Tire Roation Affecting DSC????? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 06-05-2009, 10:48 PM   #1
danielkspencer
My Ride: 2006 Mustang GT
I had a set of 1/2 worn out tires on the back and new ones on the front. I rotated them out today to save my new ones. Now if I go into a curve a little quick my warning light flashes on my dash for my stability control. The tires aren't that worn out by any means and I never had this problem a month ago when they were on the front before I got the new ones and moved them to the back. Any Ideas???????
I mean before this it hardly ever came on, now it's easy to make it flash without even trying.
I checked all my tire pressures and rechecked the torque on my lugs.
Doesn't seem to be driving any differently, either.
2006 Mustang GT Black on Black Leather- Lots of friggin TORQUE!!!!!!!
danielkspencer is offline   Reply With Quote
Old 06-05-2009, 10:58 PM   #2
GTUnit
My Ride: short bus
Send a message via AIM to GTUnit
The balder tires should have more dry grip. You put the grippier tires on the front.
When you add grip to the front it loosens up the grip in the back (suspension tuning).
It is possible that the rear slips a little more now and that is just enough for the DSC to sense under aggressive cornering.
GTUnit is offline   Reply With Quote
Old 06-06-2009, 08:14 AM   #3
danielkspencer
it just seems that this is happening when I'm not even near where I should loose traction. I take these same curves every day so I'm pretty used to them. I could take them in my jeep as fast as I was last night and not slip.
Old 06-06-2009, 09:14 AM   #4
shall36
My Ride: 325ci
I have the exact same issue. Worn tires moved up front, treaded tires out back. Totally getting DSC in turns. Going today to get new tires. In my case the fronts are down to the wear bars anyways.
My theories:
1. The worn tires and good tires have different diameters throwing off the system.
2. As the previous poster noted, the worn tires have more (or less) grip and causes imbalance.
I did not have the issue before rotation.
shall36 is offline   Reply With Quote
Old 06-06-2009, 09:31 AM   #5
danielkspencer
Thanks. Just wanted to know I hadn't messed something up during the Roation. Glad I'm not alone. I still don't get it with mine being only halfway worn out at best but I guess that's the deal.
Old 06-08-2009, 08:19 AM   #6
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
My theories:
I'd agree with both theories. A combination of the above contributes to DSC stepping too soon.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
dsc, stability, tires
