Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 22 votes, 5.00 average. Display Modes
Old 05-17-2012, 09:24 AM   #61
markusmarkus
My Ride: 2001 330Ci
Originally Posted by shellback View Post
If we use the parts express speakers that were listed above, and we later decide to by-pass or eliminate the factory amp, would we need to add a crossover?
Even better, can someone recommend amp and crossover set up that would benefit the set up?
My initial thoughts:
1) Six channel amp from JL Audio http://www.sonicelectronix.com/item_...o-XD600-6.html
2) Cross over from audio control (not sure what model/application)
Yes, you'll have to invest in crossovers. There are several websites with crossover calculators for 2-way and 3-way speaker systems.
Old 05-17-2012, 04:27 PM   #62
vids_blk323Ci
DFW
My Ride: JB 323Ci SP PP
Send a message via AIM to vids_blk323Ci
which pre-built crossovers have you guys used??? Im just looking to update the rear shelf speakers on my coupe, non-HK.
Dinan Stage I S/W | ACS RSB | ///M FSB |UUC TMEs & Pulleys |Ate Slotted Discs | ScanGuageII | RockyMounts MTB Carrrier | OEM Rear Clears | LED Euro City Lights & Rear Fogs | Two-Tone Suede DIY | ACS Pedals | Bimmian Gauge Rings & M3 Face | Smoked Frnt Corners w/ Luxeon LEDs | EAS CF Roundels | JLevi Ti CF trim | Blk Suede shift/ e-brake boots | ECS Smoked Frnt Bumper Reflectors | DICE Duo
vids_blk323Ci is offline   Reply With Quote
Old 05-17-2012, 04:33 PM   #63
markusmarkus
My Ride: 2001 330Ci
I bought a pair of 3-way xovers from www.marvin.com. They're powered by a JL 400/4 amp.
Old 04-30-2013, 10:52 AM   #64
halo0
My Ride: '02 330i 5mt
Originally Posted by Grande D View Post
You can also use this as a midrange:
http://www.parts-express.com/pe/show...number=264-807
You have to dremel the speaker flange, but it will slide and clip into the bracket. I have this, paired with this as a tweeter:
http://www.parts-express.com/pe/show...number=264-865
And this as a woofer:
http://www.parts-express.com/pe/show...number=295-372
It sounds amazing, all of the drivers listed get extremely high marks for the range they are used in for this system. I paired it with a sub and amp and it rivals some of my incredibly expensive home audio equipment. (Sonus Faber, etc.)
BSW: I have my on.
How is the fitment of the tweeter and woofer? Any cutting required? I replaced my midranges with the ones above last weekend and it was a great improvement from the blown HK's. Dremelling the speaker flange was no big deal but I'm concerned as to whether the door panel would need to be cut to get those woofers in there due to how the stock speaker mounting holes are on extended tabs. I haven't taken apart the tweeter pod to see how it mounts.
Also can you use those same woofers in the trunk?
^Click, stop by and say hi.^ ------ 5% off Redline leather
halo0 is offline   Reply With Quote
Old 05-06-2013, 03:50 PM   #65
Grande D
My Ride: E36 M3
The woofer is very tight on the sedan. You have to grind the plastic ring on the door panel down all the way. Then, within the plastic speaker adapter (purchased via eBay) you have to get the alignment just right so that the metal behind the speaker does not prevent one of the clips from clipping. I'd say the margin is 2mm at most.
The tweeter was ground down a pit in the edges so that I could wedge in it the stock foam retainer in the sedan tweeter sail panel. I don't remember if it's absolutely necessary to do so.
I tried some of the other midranges people have suggested from Parts Express and they just don't have that same, *magic* sound as the one I suggest. That and the tweeter are crucial to the sound. The woofer is not as necessary for the best sound. You might look into something that would fit with less effort instead. The woofer is good- but not worth the effort and headache to install it imo.
GL
It will change your life!
Old 05-06-2013, 04:04 PM   #66
halo0
I really like the midranges too. I checked my woofers and the foam surrounds appear to be in good shape, so combined with the info you just gave me I think I might just throw my 10" JL in the trunk and call it a day on bass. Oh and I'll probably do those tweeters too.
Thanks!
Old 09-09-2013, 08:55 PM   #67
Cheechman7
My Ride: 2003 325xi
For those who used an aftermarket, what was your approach to connecting the wires?
A. Detach the male terminals on the new speaker and re-solder to align/fit with the stock wire clip/harness?
B. Cut the in door wire and replace/re-solder new female terminals large enough to fit the speaker size?
C. Other?
I have a 325xi, replacing with these: http://www.parts-express.com/pe/show...number=295-372.
Suppose Ill have to either build a mount or chop up some of the door inner plastic to fit it.
Cheechman7 is offline   Reply With Quote
Old 11-16-2016, 09:54 AM   #68
kidrobot_
My Ride: 2003 M3, 2001 330i
Sorry to bump, but the recommended TB 1" 25-1719S tweeters are no longer available. Any speaker gurus that can source an alternative?
kidrobot_ is offline   Reply With Quote
