Old 06-19-2009, 03:42 PM   #1
antzcrashing
My Ride: 2006 330i
driver door locks broken - key spins helplessly
When I put the key in my driver-side door and turn it nothing happens, no lock, no unlock
I believe it is mechanically broken due to forceful unlocking. I didn't feel it happen ever, one day just went limp.
I'm pretty sure my problem is not that "door lock relays in the GM5 module are shot."
How can I fix this - locksmiths won't touch it, they say go to the dealer
I did he said around $100 just to pull the panel off and find out the problem
antzcrashing is offline   Reply With Quote
Old 06-19-2009, 03:50 PM   #2
nathancarter
My Ride: 02 330i
According to the Bentley manual, the lock cylinder has a fragile plastic tab that is designed to break, to thwart forced entry by, say, a screwdriver. After it breaks, you put your key in and it just spins around and around.
Fortunately, the part is relatively inexpensive from the dealer, which (I think) includes keying to match your VIN. May take a day or two to get it though.
http://www.realoem.com/bmw/showparts...54&hg=41&fg=40
Part #11, $60-80ish, I assume the price difference is whether they match your car or not.
Sorry, I don't have any details on the actual installation procedure.
nathancarter is offline   Reply With Quote
Old 06-19-2009, 03:57 PM   #3
antzcrashing
My Ride: 2006 330i
thanks for the post Nathan
Has anyone installed this part?
Old 07-13-2009, 10:27 PM   #4
mikeyh1015
My Ride: Bmw 04' 330ci coupe
Lightbulb Ihave the same problem
Same problem on my 04 330ci. Please post pics on how to fix this.!!!!
mikeyh1015 is offline   Reply With Quote
Old 07-14-2009, 08:50 AM   #5
antzcrashing
My Ride: 2006 330i
I will try to pull my door panel off and see how accessible this part is - in the next month or so
Old 07-14-2009, 09:18 AM   #6
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Number 11 is what you need. No need to remove the door panel there is a 4 MM Allen to remove near the side of the door then it pulls out.
They are ordered via vin and keyed to the car. You need a Drivers license and title to order from the dealer.
Pretty simple project should be done in less than 1 hour for your first time
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 07-14-2009, 09:25 AM   #7
antzcrashing
My Ride: 2006 330i
thanks Seth
Old 07-14-2009, 01:24 PM   #8
vimal32
My Ride: BMW E46 320i
Hi all,
I had this same issue,
fortunately i was able to do a DIY on this by buying part 11 from a salvage yard.
Unfortunately it was quite a b#$@# to figure out since the internals of the part are very slightly different between a facelift and pre facelift model.
Took quite a while and sore fingers to get it right. If its a relatively in-expensive part, i'd say get it done at the dealer - but it is a possible DIY.
Also i didnt know it could be removed without removing the door panel, only realised it after removing the whole damn thing and figured it out it couldnt be done that way, this added to my frustration of this DIY .....
vimal32 is offline   Reply With Quote
Old 07-28-2009, 12:06 PM   #9
Carlo323
My Ride: 99 323i
THANK YOU. im going to do this DIY this month lol.
I broke my key in the key hole in the winter and it was turning and turning and turning, the locks smith said WOO go to the dealer. i then broke off the key in the door. then i had to go buy a new 200$ key with remote. and now the only way to get in my car is by remote. so i rather fix this issue before i sell it.
grazzz
Carlo323 is offline   Reply With Quote
Old 07-28-2009, 12:11 PM   #10
Lionelski
My Ride: 325CIc
I've had my car for over 8 1/2 years and have never (not even once) used the key to lock or unlock it.
For the hell of it, I'll do this when I get to the car this evening.
Good luck with your repair
'Ski
www.WarrenvilleRailroad.com
2001 325ci Convertible - Titanium Silver
Sport Package, Premium Package
Racing Dynamics Strut Tower Brace
Conforti Shark Injector, Conforti CAI
Interior: Leather, Euro Tray, M3 Dead Pedal
Lionelski is offline   Reply With Quote
Old 07-28-2009, 08:02 PM   #11
Surrept
My Ride: 2002 330ci
Easiest dyi ever. Buttons on my key do not work so I always use door. I suppose one day I'll stop being cheap and replace with a working one.
Part was less than 100 bucks from dealer and dyi took all of about 3 minutes...maybe less.
Cannot get this part from a salvage yard as its specific to your key...If I recall correctly I needed my registration and ID when ordering this....DO NOT HAVE THEM DO IT. A monkey could do it blindfolded.
Surrept is offline   Reply With Quote
Old 07-29-2009, 09:42 AM   #12
antzcrashing
My Ride: 2006 330i
Glad I made this thread, seems like a common problem.
Old 07-29-2009, 09:47 AM   #13
theman5207
My Ride: 03 325i
Mine broke, but didn't spin all the way around. The key would stop at the 180 degree positions, just like normal, but there was no resistance when turning the key and it did not lock or unlock the door. In my case, the locking cylinder was broken. You can order the aprt by VIN at the dealer for approx $100. Installation is really, really easy. Open the door, loosen one screw, pull out, replace the colored cover, and reinstall. 30 mins, tops.
theman5207 is offline   Reply With Quote
Old 07-29-2009, 09:53 AM   #14
antzcrashing
My Ride: 2006 330i
true, mine stops at the 180 degree positions too
Old 08-04-2009, 03:44 PM   #15
jeguana
My Ride: 2000 323ci
I have this problem too. I took off the door lock and noticed the small little "plastic" tab that makes the rod turn is broken, and fell right out. Can i replace this little piece or do I need to replace the entire locking cylinder assembly?
jeguana is offline   Reply With Quote
Old 08-04-2009, 03:53 PM   #16
funkboy316
My Ride: 2003 M3 vert
didnt realize this was such a common problem.......last year i had this part replaced as well when my key wouldnt unlock the door.
2003 TiAg HPF stage 2.5 SMG M3 vert
funkboy316 is offline   Reply With Quote
Old 08-04-2009, 03:56 PM   #17
jeguana
My Ride: 2000 323ci
which part? number 11?
Old 08-04-2009, 04:13 PM   #18
funkboy316
yup
Old 08-12-2009, 01:58 PM   #19
bluRS
My Ride: 328ci
if ordering this part should one get the coded or uncoded? (whats the difference btw?)
thanks
bluRS is offline   Reply With Quote
Old 08-12-2009, 02:59 PM   #20
jbeurotech
Regional Sponsor
thanks
Coded means its cut for your key. thats the ONLY way I ebver order them
Seth Thorson
