Old 06-11-2009, 12:03 AM   #1
tchavis1989
My Ride: 2004 BMW 330i
Send a message via AIM to tchavis1989 Send a message via Yahoo to tchavis1989
3.46 In 330i ZHP, What Drive Shaft?
hey guys, so my drive shaft on my 2004 330i ZHP recently went up due to the fact that i didn't bolt it up properly after a transmission job but sometimes these types of things can be a blessing in disguise. anyway, a local fanatic has offered me a dead even swap (my 3.07 for his 3.46) as he's parting his car out though am wondering what type of drive shaft do i need? my 2004 330i ZHP came with a CV joint drive shaft and understand pretty much every other three series is a U joint? what will bolt up to the 3.46 and my transmission with no modification?
CLIFF NOTES
getting a 3.46 diff
what type of drive shaft do i need and off what car (make/manual/auto etc)?
regards,
tyler
tchavis1989 is offline   Reply With Quote
Old 06-11-2009, 12:05 AM   #2
Cruzader
My Ride: Alpinweiß facelift
i believe u need ur stock drive shaft. U may need different flanges idk tho.
Cruzader is offline   Reply With Quote
Old 06-11-2009, 03:14 AM   #3
Alex323Ci
My Ride: M3 & 323Ci (sold)
You don't need to change the driveshaft for diff swap, just change the input flange from old diff to the new 3.46 diff (which will have the smaller input flange). You may also need to swap the output flanges to match with your drive axles also. Output flanges are very easy, input flange is more tricky and needs to be fairly precise or the pinion gear will be worn and go out.
