Last Little Touches! HELP ME OUT! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-28-2009, 06:31 AM   #1
goblinsplace
My Ride: 330i ZHP
All regarding my 2000 323i
1 - My hood doesn't close flush. The rubber riser things are ALL the way down. Had to use a plyer to get them low. Helped 80% but need more. I did that with the Air box stuff out. BUT when i put it back, its up a little again.
Its enough where the lever to unlatch the hood sticks out. Any ideas????
-yes the hood has been repainted, so someone screwed something up
2- see pic! What do i do? This pealing of cloth is happening around the car in a few places. DAMN Arizona is TOO HOT! Please let me know the exact type of resin, glue or whatever i need..... I wanna do it right! Its also doing it on the front windshield airbag cloth a little.
3 - I changed the CCV (crank case vent valve) and didnt change the intake boots. Some say they can crack.. I pulled at them pretty hard.. I cant tell. Sprayed mist when car was on, cant tell is there is air moving cuz of electric fan blowing the mist. So that idea didnt work.... Any ideas? Should i just change them?
4 - Where in the trunk exactly is the CD Changer prewire chilling? Its a 2000 323i.
5- NAME THAT SCREW! Found a 7/16 or 12mm nut under my car. Its a shared spot. I just did a lot of work. Can we rule it out? I don't remember any 12's under there when i was doing the Guibo/drop exhaust... Can anyone confirm?
Also found another. I'm sure its from my car - this fall of the heat shield?
6 - Windshield sprayer... Didnt work for years. Cleaned it out, CLRed the pump/motor. 1st try sprayed me in the face... Now, just dribbles. Any ideas? Bad motor? Are they working or dead? Or do they get weak
7 - Paint - (Will add photo) Driver front fender is repainted. Now the top layer is chipping off, and under is the same color. I hate it. Don't want to drop 400 on a repaint for a fender. What can i do to stop the chips or fix?
ID:	316920   Click image for larger version
ID:	316921   Click image for larger version
ID:	316922   Click image for larger version
ID:	316924   Click image for larger version
goblinsplace is offline   Reply With Quote
carpet, ccv, hood, intake boot, paint
