Sponsored by The Tire Rack
Old 06-03-2009, 06:21 PM   #1
boristhecommunist
My Ride: 325i
E46 Sedan + Koni FSD/Eibach Prokit Springs + M3 rims = no go?
I've read that if you want to put M3 rims on a E46 sedan you'd need to roll the rear fenders due to the wider rears... or get 4x fronts.
Well, I got the wider rear M3 rims put on... as well as Koni FSD shocks and Eibach Prokit springs (lowers the car by about 1.5") and it rubs quite a bit. Not while driving in a straight line, but definitely in dips in the road and while cornering.
I got the rear fenders rolled... still no luck. It helped a little bit, but it still rubs.
My next line of action might be thinner tires... I'm currently running Michelin PilotSport 255/35Z R18. Would getting a less-wide tire help with the rubbing issue? What's the thinnest tire you can put on the M3 rear rims?
Any other suggestions?
boristhecommunist is offline   Reply With Quote
Old 06-03-2009, 06:28 PM   #2
easyman
My Ride: MKV GTI 4 Door
The wheels are simply too wide without doing some serious modification to your fenders. Thinner tires will def help.
2007 GTI 4 Door (MKV)- Current
2010 Acura TSX (cu2) - Retired
1987 BMW 325i (e30) Vert - Burned Down
2002 330i (e46) - Retired
ZPP - ZCW - ZSP - Nav - Bi-Xenon/85122+ - Mtech - 18" CSL - FSD's - 4300k Fogs-
Sig courtesy of fskarboe
easyman is offline   Reply With Quote
Old 06-03-2009, 06:41 PM   #3
Sneaky
My Ride: Fixie
Sell the rims and go for something less agressive in the rear.
THE OFFICIAL BLACK SEDAN THREAD because Nothing breaks necks like a Black BMW.
Sig by So Lowww
Pictures I take
OVOxo till we overdose
Sneaky is offline   Reply With Quote
Old 06-04-2009, 12:21 PM   #4
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Agreed, the suspension isn't the problem, its the wheels.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 06-04-2009, 12:50 PM   #5
Spdu4ia
My Ride: changes too much
you may be able to do it with 245 rears and some serious camber
-Travis
Spdu4ia is offline   Reply With Quote
Old 06-04-2009, 05:48 PM   #6
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Ditto, or some rolled/flared fenders.
This is definitely very aggressive fitment.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 06-06-2009, 06:32 PM   #7
BartenderPlease
My Ride: '03 540i/6 M-Sport
it still rubs but how bad does it rub now? does it still rub on dips with just you in the car? how bad are the dips, like dips when you are on the hwy and cross a bridge? if it isn't too bad you may be able to get by with running a slightly narrower tire.
do you know your current alignment specs? are you a sport or non-sport?
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 06-06-2009, 06:40 PM   #8
reynaldo
My Ride: 2001 325i Sedan
Send a message via Yahoo to reynaldo
I have 18' 235/R40/18 and the rear was rubbing so bad everytime I hit a bump, pothole. I am changing to 225.
reynaldo is offline   Reply With Quote
Old 06-06-2009, 07:07 PM   #9
Penguin Koolaid
Banned
My Ride: Inline Six
Buy wheels with the right offsets. The headache of rolling, pulling, and ****ed up tire wear because you have to use such a negative camber isn't worth it.
Penguin Koolaid is offline   Reply With Quote
