#1 |
TMS Sways..got a few Q's
Anyone have the Turner Motorsport E46 Sway Bar Set? How are they? I was looking into getting these or the H&R Sways, the only difference between the two is TMS costs like $130 less(which means $$ for swaybar end links)...but i dont want to sacrifice quality for being cheap. My only reasoning is that the hr and tms have practically the same size bars, and description. Can anyone help please.
![]() DINAN:COLD AIR INTAKE, THROTTLE BODY, STAGE 3 CHIP, FREE FLOW EXHAUST,RESONATORS DELETED EE LED TAILS M3 LIP SPOILER 35% TINT DICE IPOD INTEGRATION DIY FRONT REFLECTORS UMNITZA ANGEL EYES BILSTEIN SPORT / H&R RACE SPRINGS ROGUE RSM's POWERFLEX FCAB CLEAR FRONT SIGNALS CLEAR SIDEMARKERS LED FRONT SIGNAL BULBS LED SIDEMARKERS |
#2 |
Banned User
My Ride: E46 330 and E30 325
That's because they are the same. Turner ones are just rebranded/repainted H&R swaybars.
#3 |
Yup. What he said.
#4 | |
K. |
#5 |
same thing different name.
#6 |
I concur.
![]() Sapphire Black MetallicNatural BrownSilver Cube e46 330i ZHP/ZCW/6MT - Sold HellrotDove Grey e36 ///M3 - RIP Alpine WhiteTanSand High Gloss e46 330i SunRoofLess/5MT For Sale: $300 winter wheel/tire set (sport edition F7s and Dunlop graspics) For Rent: RTAB Removal/Installation and Preload Tools |
#7 |
sounds like TMS got my vote...but i just dont understand how they have a much lower price than then H&R site...but what ever....im on my way to they highways of sways....as for sway bar endlinks, do i need front and rear, or just front?
#8 |
You need front and rear to balance the car - in my experience you should go with full stiff setting - but try different settings to find the one the suits you!
#9 | |
OP, I ran stock sway bar links and they worked fine for me. Some lowered cars have problems with the ball joint popping out. So unless you have a slammed car, you should be ok using the stock end links with the TMS bars on both the front and the rear. I used to run full stiff in the front and middle setting in the rear w/ 255/35/18's all around. You need to determine which setting to go with.
#10 |
well i have bilstein sports on hr race springs so i want to play it safe....i will en up getting the front and rear swaybar links...
#11 |
I'm having my TMS sways put in next week using stock front and rear links since i have stock suspension on my 330i. its crazy how a Strut Bar really tighten up my front end and I'm hoping these sways really makes a difference
once they are installed are the sways easy to adjust or is it pretty annoying everything u want to change the stiffness |
#12 | |
Pretty easy to adjust, one bolt each side, make sure you have 2 (not 1) 16mm crescent wrenches for the job.
#13 |
TMS at Bimmerfest 08 told me in person that they are the same bars as H&R
#14 |
Would you guys recommend the TMS sways as oppose to the UUC?
![]() ![]() Feeler - Like My Car? Make an Offer |
#15 | |
On an otherwise stock car, yes. TMS front/rear stiffness ratio is similar to stock, preserving balance.
#16 |
My car isn't stock but it isn't slam to the ground either. I'm trying to find sways to match up with my KW2s. I need something that is stiff and gives me the control I've been looking for.
#17 |
Get Hotchkis, Or H&R. Dont get UUC they make noise and squeke.
#18 |
Hmm, but like the above post states, isn't it cheaper just to get the TMS since they are just rebranded H&R?
#19 |
If its cheaper then get TMS.
#20 |
H&R and Turner Motorsport bars used to cost the same. But I guess business was doing so well for H&R that they just increased their pricing instead of increasing production numbers.
| Tags |
| suspension, sway bars, sways, tms |
