Old 05-18-2009, 02:54 PM   #1
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
For those of you with gearbox rattle after UUC install
The suggested fluid mixture works.
When I installed it a few months ago, it was cold outside, I didn't notice the rattle until I started using the AC within the last few weeks. I was using the suggested mix of 75W140NS and D4. It was fine when it was cool outside or my AC was off, but it was bothering me. This weekend I switched in the suggested "Hot Climate" mix. Nice and quiet. It's 1 bottle of 75W140NS plus as much MT-90 as you can fit in. My abused transmission has 115k on it and is quiet with the AC on after 2 hours of driving sitting in a Taco Bell drive-thru.
I'm satisfied. Definitely the best mod I've put on the car.
Old 05-18-2009, 02:56 PM   #2
Custom3
My Ride: HellRot 330CI
your setup is the UUC flywheel with M5 clutch?
Old 05-18-2009, 03:07 PM   #3
aggieE46
Keep it clean
aggieE46's Avatar
Yep
Old 05-18-2009, 03:07 PM   #4
JJR4884
My Ride: BMW
aggie i thought you were talking about the exhaust rattle that i just made a thread about lol
JJR4884 is offline   Reply With Quote
Old 05-18-2009, 03:20 PM   #5
ledfut
ledfut's Avatar
My Ride: '99 328i
What'd you get at taco bell? I could go for some.
ledfut is offline   Reply With Quote
Old 05-18-2009, 03:22 PM   #6
aggieE46
Keep it clean
aggieE46's Avatar
I haven't had drive-thru ANYTHING in months. Just Tacos.
Old 05-18-2009, 03:25 PM   #7
juvi925
My Ride: AW ZSP 325i
Send a message via AIM to juvi925
hey i have the exact same gearbox rattle. so if i switch to these transmission fluids the rattles will go away?? cuz since its getting warmer whenever i turn on my ac its really bad
[CENTER]
juvi925 is offline   Reply With Quote
Old 05-18-2009, 04:20 PM   #8
TxZHP04
My Ride: ESS TS2+ ZHP
Keep us updated on how you like the "hot climate" blend. I ran this exact blend last summer to see how I liked it in anticipation of getting a LW flywheel. After a couple of weeks, shift feel went downhill and shifting got really finicky. Switched back to my usual RP Synchromax and everything has been fine since. My bad experience with this particular fluid blend is largely responsible for me not wanting to switch to a LW flywheel. I never tried the "normal" D4 blend.
Old 05-18-2009, 08:10 PM   #9
aggieE46
Keep it clean
aggieE46's Avatar
Will do.
Old 05-21-2009, 01:06 AM   #10
AntB
My Ride: MTA :(
It will still rattle after a day of really hard driving when the car gets really hot.
** Tim330i waz hur **
AntB is offline   Reply With Quote
Old 05-24-2009, 06:51 PM   #11
juvi925
hey can someone tell me where can i get these fluids??? pm me if possible. thanks!
[CENTER]
Old 05-24-2009, 09:04 PM   #12
AntB
My Ride: MTA :(
UUC sells the fluids.
Old 06-17-2009, 04:39 PM   #13
JSanders
My Ride: Breaks too often
Originally Posted by aggieE46 View Post
Will do.
Its been almost a month, are the fluids still holding up?
JSanders is offline   Reply With Quote
Old 06-17-2009, 06:40 PM   #14
aggieE46
Keep it clean
aggieE46's Avatar
Well, it rattles, but not nearly as bad as before.
Old 06-17-2009, 10:04 PM   #15
i0kr1sol
My Ride: 330ci
can we install tranny fluid coolers in e46's ? does it even exist? lol.
just wondering.
i0kr1sol is offline   Reply With Quote
Old 06-18-2009, 12:27 PM   #16
JSanders
On autos they come stock, I've never heard of one on a manual e46 but I bet some track/high performance guy has done it.
Interesting idea.
Old 06-18-2009, 03:19 PM   #17
fmzip
My Ride: '08 328xi / '01 530i
The magic chatter proof mixture worked for me with the UUC organic clutch and JB racing flywheel......The same mixture didn't provide any relief from chatter with a JB racing Flywheel and Clutch Master FX300.
fmzip is offline   Reply With Quote
Old 06-18-2009, 03:31 PM   #18
JSanders
Well how heavy is the JB racing flywheel?
Old 06-18-2009, 05:03 PM   #19
fmzip
10 lbs
Old 07-07-2010, 09:18 PM   #20
jblack03zhp
My Ride: 330i zhp
Hows the mixture test holding up? And anyone find out more about the possibility of that transcooler for a manual trans. I installed one on my 01 chevy Z71 silverado, that was camed, tuned, pulleys, intake, shift kit, etc & I loved it.
& on a side note, aggie, the OE M5 clutch plate you used is from an e34 or e39? Thanks
UUC Stage II Aluminum Flywheel/Perfomance Organic__UUC Evo 3 SSK & DSSR__UUC Underdrive Pulleys__Magnaflow__H&R Sport Cupkit__TMS Rear Camber Arms
__And tooo much other stuff
Originally Posted by Penguin Koolaid View Post
The difference being men don't make excuses to rationalize why it's okay. We do as we please. No fucks will be given. You ma'am, give a fuck.
jblack03zhp is offline   Reply With Quote
