Sponsored by BAVSOUND
Old 06-09-2009, 10:30 AM   #1
Ballistic325
My Ride: slow and steady
Bluetooth modules
Hi guys
Looking for some info from more experienced members....
Can someone confirm for me please whether a bluetooth module from an E9x will work in an E46?
Part numbers that I've found are:
84109122446-01
84109181276-01
Thanks in advance for your help...
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 06-09-2009, 11:34 AM   #2
profM3
My Ride: 2005 M3 ZCP
Originally Posted by Ballistic325 View Post
Hi guys
84109122446-01
84109181276-01
Look them up in realoem.com. You'll see that
84109122446 and 84109181276 are for E90 cars which are optical fiber MOST bus cars. The electronic modules are completely incompatible with E46 copper wire iBus cars.
Consult this list for TCU/ULF part numbers:
iBus TCU and ULF Part numbers
Also read this:
Description of bluetooth TCU and ULFs for E46 cars.
2005 M3 Silbergrau Metallic on black; 6MT, ZCP, ZPP, ZCW, Nav, Dinan exhaust, two AR20 resonators in section 1, Autosolutions SSK, Fucy CSL diffuser, Intravee II, illuminated ZHP shift knob, stealth V1 install with ash tray remote, OEM first aid boxes under both seats, Ultimate pedals and more...
profM3 is offline   Reply With Quote
Old 06-09-2009, 07:35 PM   #3
Ballistic325
profM3 thanks very much for the info.
I had a look through the posts that you link to above and have the following question... I am being offered a bluetooth TCU part number 84116945940-01. I've seen pictures of it and it does have the bluetooth logo / pass key etc labelled. According to your list you're unsure of whether bluetooth works on it, and you mention that it would be for US only (correct?).
Would this device work in an Aus spec car? I am pre-wired for bluetooth and have an M3 wheel with 'the talking man' button.
If it works, it's a great alternative to going to the ULF route...
Thanks....
I can help with
* RTABs
Old 06-09-2009, 10:15 PM   #4
profM3
I am almost sure that 84116945940 will not work. There was a period of time in model year 2004 cars where bluetooth modules were installed that had the bluetooth logo on the sticker and even had pairing code on them but the bluetooth circuitry did not work. BMW even gave people a card with the bluetooth pairing code when they bought their car but later had to admit that their cars didn't have bluetooth. Bluetooth was not functional in the TCU until model year 2005 cars (build dates 9/2004 and later) There is a BMW service bulletin on this. For bluetooth you need a TCU with a build date after 9/2004 (i.e. 2005 model year cars).
All that said there are CDMA (USA) and GSM (Euro) TCU modules. In the US only CDMA bluetooth modules work, even though you'd think for the bluetooth it wouldn't matter whether it was CDMA or GSM. Also we have both CDMA and GSM networks in the US (Verizon and AT&T for example) but BMW uses the Verizon CDMA network for their TCUs. I have no idea what the situation is in Australia for this aspect. Sorry.
If you can get TCU from a 2005 model or later E46, X3 or Z4 it should work. These are all iBus cars (not the brand new Z4 hard top convertible). After the upcoming X3 revision, all BMWs will be MOST bus based.
Old 06-09-2009, 11:00 PM   #5
Ballistic325
It's no wonder you're The Professor!
Thank you kindly, it's much appreciated.
Rgds
Ali
I can help with
* RTABs
Old 05-09-2013, 02:55 AM   #6
omairkhanzada
My Ride: m
Since I have this part number in my trunk, I don't have bluetooth? That's ridiculous. My build date is 04/04 and the part number in the trunk is 84116945940-01.
K
omairkhanzada is offline   Reply With Quote
Old 05-11-2013, 05:31 PM   #7
sna77
sna77's Avatar
My Ride: BMW
Nope... I bought a new e46 in 2004, and was told the BT would work and then when it didn't, was told a free fix was coming... it never did... A year later, I dropped $1k to add Bluetooth to the card. What a joke that was...
sna77 is offline   Reply With Quote
Old 05-13-2013, 08:45 PM   #8
Jeremy Bavsound
My Ride: Bavsound
If you wanted to add iPod integration as well as bluetooth to your factory radio we do offer the Mediabridge at a much cheaper price and easier install than the OEM units, as well as it is running current bluetooth technology
http://www.bavariansoundwerks.com/product/711/0//
Jeremy Whittle
jeremyw@bavsound.com
Bavsound | Audio Solutions for YOUR BMW
www.bavsound.com | 404.381.1800
Jeremy Bavsound is offline   Reply With Quote
bluetooth, bluetooth module, compatible
