Need help with Installation of Sony Radio - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BAVSOUND
Old 06-14-2009, 05:29 PM   #1
xaiolin
My Ride: 2001 BMW 330ci
I just bought a Sony CDX-GT130 and I got the wires connected how i think they should be connected. I get radio but cannot play cd's or read aux input.... the unit seems to be reading the cd's but i get no audio. Anybody familiar with sony units know what the issue can be?
here is the link for the system:
(http://www.amazon.com/Sony-CDX-GT130...6993593&sr=8-1)
xaiolin is offline   Reply With Quote
Old 06-14-2009, 07:39 PM   #2
98mustangguy
My Ride: 04-325i, 00-s4
defective unit
98mustangguy is offline   Reply With Quote
Old 06-14-2009, 08:10 PM   #3
jay2001
My Ride: 325i & 530i
This seems so typical these days. Please read this thread.
http://forum.e46fanatics.com/showthread.php?t=682759
Don't take the wiring so literally. Very few BMWs actually have a power (extension/retracting) antennas. On most Aftermarket head units these days, the power antenna is for radio use and the remote on is for the amps. BMWs use only the remote on - not the power antenna remote. Where it has power antenna on the BMW harness adapter, use the amp remote on from the HU instead.
True the industry should label things more correctly but that is a losing battle. Cost will always win. This issue should be a sticky at the top of this forum.
Do you have this? In your case use the blue/white wire for the white wire on the E46.
http://akamaipix.crutchfield.com/Man...8/158GT130.PDF
jay2001 is offline   Reply With Quote
Old 06-15-2009, 06:47 PM   #4
xaiolin
I have the 12v ant out (white wire, pin 16) from my bmw connected to the Ant rem wire of the radio..... this is the only way i get radio stations to play. My issue is that when i put a cd in or plug in my ipod to aux in, there is no audio, however it reads it because the time of the track or song counts down. I did get the cd to work in the past by connecting the yellow wire from radio to the 12v direct (constant red/green wire) and the 12v acc (switched purple/white wire) but i believe that this fried 2 radio fuses (7 and 41).
Old 06-15-2009, 06:53 PM   #5
MyE46I
My Ride: 330I
ur gonna install a sony into a bmw? *shakes head*
MyE46I is offline   Reply With Quote
Old 06-15-2009, 07:01 PM   #6
xaiolin
for now, yeah... its better than no radio
Old 06-15-2009, 07:07 PM   #7
jay2001
Let me try another way.
The amp is not ON in CD or AUX mode. There is no antenna remote in a BMW unless you see an antenna rising up or down when you turn on the radio. The antenna remote out on aftermarket radios these days only work when the "radio" is used. Since BMW in the US usually use an amp, you need to use the rem on - not the ant rem. The white wire is a rem on for the amp. The labels on the harness adapters are not labeled correctly.
Old 06-15-2009, 07:16 PM   #8
98mustangguy
Id still say it may be defective, it powers on and plays radio, well you only have 3 connections power,ground, switched. if these were wired wrong, radio wouldnt play either as you would have no power. Since you have power, radio plays, cd's appear to read but not play i would say its defective or you burnt it out when you hooked it up incorrectly.
Old 06-15-2009, 07:19 PM   #9
98mustangguy
this too, if you in fact have it hooked up properly then its fried. power attenna shouldnt be used for anything, sony wire labeled remote goes to remote wire(white) in bmw harness as jay said.
Old 06-15-2009, 07:19 PM   #10
jay2001
If your car is from the US, it likely has an amp. If the remote on turns off when you switch to CD or AUX then this turns the amp off.
Use the amp rem on.
Old 06-15-2009, 07:25 PM   #11
jay2001
Ok - Im sorry. This little subject got me a little toasted. I'll let you try this and hope you get it working.
Old 06-15-2009, 07:29 PM   #12
98mustangguy
Radios are very simple to hook up, that said if you have no idea what you are doing take it to a shop and pay the $30 to have it hooked up before you do some serious damage.
Old 06-15-2009, 08:55 PM   #13
PBFreak817
My Ride: 2005 325i
If you are using the harness adapter then the blue wire on the harness adapter has to be connected to the blue/white wire on the head unit harness.
PBFreak817 is offline   Reply With Quote
Old 06-15-2009, 09:18 PM   #14
325CI2004
My Ride: 09 335I
the blue/white wire and the blue wire on the harness need to be spliced together to the white wire. That deck has two remotes, the blue is the antenna remote, and the blue/white is the amp remote. When you are on FM, the Antenna remote wire turns on the amp/power antenna (white wire) which is giving you sound. When you are on Aux or CD, there is no Ant Remote signal going to the amp/power antenna which is causing no sound.
So try splicing the blue/white and blue to the white wire.
09 E90 335i Alpine White/Chestnut Brown
325CI2004 is offline   Reply With Quote
Old 06-15-2009, 09:20 PM   #15
325CI2004
My Ride: 09 335I
^ Didnt see PBs post.
Old 06-16-2009, 04:43 PM   #16
xaiolin
will try, thank you.
Old 06-16-2009, 05:02 PM   #17
xaiolin
It worked, thanks man.
