Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > NY / NJ / CT
NY / NJ / CT
NY NJ CT
Old 05-27-2009, 01:01 AM   #1
indraneelis
My Ride: 2003 330i ZSP
Engine rattling . Help wanted.
Hi ,
I recently started hearing slight rattling / gurgling from my engine.
Showed it to an indy sho p - who said it might be the valves.
Uopn reading some posts here - it sounds like the vanos issue.
Can someone who is familiar with the VANOs issue help me identifying if the noise i have is indeed the vanos ?
Is there someone local who is willing to help ?
indraneelis is offline   Reply With Quote
Old 05-27-2009, 08:45 AM   #2
George325i
My Ride: 03 BMW 325i
Do you hear the rattle at idle a lot? If you are near Atlantic City I can ask my friend or who certified BMW tech to look at it for you.
George325i is offline   Reply With Quote
Old 05-27-2009, 06:32 PM   #3
indraneelis
I hear the rattle above 3000 rpm esp getting out of 1st, 2nd gear.
I did the vanos test - recommended by rajaie - Go up an incline - 3rd gear 1500 rpm and floor it. car moved along just fine.
Now I'm thinking it is not a vanos issue. Does anyone have any ideas ?
Old 05-27-2009, 06:37 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
What happens if you do have a vanos issue going up a hill doing that? I might try it out
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 05-27-2009, 11:06 PM   #5
indraneelis
If you have a vanos issue - the car should stall / sputter. If it takes off with ample power - then it maynot be a VANOS issue
Posted originalli by rajaie - search VANOS -
Old 05-28-2009, 12:17 PM   #6
indraneelis
bump - No one in NY / NJ can help a fellow member - or recommend a good indy mechanic ?
Old 05-28-2009, 12:28 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
Search this forum for Autobot325i
Old 08-07-2009, 08:40 PM   #8
indraneelis
VANOS / engine rattling / DISA - solved.
SOLIDJAKE - YOU RULE !!!!!! I BOW TO YOU.
I have been researching this issue for about 3 months now, and the sound was driving me nuts.
I finally tok it to the really cool fellas at Denville BMW. - The tech told me it may be the DISA valve rattling.
I looked at your post on youtube to replace DISA valve. I now hold in my hand the completely broken DISA valve.
Unlike in your video - my valve is completely broken, and the flap turns a full 180 degrees.
Thanks a ton dude!!!
Tomorrow am I'm off to the dealership to get a new valve and hopefully the rattling will ceaze.
I decided to post back for a fellow enthusiast who may be having the same issue.
Indy
2k-3k, disa, grinding, rattling, vanos
