Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 1.00 average. Display Modes
Old 05-27-2009, 05:30 PM   #1
RACEMX-M3
My Ride: M3
DIY: Disabling the SES light
This is a 15 - 20 minute max project.
If there's gauges on your steering column you are going to need to adjust them as far forward as possible to allow room for the instrument cluster to come out.
Lower your steering wheel all the way and pull it out as far as it will go and relock it in place. Place a towel on top of your steering column to prevent scratching the front of the instrument cluster.
Remove the two torx 20 screws at the top of the cluster
Pull out gently and the cluster will rotate forward
Remove the banana shaped plastic piece from the cluster by pressing down on the tabs on each side and pulling forward
Pull the cluster forward and rest it face down on the steering column
Remove the two wiring harnesses from the back of the cluster as illustrated
Once the connections are free slide the cluster out carefully
Lay the cluster face down on a soft towel and remove the 4 torx 10 screws
Once the screws are out the gray cover will lift right off
Remove the two small knobs from the front of the cluster, they will pull right off with little effort
Turn the cluster face down again and gently lift internal circuit board out of the cover and lay it back down facing up. Remove the black cover by sliding a small flat screwdriver or something similar under the cover and gently lifting at the two points illustrated until it comes off
The led that we are going to block is circled
Cut a small piece of dense black foam that is slightly larger than the hole with the led and stuff it in making sure it is a nice snugg fit so that no light will seep through.
Put everything back the way it came out and you are finished.
RACEMX-M3 is offline   Reply With Quote
Old 05-27-2009, 09:58 PM   #2
Estoril-E46
My Ride: M3
Called that one.
The quick but slow car:
www.Precision-Sport.com
Estoril-E46 is offline   Reply With Quote
Old 05-27-2009, 10:12 PM   #3
MrMotorwerk
Der Meisterstück
MrMotorwerk's Avatar
My Ride: '02 330Ci,'01 M3,M4
there's an easier way to disable the SES light.
STAY ON TOP OF YOUR CAR MAINTENANCE.
MrMotorwerk is offline   Reply With Quote
Old 05-27-2009, 10:16 PM   #4
BimmerDude18
My Ride: 1998 528i
Yes, because thats why HPF cars have an SES light.
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 05-27-2009, 10:18 PM   #5
frankieb96
My Ride: 2004 M3
RAC | Brembo | HPF | TC Kline | www.precision-sport.com
frankieb96 is offline   Reply With Quote
Old 05-27-2009, 10:30 PM   #6
funkboy316
My Ride: 2003 M3 vert
You sir, are a genius, I can not believe nobody thought of that!
2003 TiAg HPF stage 2.5 SMG M3 vert
funkboy316 is offline   Reply With Quote
Old 05-27-2009, 10:34 PM   #7
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I just use electrical tape...probably easier to find than black foam. Nonetheless, the black foam looks better and is probably cleaner.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 05-27-2009, 10:51 PM   #8
RACEMX-M3
My Ride: M3
I'm sure either works fine.. the foam was just the first thing I saw that worked.
Old 05-27-2009, 11:19 PM   #9
HPFMTRE
My Ride: ESS VT3 E92 M3
Photobucket
Pictures of my car
http://www.cardomain.com/ride/2927228
Originally Posted by BeRzErKaS View Post
wat?? guys with turbo M3's don't have woman troubles...
try adjusting your wastegate
HPF Stage 3 #001
New ride- ESS VT3 E92 M3
HPFMTRE is offline   Reply With Quote
Old 05-30-2009, 04:26 AM   #10
//Mpower23
My Ride: 06 Titan, 04 ZHP
^^^^^^^^ditto
//Mpower23 is offline   Reply With Quote
Old 06-01-2009, 11:45 AM   #11
///Flash
Banned
My Ride: a donkey
what is causing the SES? no cats?
///Flash is offline   Reply With Quote
Old 06-01-2009, 01:38 PM   #12
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
The NickG kit, as it uses the factory DME leaves my car with the SES off, however, due to my car's abused past, when turning the car on, the "dsc", "brake" and "abs" light all come on. I should do this treatment to those, lol
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 12-04-2009, 08:24 PM   #13
BMW_Matt
My Ride: 135
Sorry to bump an old thread, however what does cause the SES light to come on in the HPF? No cats or what?
BMW_Matt is offline   Reply With Quote
Old 12-04-2009, 08:48 PM   #14
M3PTGSC
My Ride: M3
From another thread
Originally Posted by HPF Chris View Post
Of course. We control both the intake and exhaust cam and have programmed them in a table that allows us +/- 20 degrees based on both rpm and boost. It is truly remarkable how much power you can pick up by advancing/retarding the cams based on rpm and boost. That's the main reason our kits have virtually no turbo lag, it's because we've set the cams for the maximum power at lower rpms as well as tuned the cams for the maximum performance across the entire powerband.
JP (our engineer) told me back in 2006 that we have a choice, either leave the cams at their factory settings and "not" have the service engine soon light come on, or we can pick up 30-40rwhp at several points in the powerband by moving the cams to optimize the M3's performance. I asked why can't we do both. He said because the DME looks at the camshaft position sensors and determines that the camshafts are not within the range set from the factory. So I chose to have more power and leave the SES light on. If we tuned the DME, we could possibly change those limits to allow our settings and not have the SES light come on, but we really haven't spent (or wasted) any time with DME tuning on that car since the factory computer doesn't run the engine. You can't even see the SES light with our kit anyway.
Chris.
09 SL63 AMG Designo,pano and whole nine yards lol
07 S550 P2 4matic-gone
03-M3-6766 DBB..Tubular manifold...
97-M3-
95-M3 SC stage 2-Widebody...
08 Gix 1k 08 ZX10R
M3PTGSC is offline   Reply With Quote
Old 12-04-2009, 09:01 PM   #15
BMW_Matt
My Ride: 135
Gotcha, thanks.
Old 12-04-2009, 09:48 PM   #16
Evil Twin Rob
My Ride: 2004 M3
Lol welcome to the F/I section.
HPF 2.5
Evil Twin Rob is offline   Reply With Quote
Old 12-04-2009, 09:48 PM   #17
BMW_Matt
My Ride: 135
One would think if you spend $20k+ alone on a turbo system, not including other mods, they could afford simple maintenance
Old 12-04-2009, 11:12 PM   #18
TitanSilber ZHP
TitanSilber ZHP's Avatar
My Ride: 08 E90 335i
Send a message via AIM to TitanSilber ZHP Send a message via Yahoo to TitanSilber ZHP
Its not about maintenance.
| Andrew | M Technik | BMW Performance | 3M | V1 | LUX 5.0 | Bilstein PSS9 | Precision-Sport |
FS: Camera Mount:http://forum.e46fanatics.com/showthread.php?t=694858
TitanSilber ZHP is offline   Reply With Quote
Old 12-04-2009, 11:50 PM   #19
FTWeisse
My Ride: has no hip-hop rimz
This fuckin' guy.
Old 12-04-2009, 11:57 PM   #20
BMW_Matt
My Ride: 135
I know. I was mocking the guy who said that.
