Old 06-23-2009, 11:39 AM   #1
Amberite
My Ride: 328xi
Need help removing passenger side mirror (glass only)
My passenger side mirror was knocked off the other day. I purchased a new housing unit from a BMW dealership and I plan to install it myself. The only thing is I need to remove the old mirror (just the glass) from the broken housing and install it in the new housing. Can anyone point me out to an online guide or just tell me what I need to free the mirror of the housing?
Thanks!
Amberite is offline   Reply With Quote
Old 06-23-2009, 11:45 AM   #2
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
Tilt the glass so it's as far "up" as possible.
Look under the bottom of the glass, behind it you should see a little tab. Use a very small thin screwdriver and slide the tab (can't recall if you slide it clockwise or counterclockwise....)
That will unlock the glass. There will most likely be some double sided tape still holding it barely in place as well.
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 06-23-2009, 11:46 AM   #3
Amberite
My Ride: 328xi
TKC, thanks for the quick reply! I saw a picture of this, but it was for an M3. Does the same procedure still apply to a regular 325ci? I know the mirrors are slightly different...
Old 06-23-2009, 11:47 AM   #4
TKC
It was the same on my 330ci.
Old 06-23-2009, 11:49 AM   #5
TKC
Try what these guys said?
http://forum.e46fanatics.com/showthr...removing+glass
Better one:
Old 06-23-2009, 11:56 AM   #6
Amberite
My Ride: 328xi
Wow thats great. Thanks TKC! The second link even has pictures.
Old 06-23-2009, 11:57 AM   #7
TKC
np, good luck.
