Thread Tools Search this Thread Rating: Thread Rating: 28 votes, 5.00 average. Display Modes
Old 06-23-2009, 01:34 PM   #21
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
My Ride: 2001 / 330i
Send a message via MSN to ShaitanCR
Originally Posted by jbeurotech View Post
You need to use IE7 with SVG plug in and active x
HEY. i found this...
http://www.stealthone.biz/iguides/E4...tion_Guide.pdf
which has a very well detailed instructions on how to get to the K-BUS AND HOW TO REMOVE IT...
here are some images of the pdf for future refrence.
ID:	320595   Click image for larger version
************! STEPTRONIC ALL THE WAY...
*SPL Car Audio Champion*
Hamann EURO Black Shadowline Grills
Black EURO 330i emblem
Carbon Fiber Hamann Style Eyelids
Carbon Fiber Emblems
Clear Turn Lights and Sidemarkers
ShaitanCR is offline   Reply With Quote
Old 06-23-2009, 01:49 PM   #22
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
ok, with those images i posted above i can get to the box and remove it with no problem. now i just nead to know the diagram of all those white/yellow/red wires !
Old 06-23-2009, 02:15 PM   #23
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
What happens if I just leave the K-BUS disconnected ? How will the car be affected?
Also. maybe this is a very obvious question, but should i work on the k-BUS with the battery disconnected? how can i tell if what i pull out solves the problme or not ?
Old 06-23-2009, 04:16 PM   #24
sillieidiot
My Ride: '06 AW 330ci
if you want to put a switch, i would do it after the fuse. although, i would much rather use a relay so that i don't have to manually turn it off everytime. just find another switch wire to use as a trigger.
hopefully you'll be able to fix it with jb's help.
you will need the battery connected if you're testing those wires for power.
Old 06-23-2009, 04:18 PM   #25
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
thats what i thought. thanks ! I much rather try to fix the problem with BJ's help than hack at the wires and add a switch. thanks !
Old 06-23-2009, 04:46 PM   #26
sillieidiot
Does firefox have an IE emulator?? I heard they did
they do, but i get run time errors when i try to look at the picture. and ie7 seems to never load the page for some reason for me.
Old 06-23-2009, 05:07 PM   #27
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
thats all i need to start testing the K-BUS. the diagram. is their anywhere else to get it that is not on that site which you need ot have IE7 ?
Old 06-23-2009, 05:41 PM   #28
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
try this
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 06-24-2009, 12:06 PM   #29
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
try this
great. I am looking at the pdf file. I know the X10116 is the K-BUS BLACK BOX attached to the fuse box. i have allready removed that and have full access to it. The pictures below show exactly where i am now.
I dont know what i am looking for in the diagram? are those the connectors to the block that has the yellow/white/red wires?
Should i be cutting and testing? or is their a way to remove the cables without cutting them? please advice on next step. thanks !
LOOK AT PICTURES !
ID:	320707   Click image for larger version
ID:	320708   Click image for larger version
ID:	320709   Click image for larger version
ID:	320711   Click image for larger version
ID:	320712   Click image for larger version
Old 06-24-2009, 12:09 PM   #30
jbeurotech
Regional Sponsor
You will realese the lock tab and can pull them out one by one!! Good work and nice pictures and proper testing!!
Seth Thorson
Old 06-24-2009, 12:58 PM   #31
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
thanks, hopefully someone will find them useful, i know i couldn't find any b4 i started the thread... now...lock tab? hmmmm!
lock tab on the little block i removed from the K-BUS box? the one on this photo? how do i remove the lock tab? can u point it out on one of the pictures?
am i in the right place? the yellow/white/red wires?
according to the diagram you gave me, am i looking at it from left to right like in the picture? in this order... PDC,X18344,Convertible top,safety and info,rain and headlight,heating and ac,? their are 7 spaces, u can see it in the picture.
Thanks allot for all your help. sorry for taking so much time !
Old 06-24-2009, 02:59 PM   #32
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
found this intresting read...
"A high-tech data bus system or k-bus system is incorporated to enhance reliability
and reduce the amount of cables, wires and connectors,
The k-bus system reduces the number of wires and cables by using the same
wires and cables for different systems, called mutual data transmission.
Besides reliability, the k-bus system makes assembly much easier, reduces
weight and allows for the integration of additional functions such as rain sensors."
Old 06-25-2009, 12:34 PM   #33
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
ok, so i finally got the K-BUS out of the black plastic housing and separated all the wires.
here are some pictures..
Old 06-25-2009, 12:36 PM   #34
jbeurotech
Regional Sponsor
There you go nice pictures of how it comes apart
Seth Thorson
Old 06-25-2009, 12:46 PM   #35
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
Here is where I am now, and what i solved and what went wrong...
What i wanted to work in the first place, now works GREAT. the radio ! it consists of 4 wires. Head Unit, CD changer and Steering wheel controls. with those 4 wires together i can turn on and off the radio as i want and everything works fine.
The other 3 wires separated on the photo are the 2 blinker wires and 1 seat belt wire, all 3 must be together for both functions to work!
all great to their.
NOW. what changed...
In total their are 13 wires. now i have 6 that i don't know what they do or how to pair them up.
1. The passenger side rear view mirror does not move electronically. the driver side one works fine.
2. the sunroof does not open all the way with just one touch of the button, must keep it pressed.
3.The interior lights do not turn on when the key is taken out of the ignition. they do turn on fine when i open the door.
4. the doors do not lock automatically after driving for about 10 seconds. they do lock fine with lock button and key button.
5. Doors opened indicator on dash does not work. everything else on dash works fine.
at least the radio now works great...HELP...
Any suggestions? I just got a 12v tester. so i am going to go over it again and c what is what.
Thanks in advance
Name:	new k-bus.jpg
ID:	320883   Click image for larger version
Name:	new k-bus2.jpg
Old 06-25-2009, 12:47 PM   #36
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
thanks JB. now read what happened after. HELP
Old 06-25-2009, 12:55 PM   #37
jbeurotech
Regional Sponsor
PM sent
Seth Thorson
Old 06-26-2009, 11:15 AM   #38
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
UPDATE...
Battery died on me while testing. yes I had the car off. STUPID i know !
soooo.
I fixed the sideview mirror not working electronically, the cable must be attached to the 4 radio cables.
Found the doors opened indicator on the dash cable (safety and info cable) it must be attached to the two blinker cables for the seatlbelt light to work on the dash, AND. it must be connected to the radio cables for the door's opened and safety info to show.
that's BMW for you, all electronic issues are complicated by fancy systems !
whats the problem with that?... THE RADIO WILL NOT TURN OFF... we go back to the same problem as before !
so right now all is working except the doors opened, safety info on the dash, which control the autolock at 8mph. can i live without that? SURE! but I am gonna run some more tests before i finish !
Old 06-26-2009, 03:24 PM   #39
sillieidiot
lol goodluck
Old 06-29-2009, 01:53 PM   #40
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
Thumbs Up
lol goodluck
THANKS...
UPDATE 2 :
My battery died. got a new one (free)
Found out that the module messing around with the K-BUS was the info/emergency one (doors opened indicator on dash) unplugged it, and now everything is working fine.
radio
mirrors
sunroof
a/c
lights
seatbelt light
blinker lights
etc, etc
thanks for the help
