Can I go just 1 week without..... - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-11-2009, 12:41 PM   #1
odgamma15
My Ride: 2003 330 ci
Angry Can I go just 1 week without.....
The bulb out indicator on the instument panel go off.... its getting annoying
did a search and found this link for the tail lights.... http://forum.e46fanatics.com/showthr...light=bulb+out so i will try this for the brake light when it comes back on.
But front turn signals are doing this now....Sometimes its the left, somtimes the right, and sometimes both.... is there something I need to look at? I wont be visiting the Stealership for this, I do all my work on my cars, so any suggestions on where to look would be greatly appreciated.
Thanks!
used to hate german cars... now i have 2!!!!
odgamma15 is offline   Reply With Quote
Old 06-11-2009, 12:55 PM   #2
nathancarter
My Ride: 02 330i
The front corners and the rear taillights are two separate problems, though they often occur coincidentally.
For the fronts, the bulb socket is susceptible to corrosion. Take out the bulbs and inspect the socket, and R&R as necessary: clean off any corrosion, bend/tighten the contacts, or just replace the socket (inexpensive part). You may also need to replace the bulbs, if the contacts are damaged or melted due to arcing or excessive heat.
For the rears, the problem is inadequate grounding at the wiring harness, which sometimes leads to excessive heat and melting of the wiring harness. I'm not a big fan of the twisted-wire-and-electrical-tape fix, especially considering that BMW has released a TSB with a proper fix:
http://forums.bimmerforums.com/forum....php?t=1076114
nathancarter is offline   Reply With Quote
Old 06-11-2009, 01:26 PM   #3
Kubica
My Ride: 2003 325xi
Thanks!
For the rear, check out post #5 in the link you posted. Works perfectly, costs $.05!!
Old 06-11-2009, 01:34 PM   #4
odgamma15
Thanks Nathan.... you gave me something to do this weekend.
Old 06-11-2009, 01:48 PM   #5
SaN NizZLe
My Ride: 2000 328Ci
SaN NizZLe is offline   Reply With Quote
