Old 06-07-2009, 05:19 PM   #1
///BMW5
My Ride: 330ci
Definitive answer on changing ATF in high mileage 330ci
Please do not reply with because i have ed I have been reading thread after thread, after thread about changing ATF fluid on high mileage BMWs. I have an 01 330ci steptronic with 100k and I am having slightly rough shifts ONLY when downshifting from 2nd to 1st. I have read many posts saying that replacing the fluid helped the rough shifts completely and is recommended. However, we have all read about the horror stories about instant failure from dislodging built up junk in your AT over long periods of time from changing the fluid after ~60k miles. I have the GM transmission with the green sticker with "lifetime" oil in it. This thread http://forum.e46fanatics.com/showthr...f+high+mileage makes me comfortable changing the fluid but this thread http://forums.bimmerforums.com/forum...ts&pollid=5027 makes me kind of scared. I am looking for answers form people who ACTUALLY have changed their fluid, not people that have just heard stories about instant failure. If you have changed your fluid after 60k please 1) note your mileage when you replaced the fluid 2) if you flushed it or just refilled 3) what kind of fluid you used (OEM, Esso, Redline)
I really would like to fix the rough shifting because it makes driving my e46 a little less enjoyable and worried. Please post your thoughts!
Thanks!
///BMW5 is offline   Reply With Quote
Old 06-07-2009, 05:46 PM   #2
Bebopper
My Ride: 2010 E90
I do not believe in lifetime fluids, except maybe blood! So I took my wife's '06 325 with 50K miles to my independent mechanic to have the fluid flushed last week. My mechanic (whom I trust completely) said the fluid he drained was black, smelly and looked just plain bad. He flushed the transmission on the BG machine and replaced it with BG Synthetic. I don't drive it enough to say there is a big difference in shift quality, but with only 50K miles, it should not be as noticeable. I just expect that at 100K miles, it will still shift and run smooth. If the fluid is in that bad a shape at only 50K miles, it can't possibly be expected to be good for a transmission to run it to even 75K miles, let alone a real lifetime of 150-200K miles, or longer.
My mechanic, who owns several BMW's of varying vintages, has a mid-90's 740 with 100K+ miles that was shifting very poorly. He said he changed out the fluid two times about 200 miles apart and it made a dramatic improvement in shift quality.
Bebopper is offline   Reply With Quote
Old 06-07-2009, 05:46 PM   #3
Laxplayermjd
My Ride: 03 325i
Send a message via AIM to Laxplayermjd Send a message via Yahoo to Laxplayermjd
This is your problem with the internet or anything about cars. There is always people in this case would say never change your fluid when you get to 100k. Then there is other people who say thats crap and they change their fluid at regular intervals even when it says its lifetime. Everything is based on opinion's and some experiences.
Im know there is some that have blown up transmissions by changing the fluid when it has high mileage. But then there is some that have had no issues.
So all in all do what you think is right.
Laxplayermjd is offline   Reply With Quote
Old 06-07-2009, 05:55 PM   #4
mkodama
mkodama's Avatar
Blood cells are constantly dying and being replaced. When they break down you get bilirubin which is a yellow substance and is why urine is yellow, as well as some bruises are yellow as well. Think perpetual oil change.
Old 06-07-2009, 06:07 PM   #5
Bebopper
My Ride: 2010 E90
As long as I don't have to get hooked up to a BG machine (or the hospital equivalent) to get flushed, I am happy!
Old 06-07-2009, 07:10 PM   #6
///BMW5
My Ride: 330ci
I'm going crazy over this! If I had it done by BMW, I am assuming they would take no responsibility for tranny failure if something was to go wrong with it. Or will the stealership even do an ATF change on an 01?
Old 06-07-2009, 07:37 PM   #7
mkodama
mkodama's Avatar
I know that if your transmission breaks they will exchange it for a new transmission, fill it up, and warrant it for a year. But that's $5500 if you have them replace a broken steptronic. Not sure about a fluid change though...
Old 06-07-2009, 07:39 PM   #8
bmwbun
Banned
My Ride: Pre-facelift Coupe
Patient: "Doctor, it hurts when I do this..."
Doctor: "Stop doing that".
bmwbun is offline   Reply With Quote
Old 06-07-2009, 08:16 PM   #9
bmw328ciwa
My Ride: 2000 328Ci
I've changed tranny fluid at 185,000 so be confident and do it right. Im at 205,000 still shifting like butter.
bmw328ciwa is offline   Reply With Quote
Old 06-07-2009, 08:19 PM   #10
BMWespresso
My Ride: 2005 325CI
Dude change your fluid, I did mine at 47K left pic first time, right pic right bottle is after a 1K, the first change was with filter also, I used Redline D4, auto trannies are hydro knumatic devices and the cleaner the fluid the more better, change the dam fluid
ID:	318243   Click image for larger version
BMWespresso is offline   Reply With Quote
Old 06-07-2009, 08:23 PM   #11
antonmn
My Ride: 02 325Ci
Just changed mine at 134k. Wouldn't think twice about it.
Changed my Audi at 115k (exact same trans). Changed again at 130k. Now at 150k with no problems.
Just be sure to change the filter!!
antonmn is offline   Reply With Quote
Old 06-07-2009, 08:23 PM   #12
///BMW5
My Ride: 330ci
Thanks any advice? I heard something about changing it at a certain temperature and buying a digital thermometer to check the fluid before changing it... any truth to this?
Old 06-07-2009, 08:32 PM   #13
BMWespresso
My Ride: 2005 325CI
no need for that, just let it heatup to the touch, is no big deal
Old 06-07-2009, 08:37 PM   #14
///BMW5
My Ride: 330ci
this one is making me nervous...haha could possibly be a $3k+ ATF change
Old 06-07-2009, 08:53 PM   #15
muniz_ri
My Ride: 2004 325i
Thanks!
1)68K, 2)Refill & Filter Change, 3)Redline D4
~4K miles since the fluid change and all is good. Good luck.
muniz_ri is offline   Reply With Quote
Old 06-07-2009, 08:53 PM   #16
BMWespresso
My Ride: 2005 325CI
are you mechanically inclined if not then let a mechanic do it, but really not much to it
Old 06-07-2009, 09:08 PM   #17
///BMW5
My Ride: 330ci
No I'm not mechanically inclined but I am just in no position to pay $3k for a new tranny if something does happen...I'm only 17 but I've done the vanos repair, complete cooling system overhaul (water pump, exp tank, thermostat, radiator hoses, etc) , and all of my maintenance on my own so the mechanical side of it is not what scares me.
Old 06-08-2009, 07:15 AM   #18
BMWespresso
My Ride: 2005 325CI
If done those then tranny fluid if more like an engine oil change, the only trick is to remember that when you pull the filter the large flat O ring stays in, the rest is normal stuff
Old 06-08-2009, 07:50 AM   #19
eek142
My Ride: E46
Dude change your fluid, I did mine at 47K left pic first time, right pic right bottle is after a 1K, the first change was with filter also, I used Costco fruit juice, auto trannies are hydro knumatic devices and the cleaner the fluid the more better, change the dam fluid
Fixed.
eek142 is offline   Reply With Quote
Old 06-08-2009, 08:23 AM   #20
MightyY
My Ride: '05 M3, '03 M5
I had my fluid drained and the filter replaced sometime after 60K with all OEM fluid/filter. I'm now at 90K and thinking about doing it again. The fluid that came out at 60K was disgusting. It was black and looked very liquidy with chunks in it.
MightyY is offline   Reply With Quote
