Sponsored by BAVSOUND
Old 05-19-2009, 03:36 AM   #1
nawti boy
My Ride: 325 ci
Question can i remove the amp ?
hi guys , not sure if this has been done-
can i remove my oem amp and replace it with an aftermarket one ?
i have oem navigation system - the amp is dead and i can't seem to find one
in my country -the new one is too expensive.
i also notice that my aerial plugs onto the amp.
is there any way to fit an aftermarket one ?
[C
nawti boy is offline   Reply With Quote
Old 05-19-2009, 04:17 AM   #2
meccanoble
My Ride: 03 Steel Gray M3
Send a message via AIM to meccanoble Send a message via Yahoo to meccanoble
yes you def can, but your HK system probably has like 12 speakers. You may need multiple amps to power all those speakers, unless you dont run all of them. But the HK speakers have like a funny ohm setup thats hard to setup with aftermarket amps. You may be better off swapping speakers as well. Thats what I plan to do. Regardless it can be done, I would just search a little and you can find write ups.
///M3CCANOBLE
03 Steel Grey 6MT :shiftdriv
Volks TE37| Eisenmann Race 83mm + section II| RE Rasp Pipe| Vogtland Springs| Kenwood KDC X994| Poly RTABS| many more...
meccanoble is offline   Reply With Quote
Old 05-19-2009, 08:22 AM   #3
ca1242
My Ride: 2003 330i
Amp does not have an aerial connection, are you sure you are not looking at the tuner?
Are you sure you have an amplifier?
If you do have an amplifier and want to replace it, you need to do speakers as well.
You need to troubleshoot to make sure the amp is bad. It could be a blown fuse, no turn-on wire, or it is not getting a signal upstream from the tuner.
