My Ride: 2003 330i
As others said, adding another amp + subs is not a good idea. The reason is that you have a sub (designed to be in a small enclosure) firing into the ski pass, using the whole trunk as an enclosure. On top of this you are going to add two more subs in a box. This will most likely cause cancellation.
Keep the amp you have, ditch the L7 (which is highly inneficient), and get new subs + a properly designed enclosure.
No need to add a second battery (this will actually cause more strain to your car's electrical system than help). If you do have an old battery 5 years +, might not hurt to upgrade with a high-performance battery (optima, stinger, etc).
If you have already have a cap, won't hurt to put it in. It is not going to drain your electrical system as others suggested. If you don't have one, don't bother.
Old 05-16-2009, 05:20 AM   #12
invictus
My Ride: M3, 749R, SV650
JL 13W7. problem solved.
CCW. Dunlop. Ground Control. StopTech. Hawk. Vorschlag. Rogue Engineering. Recaro. TCDesign. RaceTech. VAC. Motul. Vorsteiner.
Find me on track: 10/19-21 Sonoma Speedway // 11/10-11 Thunderhill
The story so far...
Fund my track car:
PM me about my: stock diffuser, stock trunk
WTB 1x Dunlop Direzza Z1 Star Spec 265/35/18 (used is okay)
invictus is offline   Reply With Quote
Old 05-16-2009, 11:59 AM   #13
325CI2004
My Ride: 09 335I
Old 05-16-2009, 12:05 PM   #14
Laxplayermjd
My Ride: 03 325i
Send a message via AIM to Laxplayermjd Send a message via Yahoo to Laxplayermjd
I second that fact that capacitors are a waste. I had a beater ford contour with a walmart "never start" battery lol. I ran a infinity class d 1300W sub amp with two alpine type r. Also a mtx 400w amp bridged for my component speakers. I ran this for two years and never had any issues or dimming. If you have problems there would be issues with you electrical system , ex battery or alternator cant keep up.
Laxplayermjd is offline   Reply With Quote
Old 05-18-2009, 01:13 AM   #15
blatty86
My Ride: 2002 325i
adding another battery is just gonna decrease the life of ur alternator. i have a rockford t10001 amp and 2 T2's and the only dimming i ever experienced was the interior lighting of the trunk
blatty86 is offline   Reply With Quote
Old 05-18-2009, 01:35 PM   #16
e46vert
My Ride: 330ci
How long have you had this set up?
Old 05-20-2009, 11:30 AM   #17
e46vert
My Ride: 330ci
Okay guys, change of plan, i just found a great deal 2 10' kicker L7 and mtx 81001 mono amp. If i install that with my current set up, Do i need to upgrade my alternator or Battery? Im hoping i wont have to. If it does then i probably just install the 2 10' L7 and the mtx 81001 amp and disconnect my current set up. Any advice?
Old 05-20-2009, 11:57 AM   #18
325CI2004
My Ride: 09 335I
Go with one or the other. Running 2 in a box and 1 IB is going to cause issues. Disconnect your current setup and run the 2 10s in a box or keep the one you have.
Old 05-20-2009, 12:48 PM   #19
e46vert
My Ride: 330ci
yeah im prob. gonna do that and disconnect my current setup (but leave the sub in the ski pass for looks) and go with 2 10' in box with the mtx81001 amp.
