View Poll Results: I got Powerflex urethane bushings and...
The ride is no less comfy than rubber bushings, and no noise 15 29.41%
The ride is rougher and/or they squeak, but I still like them 4 7.84%
The ride is rougher and/or they squeak, and I don't like it 4 7.84%
I don't have Powerflex but want to get them 16 31.37%
I don't have Powerflex and don't want them 12 23.53%
Voters: 51. You may not vote on this poll
Old 06-06-2009, 09:43 AM   #1
nathancarter
My Ride: 02 330i
Do you have Powerflex urethane bushings?
If you have Powerflex FCABs, ....
nathancarter is offline   Reply With Quote
Old 06-06-2009, 10:00 AM   #2
thomasthethird
My Ride: is sittin' sideways
They're working well for me so far. There was a little squeaking when they I first installed them, but it didn't last long.
thomasthethird is offline   Reply With Quote
Old 06-06-2009, 10:58 AM   #3
Safar
My Ride: comes with blow
I asked my shop for Meyle HD but they didn't have them, and they advised Powerflex. I told them no because they were notorious to squeek, but they said they never had an issue like that with them before.
No squeeking at all now, just 1000 miles though.
Vehicle history
1999 BMW E46 328Ci TS2
1992 BMW E36 316i Sold
1987 Suzuki VS1400
1996 Suzuki LS650 Sold
1984 Kawasaki 305CSR RIP
Went from 305cc > 650cc > 1400cc > 2800cc
No prizes for guessing what my next engine will be...
Safar is offline   Reply With Quote
Old 06-06-2009, 11:48 AM   #4
Titan 3
Titan 3's Avatar
My Ride: E46 325ci, F36 428ix
I had too much vibration transfer through them... I hear a lot of great things about them, but not for me.
Titan 3 is offline   Reply With Quote
Old 06-06-2009, 12:02 PM   #5
JSanders
My Ride: Breaks too often
Meyle wins.
JSanders is offline   Reply With Quote
Old 06-06-2009, 12:17 PM   #6
thefitter
My Ride: Is tight all night!
You need to add a category
The ride is firmer and no noise after _______________ miles.
20,000+ so far
2002 325i - BBS RK ~ Michelin PSII ~ Bilstein CoilOver ~ Rogue RSTM ~ Brembo BBK (custom yellow color) ~ H-Sport Sways ~ TMS endlinks ~ M-Sport CA ~ Powerflex CAB ~ M-Sport STB ~ Ground Control RCA ~ PowerFlex RTAB ~ SuperSprint catback ~ Vorshlag ACP ~ Dinan CAI ~ Dinan SW ~ Denso Iridium ~ Formula One Pinnacle 35.
2007 335i - 100% Stock except dumped the run flats for Michelin PSII.*SOLD*
2011 335d - 100% Stock *SOLD*
thefitter is offline   Reply With Quote
Old 06-06-2009, 01:04 PM   #7
jhk2bmw
My Ride: 2002 E46
I installed them about 3-4 weeks ago and love them. Night and day difference over OEM, but I had the sport package to begin with and prefer a tighter/stiffer feel. All but eliminated annoying tramlining effect I was having on the freeways too (thought I had bad set of tires). After my DIY experience, I suspect that a lot of people are not installing them properly. Admittedly, the instructions you get from PFlex are too vague. The lubed bushing actually "snaps" into the carrier for proper fitment, although if you didn't know better, it appears as though it's engineered to just slide in to the carrier since the front side of the carrier has a recessed lip about the same size as the top lip of the bushing. I basically figured this out by accident after removing and re-intalling the greased bushing into the carrier about 10 times trying to figure out why it wouldn't fit. For some reason the tenth time I stepped on it on a padded surface and it magically poped all the way in. You can't pop it in by hand, need to step on it or use a rubber mallet. Hope this helps someone.
jhk2bmw is offline   Reply With Quote
Old 06-06-2009, 10:33 PM   #8
benjamin1
My Ride: 350z track edition
I've had mine for 12k+ and I've experienced no noise. Ride is stiffer, but that's a very good thing.
benjamin1 is offline   Reply With Quote
Old 06-06-2009, 11:28 PM   #9
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
I've been running my Powerflex bushings, FCABs and RTABs and have extrememly accurate response, no noticable noise and no squeaking. I've had them for roughly 45k miles now.
I would do it all over again in a heartbeat too, if it was necessary. These things don't wear out.
/// MODS
Old 06-07-2009, 12:29 AM   #10
325 & 55
My Ride: 2001 325Ci Step
Powerflex...
will definitely transform one's "comfy" OEM ride, to one that is many times more "rigid"; took some time to get use to.
I've never experienced any "squeaking", but one shouldn't with proper lube and install.
325 & 55 is offline   Reply With Quote
Old 06-08-2009, 09:45 AM   #11
nathancarter
My Ride: 02 330i
Bump, and thanks for the responses so far.
I'm looking at a big suspension refresh/overhaul sometimes within the next month or two. It's my daily driver and I don't want an uncomfortable ride, but increased responsiveness is of course a plus. I'm really undecided between Meyle HD bushings and Powerflex bushings. (then there's the UUC bushings but I don't know if I wanna spend that much... that lifetime warranty is a plus though!)
Old 06-08-2009, 09:55 AM   #12
texlnghorn
My Ride: 330ci
I had them and used them for about 20K miles but I had a persistent popping noise. I pulled the bushings off several times to regrease them but the noise never went away. I thought the noise might be something else like sway bar end links or even the brakes (I replaced both). I eventually put in Meyle HD bushings and the noise completely disappeared. The Meyle bushings were just as easy if not easier to install than the Powerflex bushings.
texlnghorn is offline   Reply With Quote
Old 06-08-2009, 10:11 AM   #13
Denlin68
My Ride: 335i -->330i
Send a message via AIM to Denlin68
MY Powerflex FCAB with housing are coming in this week and will have them installed soon. U guys have the price u paid to get them installed ?
Also do the actual steering reponse gets better ? or its more related to suspension as in viberations u feel
Denlin68 is offline   Reply With Quote
Old 06-08-2009, 11:27 AM   #14
n2Bimmer
My Ride: Loves Corners
I am intrested in getting them myself, but im worried about noise and vibration.
Old 06-08-2009, 03:08 PM   #15
texlnghorn
My Ride: 330ci
Paid to get them installed????? DIY.
Old 06-08-2009, 03:12 PM   #16
fmzip
My Ride: '08 328xi / '01 530i
Powerflex RTABS in my E46....love them.
Powerflex front Upper Control arm bushings in my E39......I don't like the increased feel in the front end of my car. Little reluctant to swap out the FCAB's in my 330 right now.
fmzip is offline   Reply With Quote
Old 06-08-2009, 03:16 PM   #17
n2Bimmer
Can you explain why you dont like it. You dont have noise from the rear?
Old 06-08-2009, 03:20 PM   #18
fmzip
^^^^^ is that question posed to me? My reservation on the FCAB's is because my front end feels perfect so i am not messing with it!
I just put in the Powerflex RTAB's, no noise as of yet......the only difference I feel with these is that the car tracks unbelievebly better. There is no difference in the comfort of ride quality to me. Actually I feel the car rides better since it seems so "together" now.
Being 43, I had the same fear....I hate noise and harshness. Hands down, I am extremely pleased I made the switch.
Here's my DIY I wrote up:
http://forum.e46fanatics.com/showthread.php?t=678004
Old 06-08-2009, 03:22 PM   #19
koven
My Ride: 330Ci
i have powerflex bushings.. they definitely made a difference compared to my worn out OEM ones
koven is offline   Reply With Quote
Old 06-08-2009, 03:23 PM   #20
Tele
My Ride: E46 330XIT MTech II
I'm also going to do a suspension refresh/overhaul but are a bit undecided...
Have anyone tried the purple powerflex bushings?
They say it's more for street use...!?
Tele is offline   Reply With Quote
bushings, powerflex, urethane
