Sponsored by BAVSOUND
Old 06-03-2009, 11:11 AM   #1
danielkspencer
My Ride: 2006 Mustang GT
Aux Input ?'s on 03 330i with MKIV Nav
I want to install an Aux Input on my Bimmer with MKIV Nav. I've heard different things.
Does it attach to the front head unit or to the Brain in the Trunk????
Will I have to Disconnect power to the system to install it????
If so does the system have to be reprogrammed???
Basically Can I DIY it easily????
2006 Mustang GT Black on Black Leather- Lots of friggin TORQUE!!!!!!!
danielkspencer is offline   Reply With Quote
Old 06-03-2009, 10:06 PM   #2
profM3
My Ride: 2005 M3 ZCP
http://www.europeanautosource.com/pr...roducts_id=294
I believe it plugs into the back of the head unit. You will need to pull the head unit out, it's a bit tricky, you can get a special tool to help:
http://www.europeanautosource.com/pr...roducts_id=392
You should confirm with EAS for your car.
2005 M3 Silbergrau Metallic on black; 6MT, ZCP, ZPP, ZCW, Nav, Dinan exhaust, two AR20 resonators in section 1, Autosolutions SSK, Fucy CSL diffuser, Intravee II, illuminated ZHP shift knob, stealth V1 install with ash tray remote, OEM first aid boxes under both seats, Ultimate pedals and more...
profM3 is offline   Reply With Quote
Old 06-03-2009, 11:23 PM   #3
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
You'll need to be 2003.5 or later build to be compatible for AUX if equipped with NAV. AUX input is located behind the factory NAV screen.
tom @ eas is offline   Reply With Quote
Old 06-04-2009, 07:20 AM   #4
sna77
sna77's Avatar
My Ride: BMW
if yours doesn't support it, you can easily upgrade the radio to support AUX, and Sirius:
http://cgi.ebay.com/BMW-BM53-GPS-Nav...3%3A1|294%3A50
BTW, don't pay that much. Go to www.car-part.com and search for a BMW radio from an e46 or X3 from 2005 - present (with Nav of course). You can probably grab one for under $100. Its a 5 minute swap to the new radio. All the radio part #'s are here:
http://forum.e46fanatics.com/showthread.php?t=665464
sna77 is offline   Reply With Quote
Old 06-04-2009, 11:59 AM   #5
danielkspencer
Ok, mine says 03/03 on the door sticker. . . Am I out of Luck???????
Old 06-04-2009, 03:12 PM   #6
profM3
Close call, 03/03 is right at 2003.5, probably could be either way.
Old 06-04-2009, 03:15 PM   #7
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Check your radio version:
1. Turn on engine (or key to position II)
2. Push and hold the SELECT button for about 5-10 seconds. The serial number will show,
3. Press the > button on the NAV screen to display the software version of the radio
You will need to be SV80 or higher to be compatible for AUX.
Old 06-04-2009, 06:57 PM   #8
sna77
sna77's Avatar
My Ride: BMW
how do you do tell the version number? Mine says:
"Software Version 03-06 48"
Old 06-04-2009, 07:48 PM   #9
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
48 is your software version, meaning it is not compatible with AUX.
Old 06-04-2009, 09:38 PM   #10
sna77
sna77's Avatar
My Ride: BMW
That's odd... My BM53 radio is part # 65126988275, which is the 2nd newest radio listed on realoem:
http://www.realoem.com/bmw/showparts...65&fg=05&hl=83
Its stamped with date 24/07, which is the 27th week of 2007 if I'm not mistaken... Also I have Aux (working) in my car now... Could they have changed something with the software version numbers on the newer BM53 radios?
BM53 radio module part #'s:
65128374293
65126902719
65126902718
65126904214
65126919081
65126922513
65106933090
65126927911
65126943450
65126964399
65126972665
65126976962
65126988275
65126988276
Old 06-04-2009, 10:09 PM   #11
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Good question, it could be a remanufactured radio.
Old 06-04-2009, 10:14 PM   #12
sna77
sna77's Avatar
My Ride: BMW
Good question, it could be a manufactured radio.
You mean a re-manufactured unit?
My radio came out of an 05 M3 (I retrofit OEM Nav into my 04), and its stamped as 07, which leads me to believe that it was replaced under warranty for the previous owner...
That being the case--how could it support AUX then with the older software? Are there other determining factors besides the software version? hmmmm
Old 06-04-2009, 10:27 PM   #13
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Correct, remanufactured. Build date and software version are determining factors.
Old 06-04-2009, 10:32 PM   #14
sna77
sna77's Avatar
My Ride: BMW
Interesting... -275 # is not listed in the ETK as being remanufactured, and the -276 is. odd.
Apparently there are hardware changes in the newer units... Not sure why they wouldn't update the radio software as part of the remanufacturing process...
Tom, what is the latest software version you have seen? Besides support for Aux and Sirius, are there other discernible differences?
Old 06-05-2009, 02:29 AM   #15
danielkspencer
Interesting. . . . .
So when I update my software via my new DVD I just got in the mail today from BMW (thanks for the tip SNA77) Will it make mine ok to use Aux???? And I don't get it, shouldn't SNA's radio, being that new, have a way newer Software Version??????
Old 06-05-2009, 06:47 AM   #16
sna77
sna77's Avatar
My Ride: BMW
thats just the Nav software... radio software is not upgradable, and is hard coded to bm53 module.
what radio software did you have?
After Nav update you should be at 4/100 (latest Nav software)
Old 06-05-2009, 12:13 PM   #17
danielkspencer
I can't get my version to show up. nothing happens when I hold the select button for 5-10 or even 20????
Old 06-05-2009, 12:14 PM   #18
sna77
sna77's Avatar
My Ride: BMW
Turn radio off (leave monitor on)
Turn car off
wait 30 secods
Turn car to position 2
hold select
use < and > arrows to scroll to s/w version
I forget if I had the radio off totally or on the FM input. One of them worked...
Old 06-05-2009, 02:55 PM   #19
danielkspencer
Ok, mine says 28-02 81
I actually had to have my radio on with a CD playing to get it to work. Go figure.
So, back to one of my inital question. . .
Will I have to unhook my head unit to plug this in the back of it???
If so will I then need to have anything done at the dealer to get it to work again??
I've heard horror stories about having to pay out the ass if you disconnect the battery or the Stereo to have it "reset" or something.
Old 06-05-2009, 03:52 PM   #20
sna77
sna77's Avatar
My Ride: BMW
e46s don't need a code or anything to be unlocked. They just start working when you turn the car on.
Its always best to disconnect the negative terminal of your car before doing any electrical work.
The LCD screen is very easy to remove. Check out "The Ultimate Retrofit Part 1" in my DIY links here: http://www.bigpatsfans.com/bmw.htm . Part 2 has pics of the Aux input install. There will be no pin swapping for you though since the cable you order will be made for Nav already...
Detailed pics with how to remove the LCD screen. should only take 5 minutes or so to do.
Tom: e46s with factory Nav have the Aux input connection in the back of HU, not in the trunk where BM53 radio is, correct? I used a retrofit harness when installing my Nav, and the Aux input connection is definitely behind the radio with the retrofit harness.
