Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 4.86 average. Display Modes
Old 09-04-2009, 01:10 PM   #41
plaroud
My Ride: 2003 m3
Does anyone know the torque specs for the middle carrier bolt and the 3 18mm bolts that hold the rear trailing arm in place?
Also, what would happen if you use regular silver anticeize and also what would happen when you use oem rtab's and you pre-load?
2003 M3
Scorpion Exhaust
K&N Cold air intake
Denso Irridium Sparks
H&R Sport springs
plaroud is offline   Reply With Quote
Old 09-07-2009, 02:29 PM   #42
plaroud
My Ride: 2003 m3
Bump, anyone?
2003 M3
Scorpion Exhaust
K&N Cold air intake
H&R Sport springs
Old 09-14-2009, 10:54 PM   #43
Luky
My Ride: '08 335i RIP'03 330i
Originally Posted by plaroud View Post
Bump, anyone?
Try using search...
http://forum.e46fanatics.com/showthread.php?t=693108
Luky is offline   Reply With Quote
Old 10-02-2009, 10:26 AM   #44
Arsevader
My Ride: '90 325i, '02 325it
Just want to make a point about 'preloading'.
People have it backwards. If you tighten things up before lowering the car then that is preloading, not the other way around.
You are 'preloading' the bushing before actual load is placed on it, which is a common mistake when installing OEM CAB. If you tighten the bracket to the underside of the car before actually placing 'load' on them this will lead to premature failure as the bushing will be under constant stress once the weight of the car is placed on them. Therefore you do not want to preload OEM bushings.
The poly bushings don't care as pointed out because they cannot be 'preloaded'.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Arsevader is offline   Reply With Quote
Old 10-02-2009, 12:53 PM   #45
plaroud
My Ride: 2003 m3
Originally Posted by Luky View Post
Uhhh, I did, that is how I came to this thread. I guess I missed the thread you made. But thanks anyway.
2003 M3
Scorpion Exhaust
K&N Cold air intake
H&R Sport springs
Old 10-02-2009, 01:07 PM   #46
Custom3
My Ride: HellRot 330CI
great this whole preload crap is confusing me now...i want to upgrade to oem M3 RTAB on my 330CI.....so do you guys mean that the 3 bracket bolts should be tighten with the car on the ground and not supported by jacks?...i cant see how the thru bolt can be tighten once the car is on the ground...someone clear this up for me.
Old 10-05-2009, 11:14 AM   #47
NikolaiD
My Ride: 2002 M3C
Send a message via AIM to NikolaiD Send a message via MSN to NikolaiD Send a message via Yahoo to NikolaiD
The pre-loading uses a special BMW tool, but if you use powerflex or RE bushings, there's no pre-loading. That only applies to OEM bushings.
Edit:
Here's the tool:
_______________________________________
My Ride: 2002 M3C
NikolaiD is offline   Reply With Quote
Old 10-05-2009, 12:00 PM   #48
Custom3
crap...looks like i have no choice but to get powerflex bushing....i would rather go OEM since i heard some bad reviews on the powerflex bushings
Edit:
Here's the tool:
Old 10-05-2009, 12:55 PM   #49
TxZHP04
My Ride: ESS TS2+ ZHP
You seem to be a bit confused yourself. The 3 bracket to body bolts have nothing to do with preloading the bushing. The bushing through-bolt is the only bolt of significance in this regard but unfortunately, due to the fact that it is recessed in a pocket and covered by the bracket, it can't be tightened after the car has been lowered onto the suspension.
In order to keep from pre-loading the bushing, the through-bolt must be tightened while the bracket is oriented at a specific angle relative to the trailing arm (the same angle that the bracket makes relative to the TA when the car is resting on the suspenion). Then, when you bolt the bracket back up to the body, you will notice that in order to get the bracket to sit flush against the body you must apply enough force to twist the bushing. The bushing is now pre-loaded while the suspension is at full droop with the wheels dangling in the air. If you installed the bracket at the correct angle though, the load on the bushing will be relieved when you lower the car back to the ground and the bracket to TA angle is returned to its static resting value.
Old 10-05-2009, 01:00 PM   #50
TxZHP04
You can make your own tool, the Bentley manual gives the specs that need to be met. It's really not that difficult to get the correct bracket angle when torquing the bushing through-bolt.
Old 10-05-2009, 01:15 PM   #51
thomasthethird
My Ride: is sittin' sideways
I just did my suspension last week and bought the RTAB tool for the bushings. Well worth the money! Took hardly any time at all to pull the bushings. I have mine and will sell it to you if you want. I paid $100, if you want it, send me a PM.
I know this isn't the place to sell stuff, but I thought it was appropriate because if you're reading this, you're probably about to do it.
thomasthethird is offline   Reply With Quote
Old 10-05-2009, 01:26 PM   #52
NikolaiD
My Ride: 2002 M3C
I got Rogue Engineering (the softer type, not the race) and have been more than satisfied with them, no special tools needed and were very easy to install.
My Ride: 2002 M3C
Old 10-15-2009, 09:56 PM   #53
gfeiner
My Ride: 2003 330i
TxZHP04 is correct. The bentley manual confirms it. I have attached what the bentley manual (3-series 99-05) says about preloading the trailing arm.
gfeiner is offline   Reply With Quote
Old 10-15-2009, 10:11 PM   #54
gfeiner
My Ride: 2003 330i
And here is the BMW TIS document that talks about how the trailing arm bushing housing needs to be preloaded with the special tool
Old 10-16-2009, 07:49 AM   #55
Arsevader
I'm not confused. I wasn't talking about the specific procedure for RTABs. I was responding to the comment that you should preload all bushings for BMWs.
The RTAB is the only bushing that I know of that you need to preload.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Old 10-16-2009, 08:17 AM   #56
Spiritwalker42
My Ride: '02 M3 Coupe
I just got some Meyle HD rtabs and Vorshlag limiters...
Anyone know if I should be concerned with the preload? The rtab sure resembles an oem closely. I have the newer style with the split casing and it doesn't flange out on one side..
Any input appreciated, Ken
*Sharked*AA Headers*CRT RT/Cats*ESR Ti Tip Exhaust*AFE Stg II CAI*Lighting*Enco-B146:Nav:Blu:Magic Box*PSS10s*Rogue*SPC*VMR V710s/Potenzas*Carbon*
Spiritwalker42 is offline   Reply With Quote
Old 10-16-2009, 03:27 PM   #57
fmzip
My Ride: '08 328xi / '01 530i
My 5 series requires pre-loading on one of the front control arm bushings as well. PITA as far as I am concerned.
A simple flat bar of steel will do the trick as pointed out below in the Bentley manual:
fmzip is offline   Reply With Quote
Old 10-16-2009, 03:45 PM   #58
TxZHP04
Yes. Follow the instructions in the TIS attached in post 54 above. For the proper pre-load, see the section regarding installation without the special tool.
Old 10-27-2009, 10:59 AM   #59
LABMW13
My Ride: M3, 330i, '89 325i
Thanks this DIY helped me a lot....Bimmerworld.com has the same tool to rent
M3: SSR GT3 Wheels, H&R Coilovers, JL 12" W6, Eisenmann 83mm, SS Headers, 4.10's, CF CSL Trunk & Diffuser, Euro Front Bumper, Hamann CF front lip, 3000k Fogs, NX 125 Shot
UUC Parts: SSBC Brakes, Lines, Sway bars, 8LB Flywheel, twin disc clutch, Evo 3 Shifter, RK7A Shift Knob, CF E-brake, Rasp-X Mid Pipes
Coming Soon: VRS Vented Race Hood & VCSL CF Roof Panel
LABMW13 is offline   Reply With Quote
Old 10-27-2009, 06:05 PM   #60
fmzip
Glad it helped!
