Old 06-11-2009, 05:03 AM   #1
kuksul08
My Ride: M3
100 Octane Gas
There's some 100 octane gas at a 76 station near my friend's house. At $9 a gallon he put a few gallons in and said it was noticeably faster (e36 M3).
Will my car benefit at all from it or not? It would just be to try a little...
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is offline   Reply With Quote
Old 06-11-2009, 05:18 AM   #2
Acarder
My Ride: 69' M3
Probably not. He has a high compression ratio so he can benefit from higher octane gas, unless you have a FI'ed M52tu/M54, 91-93 should be the most you put in. It's like if you have a car made to run on 87 and you put 93 in nothing changes.
It might make your car run a little better i.e. whatever gas you have in now might not be fully reaching the cars potential but thats a trade off you make for the increased price and 91 is more then reasonable. Even if you did put it in, the car would only run like it was on the top usable fuel (for example, 95) so you'd be wasting a lot of money. From memory we have a 10.2:1 compression ratio and the E36 M3 has a 11.2:1, so it can harness a higher octane.
Acarder is offline   Reply With Quote
Old 06-11-2009, 08:16 AM   #3
TX_Bullet
My Ride: 2001 325Xi
From my experience I found it will make a slight difference. When running a higher octane like 100 really what happens is that the fuel combust more rapidly and hotter creating a slight bit of HP. My father and I have a oval race car that runs 112.
One day at the track I figured I'd put a splash of 105 Sunoco race fuel in my car and I must say she was running a bit more SPIRITED!!!!!
You have to be careful running high.....I'm mean really high octane because you can combust the fuel to HOT
Originally Posted by jbeurotech View Post
Sometimes the Cheapest quote is the most expensive in the end
Number of Destroyed Newb Destroyers- 1
The Mods
Power Flex FCAB
Much more coming.....
TX_Bullet is offline   Reply With Quote
Old 06-11-2009, 08:27 AM   #4
Renboy
My Ride: 04 330Ci '08 Daytona
Wrong. Completely wrong. High octane burns SLOWER and as a result COLDER than low octane.
OP, it won't do a thing. Unless it's leaded, then it'll just plug your cats in a couple of minutes.
Renboy is offline   Reply With Quote
Old 06-11-2009, 08:34 AM   #5
Acarder
My Ride: 69' M3
Higher octane fuel just takes more energy to detonate, so when you have a high compression engine (ie, S52/S54) using a higher octane means that the fuel wont prematurely detonate due to the higher compression and cause the engine to "knock" while the piston is going down.
Old 06-11-2009, 08:37 AM   #6
altink
My Ride: 99 328i
From wat i remember about high octane is the higher the engine compression more octane it needs, so it doesn't pre-detonate, like turbos, chargers and high compression race or sport cars, just my 2 cent
altink is offline   Reply With Quote
Old 06-11-2009, 08:39 AM   #7
sprintman
My Ride: Ex 325CI owner
My 325 ran better on Shell V-Power Racing 100 RON but no longer available. 98 RON the best available now unfortunately.
sprintman is offline   Reply With Quote
Old 06-11-2009, 08:50 AM   #8
enelson325
My Ride: 2002 325i
you can def feel the difference in the performance of the car
enelson325 is offline   Reply With Quote
Old 06-11-2009, 09:24 AM   #9
Freeflow
My Ride: 330zhp ; E30/325is
If you get a shark injector or some kind of performance software it states it allows you to benefit from changes in octane 87-93 pump fuels... I don't see why this software wouldn't help you benefit from race fuel...
Freeflow is offline   Reply With Quote
Old 06-11-2009, 11:27 AM   #10
matterhorn
My Ride: 2000 328i
Engine knock is premature ignition on the UP stroke of the engine otherwise known as the compression stroke...
matterhorn is offline   Reply With Quote
Old 06-11-2009, 11:30 AM   #11
matterhorn
My Ride: 2000 328i
unless you are increasing the compression ratio of the engine, i.e. milling the head, new pistons, supercharger, or turbo charger, etc. there is absolutely NOOO benefit to using higher octane fuels... you'd be wasting money. Software does not increase compression.
Old 06-11-2009, 11:37 AM   #12
nathancarter
My Ride: 02 330i
To my understanding, changing the valve timing - which can be accomplished through the VANOS, which is controlled by software - CAN change the compression. Same way the compression is backed off a bit when the anti-knock sensors start to detect knock.
Can't believe I'm replying to an octane thread.
nathancarter is offline   Reply With Quote
Old 06-11-2009, 11:44 AM   #13
matterhorn
My Ride: 2000 328i
THAT I didn't know - most engines that I'm accustomed to working with use Ignition Timing to control knock, not compression ... with that said, I REALLY doubt software could change valve timing so much that you'd need anything higher than 91-92 octance ... okay I'm done ...
Old 06-11-2009, 11:46 AM   #14
todd92
My Ride: 05 330i ZHP
LOL. Valve timing has nothing to do with compression. Knock sensors retard ignition timing, they cannot and do not change compression.
todd92 is offline   Reply With Quote
Old 06-11-2009, 11:47 AM   #15
SteveX82
My Ride: 2001 325i
Valve timing is varied with RPM to assist with cylinder filling (and therefore cylinder pressures) and broaden the peak of the torque curve, as cylinder heads have different airflow characteristics as RPM (and therefore air velocity) changes. It has nothing to do with compression ratio.
Similarly, the knock sensors are used to retard ignition timing (and therefore the timing of the increase in cylinder pressures due to combustion) and have nothing to do with compression ratio.
Matterhorn's point remains that unless you are doing something to either a) increase cylinder pressures or b) advance the timing of said cylinder pressures beyond what BMW has designed, you will not benefit from using fuel that is ultimately less prone to ignition than 91 octane.
SteveX82 is offline   Reply With Quote
Old 06-11-2009, 12:02 PM   #16
nathancarter
My Ride: 02 330i
Thanks for the clarification about the ignition timing, though it doesn't really make sense. If "knocking" happens when the fuel detonates before the spark, how does retarding the spark prevent knocking? Can't find a clear answer with searching; everything that I find just says that the software "changes the running conditions" to prevent knock - how vague.
Also, though the compression ratio doesn't change, the "cylinder pressure" can change if you change the valve timing - pardon my semantics in the previous post, perhaps I should have used the words "cylinder pressure" instead of the word "compression" which I didn't mean to be the same as "compression ratio." So, then, how does the Shark injector - widely regarded to be good and reliable software - claim to improve power and fuel economy with the use of higher-octane fuel? It changes the valve timing to increase cylinder pressure, correct?
Old 06-11-2009, 12:17 PM   #17
kuksul08
My Ride: M3
Haha, yes I understand how octane works, and that our cars adapt to the type of fuel we put in using sensors. You're supposed to use 91 or higher, but 87 works and it just changes the timing. I thought maybe it would be able to advance the timing (more so than with 91) and maybe put out a little more power.
Probably little to no difference practically though...
Old 06-11-2009, 12:52 PM   #18
SteveX82
My Ride: 2001 325i
If "knocking" happens when the fuel detonates before the spark, how does retarding the spark prevent knocking? ........
"Knocking" happens when you have too much ignition advance and the spark plug ignites the a/f mixture before the piston has reached TDC and begins traveling downwards. "Pre-detonation", on the other hand, occurs when the mixture auto-ignites (ie, without a purposeful ignition source) due to hot spots on the cylinder head, lean a/f mixtures, or the heat generated by compression.
I'm not familiar with the shark injector, but it's much more likely that it advances ignition timing instead of cam timing.
Old 06-11-2009, 01:16 PM   #19
Bondga
My Ride: 328Ci
Retarding ignition timing stops detonation becasue of when it ignites the fuel. As gasoline is compressed it becomes more easily ignitable and under enough pressure it will ignite on it's own (this is becasue of the heat caused when it is compressed). Because of the velocity that the piston moves at, your timing is ALWAYS advanced of TDC. The spark is fired well before (compared to the speed of the piston) the piston ever reaches the top. As the combustability of the fuel increases it takes less spark and less time to ignite it, therefore the spark needs to be released at a later time so that it will iginte at TDC.
Increasing your Octane past it's recomended level, without any modifications to the ignition system, can actually decrease performance. If the combustability of the fuel is to low it will ignite after TDC thus wasting power.
Considering your engine runs only about a 15-25% percent efficientcy, I wouldn't figit with it if you don't know what your doing. (A.K.A. adding unrecomended fuel)
Bondga is offline   Reply With Quote
Old 06-11-2009, 01:20 PM   #20
Bondga
My Ride: 328Ci
One of the strokes is the compression stroke, where the engine compresses a cylinder-full of air and gas into a much smaller volume before igniting it with a spark plug. The amount of compression is called the compression ratio of the engine. A typical engine might have a compression ratio of 8-to-1. (See How Car Engines Work for details.)
The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting.
The compression ratio of your engine determines the octane rating of the gas you must use in the car. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel. The advantage of a high compression ratio is that it gives your engine a higher horsepower rating for a given engine weight -- that is what makes the engine "high performance." The disadvantage is that the gasoline for your engine costs more.
http://science.howstuffworks.com/gasoline4.htm
