Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 4.86 average. Display Modes
Old 12-16-2009, 12:07 PM   #61
AtotheJ
My Ride: E46/E90/R53
Originally Posted by fmzip View Post
12) Take the RTAB's and install them in the trailing arm. Apply antiseize to the barrel and push the barrel through both bushings. You may need to tap it with a hammer to get the barrel through
GREAT write-up...I have one question though - RE: the PowerFlex RTABs - did you need the RTAB tool to install them - or since it's 2 pieces (unlike OEM which is a whole unit), can you simply push them in by hand?
Thanks!
"Do or do not..there is no try.." Yoda
AtotheJ is offline   Reply With Quote
Old 12-17-2009, 02:45 PM   #62
Luky
My Ride: '08 335i RIP'03 330i
No, you do not need the RTAB tool to install the powerflex RTABs, only to remove the old bushings.
I did find using a couple of small C clamps helped for pushing the center barrel in and compressing the two urethane bushing halves together.
I have an RTAB tool for rent if you're interested...
Luky
Luky is offline   Reply With Quote
Old 12-17-2009, 03:06 PM   #63
AtotheJ
Luky
Thanks Luky!
I see yer in SD also. I'm actually going to try and pry the OEM RTABs out another way (there many DIYs here using alternative methods). If these fail, I'll definitely hit you up for your tool!
Thanks,
AJ
Old 12-21-2009, 02:40 AM   #64
rrboy
My Ride: 2005 m3 convertible
not trying in anyway to take from a great thread...but i just replaced my rtabs and found using a whole saw bit..2 inches...worked great..just sawed out the rubber and then the aluminum race came right out. for those that dont have the puller. i put the power flex brand in..and you can just press them in..not much force is needed..or just love tap with a rubber malett.
rrboy is offline   Reply With Quote
Old 12-21-2009, 06:13 PM   #65
fmzip
My Ride: '08 328xi / '01 530i
^^^^Nice!
fmzip is offline   Reply With Quote
Old 01-10-2010, 03:59 AM   #66
gtchong
My Ride: E46 M3
man, i'm pretty strong but using my own strength to put up the control arm into place was a no go. great write up and the tool was easy to get the only hard part was getting the passenger side wheel off the hub. it just wouldn't come off what a pain. the only difference is i used marine based grease.
thanks i appreciate it
gtchong is offline   Reply With Quote
Old 01-10-2010, 10:51 AM   #67
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Good info. I'll refer to this when I rip out my squeaky UUC RTABs and install some M3 RTABs w/limiters.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 01-16-2010, 09:53 AM   #68
Silver325
My Ride: 2002 325i
This is a great DIY! I am getting ready to remove my UUC RTAB's, I am tired of dropping the arms and re-greasing them to get rid of the squeeks. I have new M3 RTAB's and this issue of pre-loading is key. Please take a look at the figure from above I modified. Is the top of the bearing hub and the top of the carrier alignment tool in the same plane? It looks like it is in the pic and in the pdf posted above. If so, I think I can devise a method to get this lined up properly. Anyone know for sure?
[IMG]Photobucket[/IMG]
Meyle control arms, M3 RTAB's, Bridgstone Potenza RE760
Silver325 is offline   Reply With Quote
Old 01-16-2010, 10:56 AM   #69
fmzip
I don' have the tool but it doesn't appear to be flat from the top of the bearing hub. If my memory serves me correctly, you are shooting for the "center" of the hub to align itself in a straight line to the carrier
Old 01-16-2010, 12:56 PM   #70
Silver325
My Ride: 2002 325i
OK, cool. That seems to coincide with the pdf on this after looking at it again. Makes it a bit more of a challenge to get it lined up right though. Thanks!
Old 01-31-2010, 07:38 PM   #71
muniz_ri
My Ride: 2004 325i
LOL: Great idea!
muniz_ri is offline   Reply With Quote
Old 03-19-2010, 11:06 AM   #72
SoCalBuff
My Ride: 2003 330i ZHP
Other control arms
Is this bushing the controlling item in the rear suspension for alignment? I have 120k miles on my car and am looking at refreshing the suspension. Have people replaced the busing on the aft end of hte RTA or the bushings on the upper or lower control arms? Would replacing these other bushings be worth the effort and do they have any impact on the alignment?
Thanks in advance.
___________________________________________
Stock, but for how long???
SoCalBuff is offline   Reply With Quote
Old 03-19-2010, 01:46 PM   #73
jbfrancis3
Formerly Snox400
My Ride: 1999 323i
It affects the rear alignment a noticeable amount, specifically the toe.
I just changed my RTABs and before an alignment, the measurements came in at .22 and -.01, after having been within spec prior to bushing replacement.
Stock spec is between .08 and .18 FYI
I would recommend and alignment contrary to if others claim they've been 'just fine' without one
jbfrancis3
jbfrancis3 is offline   Reply With Quote
Old 03-23-2010, 12:51 PM   #74
m3collins
My Ride: 2002 Carbon Black M3
I just took my new to me E46 M3 to the stealership for an alignment and they told me they couldn't do it due to worn rear wishbone bushings and front control bushings. Is that what you guys call the RTAB's and FCAB's?
They wanted $1300 to replace all of and I almost fainted.....think I'm gonna do it myself as I'm very mechanically inclined (used to build Subaru STi's and DSM's but this is my first BMW).
So questions are:
1) Is the RTAB and FCAB what the dealer is telling me about
2) what poly brand is the best for comfort and reliability....DON'T want OEM
3) Are there any other bushings that affect alignment other than RTAB and FCAB?
Thanks guys.
m3collins is offline   Reply With Quote
Old 03-23-2010, 03:16 PM   #75
Albobmw
My Ride: 01 bmw 325i
So questions are:
Thanks guys.
RTAB = rear trailing arm bushing
FCAB = front control arm bushing
OE is the best imo for comfort and some spirited drive, if not, then buy the Meyle bushings. Anything else will be stiffer.
3)The only bushings which affect alignment are the RTAB and FCAB.
Albobmw is offline   Reply With Quote
Old 03-23-2010, 04:11 PM   #76
m3collins
Thanks. Also found out one of my rear control arms is slightly bent. Sigh.....
Old 03-23-2010, 07:17 PM   #77
fmzip
Get yourself some adjustable rear control arms while you are it.......see my other write up
Old 03-23-2010, 09:27 PM   #78
m3collins
Thanks I will look at that. Man today is just horrible.....find out my bushings are worn, my rear control arm is bent and then on the way home the battery light pops on......dead alternator. Grrrrrrrrrrrrrrrrrrrrr.
Old 03-23-2010, 09:34 PM   #79
fmzip
bummer man....sometimes, when it rains it pours !
Old 03-24-2010, 07:24 PM   #80
Luky
So questions are:
Thanks guys.
Powerflex PU RTABs and FCABs. Just make sure you lube up the PU contact areas where they rub so they don't squeak. Also you may want to replace your front control arms when replacing the FCABs. It is really a pretty simple job to do both of these (especially if you have a RTAB tool) and buy the FCABs in new housings (lollypops) ready to bolt up.
