Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 4.56 average. Display Modes
Old 05-29-2010, 06:07 PM   #41
carcus
My Ride: 2006 BMW M5
Originally Posted by delmarco View Post
I'll use the quote of a member here to respond to you.
Yep.....but I was not going to run out and get rid of the car just because it was a SULEV. I was just checking on the failure rate of the fuel pump from other SULEV M56 owners.........and.....you do not have one.
It would be nice to have info on this though. I also think you can retrofit a normal one on the M56....no reason why.
Also, as far as my modifications, I live in Colorado and we have no emission test here. I think I have done quite alot for my M56 mod wise. Tons of people said some things would not work, just out of opinion.
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 08-22-2010, 12:53 AM   #42
devin_name
My Ride: 2004 325i
quick question... there's that other thread about over heating and how to use your OBD to see real time engine temp. That thread states temp should be between 88 and 98. Any of you guys try this out yet? Mine sits between 78 and 88... only hits 90 if I'm really railing it.
Figured I'd post here since we all have more experience with the M56
devin_name is offline   Reply With Quote
Old 08-22-2010, 11:16 PM   #43
ric4080
My Ride: 2004 BMW 325IT
Send a message via MSN to ric4080 Send a message via Yahoo to ric4080
The only issues I've have is that rattle from the fuel tank when I hit a bump in the road, I live in AZ so I don't know if BMW will cover a CA emissions car. I lost faith in BMW stealerships and do most of my own work.
ric4080 is offline   Reply With Quote
Old 09-16-2010, 03:26 PM   #44
ali_abbass85
My Ride: 325i 2003
Just for the records, I have one of my injectors gone bad, SULEVs have special injectors too.
ali_abbass85 is offline   Reply With Quote
Old 09-16-2010, 04:46 PM   #45
g6
My Ride: BMW
i am interested in this too. i know for the m52,m54 that is definitely the norm (88-98)...because i have seen it first hand on a few that have been maintained to spec, but i am not sure on the m56. i have a sneaking suspicion that the m56 may run a bit cooler but i am not sure yet.
g6 is offline   Reply With Quote
Old 09-28-2010, 09:53 PM   #46
sgtfury40
My Ride: 2003 325i
My M56 fuel pump went out a couple of months ago. Have a 2003 325i w/108000 miles. Chapman BMW in Chandler, AZ is replacing tank,etc. under emissions warranty here in AZ. Big relief.
sgtfury40 is offline   Reply With Quote
Old 09-28-2010, 11:39 PM   #47
carcus
Please take a picture of the old tank and get it back from the dealer. Would be great help for conversions.
Old 09-30-2010, 01:09 AM   #48
devin_name
My Ride: 2004 325i
Anybody know about the temp range? There are two of us requesting it now.
Old 09-30-2010, 07:32 AM   #49
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Most the time if it is warrenty BMW wants the parts back.
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 10-02-2010, 11:33 PM   #50
sgtfury40
My Ride: 2003 325i
BMW did want the tank back. But all is good. I think that if you fall within the warranty (150K, 10yrs) you should have no problem getting your local BMW dealer changing out the tank if that is what is needed.
Old 10-19-2010, 05:38 PM   #51
SiLVeR_E46
My Ride: 2003 325i sedan
hi guys, i have a M56 sulev and my check engine light came on and is throwing a code saying DMTL leak. my brother works for BMW and told my that my car has 10yrs 150k miles warranty on the sulev system and to call BMW of NA.I called them and they said that the cars warranty has expired but i only got 65k miles on my car.
i need help i dont want to to pay 6k to fix my car since is goin to the body shop soon to get the zhp aero kit put on and i just ordered the H&R touring cut kit suspension too.
SiLVeR_E46 is offline   Reply With Quote
Old 10-19-2010, 06:12 PM   #52
g6
My Ride: BMW
call them back. find somebody who knows about the sulev. you are covered.
Old 10-19-2010, 06:54 PM   #53
RONINTRANS
Account Under Review
My Ride: 05 325i sulev
Curious, I have about 77K on the engine. The fuel pump and filter are built into the gas tank and it runs about 6K.....no joke...to replace the gas tank with the lifetime fuel pump and fuel filter. Wondering if any of you had to go through this. No issues here, but I can buy a new engine for the price of that gas tank!!!!!
I actually removed fuel pump from 325 sulev M56 and installed on 330 m54. Im sure you can access fuel pump just like non sulev vehicles.
RONINTRANS is offline   Reply With Quote
Old 10-19-2010, 06:59 PM   #54
RONINTRANS
Thats an easy fix. very common issue. DTML pump is located on rear passenger wheel well.
pump cost 85 bucks new . part #16 13 7 193 479
I actully removed one from used e39 and its same part #
I should do a DIY- but its fairly easy to remove and replace. I had same codes and replaced pump and issue was fixed.
Old 10-20-2010, 12:59 PM   #55
SiLVeR_E46
is the DMTL pump covered on the sulev emmission warranty?
Old 10-20-2010, 01:03 PM   #56
jbeurotech
Regional Sponsor
No
Seth Thorson
Old 10-20-2010, 02:05 PM   #57
SiLVeR_E46
how come is not covered? is not part of the emission system?
Old 10-20-2010, 02:08 PM   #58
jbeurotech
Regional Sponsor
Lots of things are part of the emissions system only certain parts are covered by the extended warrenty
Seth Thorson
Old 10-20-2010, 03:58 PM   #59
carcus
I still say after the emissions warranty goes out on the SULEV, a normal plastic tank and filler tube will work. No reason it would not.
Old 10-20-2010, 04:22 PM   #60
jbeurotech
Regional Sponsor
Fuel lines are different I believe I would have to check. Not to mention you would be breaking the law and liable when you sold the car. Unless sold as a "race car "
Seth Thorson
