Old 05-29-2009, 11:12 AM   #1
eamc420
My Ride: 05 325i
Question help taking off lower radiator hose
how do we take off the lower radiator hose? mine has a small leak and i need to replace it i bought a new lower radiator hose and temp sensor thnx in advance
eamc420 is offline   Reply With Quote
Old 05-29-2009, 02:56 PM   #2
K:^P
My Ride: 00 323//65 Fastback
yeah, it's a b!tch to work on. It's pretty straight forward except the hose is stuck and the tight space to work on.
The hard part for me are:
1. Trying to disconnect the hose from the radiator.
2. Putting back the hose to the thermostat.
If I would do it again, I would remove fan shroud to remove the thermostat housing to get to disconnect hose.
Then have patient to remove the lower part. I used screwdrivers wedge it out(I don't know if it's easier to try to cut the connect without damaging the radiator part).
Connect the new hose with the thermostat, put back the thermostat then the connect the radiator part. Finally, put back the shroud, sensor, wiring etc...
Maybe others have a better method then mine...
K:^P is offline   Reply With Quote
Old 05-29-2009, 04:21 PM   #3
kent330i
My Ride: 2005 330i ZHP
Send a message via AIM to kent330i
Put some WD40 around the hose connectors; it helps during the remove.
kent330i is offline   Reply With Quote
Old 05-31-2009, 12:45 AM   #4
eamc420
My Ride: 05 325i
anyone else ?
Old 06-01-2009, 11:40 AM   #5
eamc420
My Ride: 05 325i
Old 06-02-2009, 11:37 PM   #6
DBear
My Ride: 2001 325i w/SportsPk
I recently replaced my thermostat and hoses and the lower hose definitely gave me the most problems. After a few hours of struggling to no avail i finally broke out the Dremel tool and very very carefully ground away at the hose coupling until I removed enough material so that I could insert a big blade screwdriver in the slot. I then twisted it and was able to crack the hose coupling away from the radiator. Not something i would recommend doing but i was kinda outta ideas outside of removing the radiator.
DBear is offline   Reply With Quote
Old 06-03-2009, 02:07 AM   #7
paraklas
My Ride: ESS TS2 320ci
WD-40 makes wonders. just let it soak for a while before removing
Old 06-03-2009, 02:11 AM   #8
GTUnit
My Ride: short bus
Send a message via AIM to GTUnit
Radiator hoses are a *****.
TWIST the hose first. Don't just try to pull it off.
You twist it to break the "bond" or "seal". Once its broken loose it is much easier to pull back and off.
Twist from side to side (shimmy) while pulling back to get it off after.
GTUnit is offline   Reply With Quote
