Thread Tools Search this Thread Rating: Thread Rating: 66 votes, 4.92 average. Display Modes
Old 06-10-2009, 05:03 PM   #1
e46amazed
My Ride: M3
Question M3 Steering Wheel Leather Restore? PROBLEM SOLVED
UPDATED: See images/text below
I bought a used m3 with 48k miles and the leather on the steering wheel is pretty worn out. It looks like some combination of the use of bad products, lots of sun, and maybe heavy use?
Any recovery possible? Tips or tricks? should/can I re-dye the wheel?
I tried LOTS of Lexol leather conditioner, but it didn't do a whole lot. And when applying it, it made the leather wear out a little more (because it was softer until dry)... but not noticeably different
I was debating getting a new steering wheel, but the M3 SMG wheels cost way more than a regular non-SMG (I actually have a non-SMG wheel from my previous 330).
Any thoughts would be greatly appreciated. thanks!
All I have to say is WOW!
I had read a previous thread about a product called Mr. Clean Magic Eraser... and I didn't think it would work until stolidog brought it up again in this thread. It is basically a specialized sponge with no chemicals... that you get wet/damp... and just wipe down your steering wheel as if you were trying to remove some dried lotion from leather (hint hint).
Just dunk it in a bucket of water after a handful of wipes and then squeeze it out so it is damp again (the bucket of water was brown after I was done). My only guess is that the previous owner (or his girlfriend) used hand-lotion frequently... along with maybe some bad leather product (maybe armorall). So basically, I took about 15 minutes to obsessively wipe down every bit of the steering wheel including the stitching... and the steer wheel was like FRIGGIN NEW!!!
I actually liked the way it felt and looked after the cleaning (felt like the brand new matte finish of a new wheel)... but decided for longevity and applied some lexol leather conditioner after about 30 minutes of drying. Since the cleaning was done with water and the magic eraser sponge I feared the water might dry out the fresh leather. It still feels and looks AWESOME after the leather conditioner.
Anyways, I am so stoked and blown away by the results. A four pack set me back about $3.00 at target and would recommend you use them on even just a barely dirty steering wheel. I don't know how these things work sooo well.. but Im glad I can share the results.
If I had to compare the steering wheel to a brand new one, I'd say it looks and feels about 90% new. Obviously can't get away from wear that occurs over time, but my steering wheel looked beat... as you all concluded
ID:	319716   Click image for larger version
ID:	319717   Click image for larger version
ID:	319718   Click image for larger version
ID:	319720   Click image for larger version
ID:	319721   Click image for larger version
ID:	319722   Click image for larger version
ID:	319724   Click image for larger version
ID:	319725   Click image for larger version
ID:	319726   Click image for larger version
ID:	319728   Click image for larger version
ID:	319729   Click image for larger version
ID:	319730   Click image for larger version
e46amazed is offline   Reply With Quote
Old 06-10-2009, 06:38 PM   #2
THATS FRESH
My Ride: SSHNIPER
Send a message via AIM to THATS FRESH
thats alot of wear. he must had some rough as s hands. that looks like alot of dirt buildup to. if it were up to me, id get a new steering wheel.
THATS FRESH is offline   Reply With Quote
Old 06-10-2009, 07:55 PM   #3
e46amazed
My Ride: M3
only thing I can think of is that the previous owner may have taken the car to the track often or something (which I am trying not to think about)... but I had an inspection done and the rest of car is in great condition. Its a 2003 with 48k miles.
Could crappy products like Armor All (a guess) have sped up the deterioration (along with other things)?
Although it looks super patchy, dry, and dirty, the overall feeling of the wheel is uniform, soft, and doesn't feel bad. It really is just the look that throws me off.
Would the Leatherique Steering Wheel kit for $25 be worth it?
http://leatherique.org/detail.aspx?ID=39
or would a different re-dye kit be better? or should I fork over $650+ for a new SMG wheel (which I don't really want to)?
I am pretty hands on and would like to try a DIY solution... unless it is just not realistic/logical.
Old 06-10-2009, 10:10 PM   #4
Regensburg94
My Ride: 2006 BMW 330ci
I'd get a new wheel too. The look alone will make a lot of difference. The damage will be hard to DIY fix, I would imagine.
Regensburg94 is offline   Reply With Quote
Old 06-11-2009, 11:12 AM   #5
Hellishness
My Ride: Interlagos M3 ZCP
maybe go to a detailer, or try anything (like leatherique for $25) cheaper than 650....
'06 IB M3
2 E30 Verts
Hellishness is offline   Reply With Quote
Old 06-13-2009, 10:08 AM   #6
stolidog
My Ride: 2004 M3 6spd
Tried the magic eraser? A lot of that could just be dirt and oil build up. If you lightly use the Mr. Clean magic eraser with some water and maybe a drop of soap, you might get some good results. Then when you are done make sure you put some conditioner on the leather.
http://forum.e46fanatics.com/showthr...t=magic+eraser
stolidog is offline   Reply With Quote
Old 06-13-2009, 10:15 AM   #7
nickchuck
My Ride: 325xi (Topaz)
I'd say try the kit, as posted above way cheaper than buying a new wheel.
Also, are you willing to part with that extra wheel you have? Shoot me a PM
nickchuck is offline   Reply With Quote
Old 06-15-2009, 12:04 PM   #8
e46amazed
My Ride: M3
nickchuck, thanks for your feedback... and the non-SMG wheel I mentioned is on another car. Sorry.
Old 06-17-2009, 05:11 PM   #9
e46amazed
My Ride: M3
Problem solved. I edited the first post with more text and before/after images
Thanks Everyone!!!
Old 06-17-2009, 05:27 PM   #10
sna77
sna77's Avatar
My Ride: BMW
holy $hit I can't believe thats the same wheel?!! Cleaning up the attachments for a better visual...
sna77 is offline   Reply With Quote
Old 06-17-2009, 05:30 PM   #11
sna77
sna77's Avatar
My Ride: BMW
Old 06-17-2009, 05:31 PM   #12
sna77
sna77's Avatar
My Ride: BMW
Old 06-17-2009, 05:55 PM   #13
Regensburg94
Wow, amazing results. Your wheel looks almost new.
Old 06-17-2009, 06:18 PM   #14
e46amazed
My Ride: M3
yeah seriously, I thought people would think I was lying and bought a new wheel
Im sooo happy... you don't even understand I had such low expectations and was ready to buy a new wheel.
and thanks sna77 for the relinked pictures!
oh, and here is the link to my similar thread at m3forum.net:
http://www.m3forum.net/m3forum/showthread.php?t=270389
Old 06-17-2009, 08:05 PM   #15
Addy25
My Ride: TitanSilber m3 Vert.
Send a message via AIM to Addy25
Bow to the Magic Man!!!
OK..so I was forwarded this thread by a good friend (SNA77) who HATED the condition of my wheel..and I wont lie..i hated the shine on it equally..
SO i read this thread and said..wth heck..try out Mr Clean..dont have anything to lose...so I just did it..and below are the results...
All i can say..is...I believe in MAGIC!!!
This thing is SUPER for ALL types of surfaces.
(Granted the leather on the wheel is no longer as supple as it once was, it look 1000 times better now!)
PICS : (first is the old wheel after a full interior detail..and the pic was NOT taken with a flash (which multiplies the reflection))
Name:	Detail Big A 016.jpg
ID:	319736   Click image for larger version
ID:	319737   Click image for larger version
ID:	319738   Click image for larger version
Addy25 is offline   Reply With Quote
Old 06-17-2009, 08:10 PM   #16
sna77
sna77's Avatar
My Ride: BMW
Holy $hit Addy! I can't believe that's the same wheel!!!
Old 06-17-2009, 08:22 PM   #17
Andrew@euro-spec
My Ride: E92 335
so what kinda condition do you guys recommend after u use the magic eraser?
Andrew@euro-spec is offline   Reply With Quote
Old 06-17-2009, 08:35 PM   #18
Addy25
no conditioner for me yet.... i do have the bmw leather cleaning//restore kit, i might use that. but for now, im just gonna leave it as is
Old 06-18-2009, 07:03 AM   #19
Slick-Vic
My Ride: 2003 BMW M3 Tiag
I used leatherique on my steering wheel even though my wheel wasn't as discolored as the OP's it still got rid of the lines/wrinkles these steering wheels get after time. It also made the wheel feel thicker like how the steering wheel is when its brand new and the color came back to life as well. I think leatherique would have done just as good as a job as the magic eraser in most ways I think the biggest thing is getting all the dirt and sweat plus the sun abuse off the wheel to restore the look it use to have.
CF TMS cold air intake/UUC Rasp-x section I/StopTech stage II brake kit slotted rotors, SS brake lines/3 pc. AC Schnitzer rear spoiler/CF rear diffuser/Iforged Aeros 19x8.5x10/Smoked corners/Smoked EE LED tails/Matte Black kidney grills/Matte Black gills/Painted reflectors
Slick-Vic is offline   Reply With Quote
Old 06-18-2009, 11:24 AM   #20
SeanC
My Ride: 330i
wow, gonna to this today.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
