Bavarian Soundwerks' Mobile Electronics Forum
Have all your A/V and electronics questions answered here. Ipods, A/V, Radar Detectors Oh My! Sponsored by Bavarian Soundwerks |
#1 |
Stereo wiring
Could any of you pro's give me some advice of how to connect the power wire to the battery? also where is the best grounding point for no interferance. I also need to wire an invertor in?
Any help greatly appreciated. Thanks |
#2 |
yo mama
Cant you ground your amps to the ground terminal of the battery? thats what my stereo store did...
#3 | |
Depending on how many amps you are planning on installing (now and in the future) depends on how to connect to the battery. If you are only going to install one amp (in some cases 2 just split the wire in two not recomended) in the car, you can get a a ring and crimp it to a fused 4 gauge wire. and connect it directly to the possitive battery post. If you plan on installing 2 or more amps I would attach a 1 ga. wire to the battery and run it to a fused distribution block, and run a 4 ga. power wire to each amp from there. If you are talking about a high to low level converter, the instructions are pretty easy. Left speaker (+ to +) & (- to -) right speaker (+ to +) & (- to -). Good luck
1999 323i
18 inch Alba Bertha's BMW accessories 2dr. front bumper McIntosh MC427 McIntosh MC427 McIntosh MC425 /////Alpine PXA H600 (3) JL Audio 8w6's |
#4 | |
yo mama
Gound wires have to be short, but how short is short? (Yes I know as short as possible), but how short is that? Accross the trunk is bad? So maybe each amp should have its own ground? what about a ground dist block?
#5 |
I assume you're putting the amp in trunk, and if that's the case, there is at least one factory ground block on each side of the car on the fender walls, so regardless, it's not necessary to run the ground to the battery. Also, you want to ground the amp with the other components, so you don't have a ground loop.
Yes, the ground wire should be as short as possible, but that doesn't mean 6", but it also preferable to not run a 3-4' one to the other side of the car. Regarding connecting to the battery (+), and wiring in general, I find the amp install kits (e.g., Monster), helpful in providing all hardware necessary for a technically sound and clean-looking install.
Better picture coming!
